Error while setting up platform plex
Hello
I am having an issue setting up Plex. I followed the instructions here: https://www.home-assistant.io/components/media_player.plex/
But I seem to be getting an error:
  File "/srv/homeassistant/lib/python3.5/site-packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
  File "/srv/homeassistant/lib/python3.5/site-packages/urllib3/connectionpool.py", line 354, in _make_request
conn.request(method, url, **httplib_request_kw)
  File "/usr/lib/python3.5/http/client.py", line 1107, in request
self._send_request(method, url, body, headers)
  File "/usr/lib/python3.5/http/client.py", line 1152, in _send_request
self.endheaders(body)
  File "/usr/lib/python3.5/http/client.py", line 1103, in endheaders
self._send_output(message_body)
  File "/usr/lib/python3.5/http/client.py", line 934, in _send_output
self.send(msg)
  File "/usr/lib/python3.5/http/client.py", line 877, in send
self.connect()
  File "/srv/homeassistant/lib/python3.5/site-packages/urllib3/connection.py", line 181, in connect
conn = self._new_conn()
  File "/srv/homeassistant/lib/python3.5/site-packages/urllib3/connection.py", line 168, in _new_conn
self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x6881d390>: Failed to establish a new connection: [Errno 111] Connection refused
  File "/srv/homeassistant/lib/python3.5/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
  File "/srv/homeassistant/lib/python3.5/site-packages/urllib3/connectionpool.py", line 638, in urlopen
_stacktrace=sys.exc_info()[2])
  File "/srv/homeassistant/lib/python3.5/site-packages/urllib3/util/retry.py", line 398, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='localhost', port=32400): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x6881d390>: Failed to establish a new connection: [Errno 111] Connection refused',))
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py", line 128, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
  File "/usr/lib/python3.5/asyncio/tasks.py", line 400, in wait_for
return fut.result()
  File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
  File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/sensor/plex.py", line 62, in setup_platform
plex_token)], True)
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/sensor/plex.py", line 89, in __init__
self._server = PlexServer(plex_url)
  File "/srv/homeassistant/lib/python3.5/site-packages/plexapi/server.py", line 102, in __init__
data = self.query(self.key, timeout=timeout)
  File "/srv/homeassistant/lib/python3.5/site-packages/plexapi/server.py", line 341, in query
response = method(url, headers=headers, timeout=timeout, **kwargs)
  File "/srv/homeassistant/lib/python3.5/site-packages/requests/sessions.py", line 537, in get
return self.request('GET', url, **kwargs)
  File "/srv/homeassistant/lib/python3.5/site-packages/requests/sessions.py", line 524, in request
resp = self.send(prep, **send_kwargs)
  File "/srv/homeassistant/lib/python3.5/site-packages/requests/sessions.py", line 637, in send
r = adapter.send(request, **kwargs)
  File "/srv/homeassistant/lib/python3.5/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='localhost', port=32400): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x6881d390>: Failed to establish a new connection: [Errno 111] Connection refused',))
Any help would be greatly appreciated
Following. Having the exact same issue. Have tried different methods found online to no avail.
Did you resolve this?
