I installed HASSIO on an existing pi3 (hence in a docker container), now I need my HASSIO installation to interact with GPIO, but I have this error…
I added to the group GPIO the user hass, my user in HASSIO, the user for which I connect to the pi3 … but is not working … any advice?
2019-02-09 13:10:21 ERROR (MainThread) [homeassistant.components.switch] Error while setting up platform rpi_gpio
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 128, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File "/usr/local/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
return fut.result()
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/switch/rpi_gpio.py", line 44, in setup_platform
switches.append(RPiGPIOSwitch(name, port, invert_logic))
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/switch/rpi_gpio.py", line 57, in __init__
rpi_gpio.setup_output(self._port)
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/rpi_gpio.py", line 39, in setup_output
GPIO.setup(port, GPIO.OUT)
RuntimeError: No access to /dev/mem. Try running as root!
