Hello. I reinstalled Home Assitant, but when I try to restore my backup I’m always having this error in the cmd:
INFO:homeassistant.backup_restore:Restoring C:\Program Files\HassWP\config\backups\f93a062d.tar
WARNING:securetar:Found issue with file backup.json
WARNING:securetar:Found issue with file homeassistant.tar.gz
File “C:\Program Files\HassWP\python\Lib\site-packages\homeassistant\backup_restore.py”, line 175, in restore_backup
_extract_backup(
config_dir=config_dir,
restore_content=restore_content,
File “C:\Program Files\HassWP\python\Lib\site-packages\homeassistant\backup_restore.py”, line 107, in _extract_backup
backup_meta = json.loads(backup_meta_file.read_text(encoding=“utf8”))
File “C:\Program Files\HassWP\python\Lib\pathlib_local.py”, line 546, in read_text
return PathBase.read_text(self, encoding, errors, newline)
File “C:\Program Files\HassWP\python\Lib\pathlib_abc.py”, line 632, in read_text
with self.open(mode=‘r’, encoding=encoding, errors=errors, newline=newline) as f:
File “C:\Program Files\HassWP\python\Lib\pathlib_local.py”, line 537, in open
return io.open(self, mode, buffering, encoding, errors, newline)
FileNotFoundError: [Errno 2] No such file or directory: ‘C:\Users\jonas\AppData\Local\Temp\tmpg3ipqrpp\extracted\backup.json’
File “C:\Program Files\HassWP\python\Lib\site-packages\hass_win_main_.py”, line 144, in
sys.exit(main.main())
File “C:\Program Files\HassWP\python\Lib\site-packages\homeassistant_main_.py”, line 186, in main
if restore_backup(config_dir):
File “C:\Program Files\HassWP\python\Lib\site-packages\homeassistant\backup_restore.py”, line 180, in restore_backup
raise ValueError(f"Backup file {backup_file_path} does not exist") from err
ValueError: Backup file C:\Program Files\HassWP\config\backups\f93a062d.tar does not exist
