Error when binary_sensor moves to a difference file
I have my binary sensors are also inside the configuration.yaml file.
I want move them to a seperate file called binary_sensor.yaml
I have created this file & moved the binary sensors to this file & added the following line to the configuration.yaml file.
binary_sensor: !include binary_sensor.yaml
But I get the error Configuration warnings
Invalid config for ‘binary_sensor’ at configuration.yaml, line 11: required key ‘platform’ not provided
My binary_sensor.yaml files lookes as follows
binary_sensor:
    sensors:
      is_night:
        friendly_name: "Is Night"
        value_template: >-
          {{ now().time() >= strptime('18:00:00', '%H:%M:%S').time() or now().time() < strptime('06:00:00', '%H:%M:%S').time() }}
    sensors:
      pixel_work:
        friendly_name: "Pixel Work"
        value_template: "{{ is_state('device_tracker.pixel_7', 'work') }}"
How to resolve this?
Remove this line from your binary_sensor.yaml file.
At the moment your !include resolves to this in your configuration.yaml file:
binary_sensor:
  binary_sensor:
      sensors: etc...
When it should only be this:
binary_sensor:
    sensors: etc...
Also you should be using the new template integration for new sensors. And your “is night” sensor could be done a lot easier with the ToD integration:
