I just updated ESPHome to 2025.2.0. After that, there was an update for the voice assistant PE available. When starting the update on ESPHome, this error is shown:
INFO ESPHome 2025.2.0
INFO Reading configuration /config/esphome/home-assistant-voice-099af9.yaml...
INFO Updating https://github.com/esphome/home-assistant-voice-pe@dev
WARNING GPIO0 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
WARNING GPIO3 is a strapping PIN and should only be used for I/O with care.
Failed config
light.esp32_rmt_led_strip: [source /data/packages/dc43710d/home-assistant-voice.yaml:559]
platform: esp32_rmt_led_strip
pin: GPIO21
This feature is not available for the IDF framework version 5.
rmt_channel: 1
num_leds: 12
rgb_order: GRB
chipset: WS2812
default_transition_length: 0ms
power_supply: led_power
Seems the configuration file on github contains some false references?
I got it with al mine device. Home assiatnt voice. kincony AS en Apollo msr-2. and it all involves the same control of the LEDs. They have already created a workaround for the Apollo by putting this behind it.
I need to bring mine in to ESPHome to make the Wi-Fi stick. Without setting up in the yaml - whenever it loses power it fails to connect to the Wi-Fi. I guess I’ll just have to wait (it has been reported on the relevant github repository)
Sorry wasn’t meant to come across as lecturing you, I only found that myself just before. I don’t have a solution as I also have the same issue on another bit of ESPhardware
