ERROR when setting temp
Hi I get the following error when my trigger event happens but i dont know why i can find the temp value
INFO:homeassistant.components.automation:Executing Heating
INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sensor.time, old_state=<state sensor.time=13:17; icon=mdi:clock, friendly_name=Time @ 13:17:00 08-04-2016>, new_state=<state sensor.time=13:18; icon=mdi:clock, friendly_name=Time @ 13:18:00 08-04-2016>>
INFO:homeassistant.core:Bus:Handling <Event logbook_entry[L]: name=Heating, domain=automation, message=has been triggered>
INFO:homeassistant.core:Bus:Handling <Event call_service[L]: service_data=entity_id=['thermostat.home'], service=set_temperature, domain=thermostat, service_call_id=1980491696-1>
ERROR:homeassistant.components.thermostat:Received call to set_temperature without attribute temperature
Configuration
alias: Heating
  platform: time
  after: '13:18:00'
  weekday:
  - mon
  - tue
  - wed
  - thu
  - fri
condition:
  - platform: numeric_state
    entity_id: sensor.1st_floor
    below: 30
  service: thermostat.set_temperature
  entity_id: thermostat.home
  target_temp_low: 27
  target_temp_high: 28
you need data on your service call :blush:
alias: Heating
platform: time
after: ‘13:18:00’
weekday:
  • mon
  • tue
  • wed
  • thu
  • fri
    condition:
  • platform: numeric_state
    below: 30
    target_temp_low: 27
try this
Hi
Thanks for this but unfortunately it did not like the data part
here is a the error output
16-04-20 15:22:23 homeassistant.bootstrap: Invalid platform config for [automation]: expected dict for dictionary value @ data[‘action’][‘data’]. OrderedDict([(‘alias’, ‘Heating’), (‘trigger’, [OrderedDict([(‘platform’, ‘numeric_state’), (‘entity_id’, ‘sensor.1st_floor’), (‘below’, 30)])]), (‘action’, OrderedDict([(‘service’, ‘thermostat.set_temperature’), (‘entity_id’, ‘thermostat.home’), (‘data’, None), (‘target_temp_low’, 27), (‘target_temp_high’, 28)]))])
Try formatting it like this:
- alias: Heating
    platform: time
    after: '13:18:00'
  condition:
      below: 30
    - platform: time
      weekday:
        - mon
        - tue
        - wed
        - thu
        - fri
      target_temp_low: 27
Thanks this has helped alot but the data element doesent appear to be setting the heat_control componets temperature when its triggered.
ive tried different options with no success
target_temp_low: 27
temperature: 27
state: 27
Try target_temp :wink:
Sadley no :frowning:
alias: Heating
platform: time
after: ‘11:00:00’
condition:
below: 30
- platform: time
weekday:
- mon
- tue
- wed
- thu
- fri
target_temp: 27
The data attribute for set_temperature is called temperature. Make sure you format the yaml correctly. When you post it without code markdown here, we can’t judge the formatting.
You can test calling the service from the developer tools, but there you use json formatting for the attributes.
This what i have now bu t im getting an error.
16-04-22 09:00:00 homeassistant.components.automation.numeric_state: Value returned from template is not a number: unknown
  alias: Heating
    platform: time
    after: '09:00:00'
  condition:
      below: 30
    - platform: time
      weekday:
        - mon
        - tue
        - wed
        - thu
        - fri
      temperature: 27
Have you been able to get this to work.
I’ve tested the below setup and seems to work and wanted to provide in case it is still needed.
  • alias: Hot in Bedroom Turn on Action
    entity_id: sensor.aeotec_multisensor_6_temperature_3
    above: 71
    condition:
    condition: time
    after: ‘19:00:00’
    before: ‘22:00:00’
    entity_id: thermostat.hallwaywhats_up_fishes
    temperature: 70
