I’ve been trying to get this working for two weeks now, but to no avail. I have two MiFlora sensors that are reporting their values correctly to Home Assistant. I have configured these as two plant entities (plant.monstera_deliciosa and plant.howea_forsteriana) and both are reporting the correct values for humidity, brightness, moisture, etc…
I now want to display their current state using the custom card by thomasloven, but I keep getting a “Custom element doesn’t exist: flower-card.” error in Lovelace. I have searched the forums here, but I found only one topic where a faulty data.js file was at the source. However, the logs don’t show any related errors indicating data.js problems for me.
What I have done so far:
Configured the sensors and joined them through plant entitities (verified working)
Installed the custom card via HACS
The card is loaded via “config/lovelace/resources” just like my other custom cards that do work fine.
