Error while setting up rpi_gpio platform for switch
I have: Error while setting up rpi_gpio platform for switch.
I cant use any GPIO :frowning:
PS: I dont have hass user. I have only root and pi. HA instalation is on docker i think ?
You have not given much to go on, first read this:
https://community.home-assistant.io/t/how-to-help-us-help-you-or-how-to-ask-a-good-question/114371/4
You may then wish to start here, its one possibility:
Good luck
I am not familiar enough with docker compose to answer, hopefully someone who is will jump in here for you. That being said I think you need to add the device to the volume:
  - /home/pi/homeassistant:/config --device=/dev/gpio:/dev/gpio
But I am just guessing, the other way is to privilege the container with
--privileged
Did you read the link @Kdem posted, especially point 11 on how to post code? Please don’t post screenshots of code.
You don’t need to mount a volume, you need to mount a device
try:
device:
  - /dev/gpiomem:/dev/gpiomem
i add this now but this isnt working too :frowning: i try to add this in all configuration
services:
homeassistant:
container_name: home-assistant
image: homeassistant/raspberrypi4-homeassistant:stable
volumes:
  - /dev/mem:/dev/mem
devices:
  - /dev/mem:/dev/mem
privileged: true
environment:
  - TZ=Europe/Warsaw
restart: always
network_mode: host
