Error with esphome and SHT3xD connection
Hello, I’m trying to use my ESP to monitor temperature and humidity, but I can’t connect to sht3xd. Is there a problem with my code? Everything works fine from the Arduino IDE.
[18:26:00.344][I][i2c.arduino:099]: Results from bus scan:
[18:26:00.344][I][i2c.arduino:105]: Found device at address 0x40
[18:26:00.354][C][sht3xd:048]: SHT3xD:
[18:26:00.355][D][sht3xd:051]:   Error reading serial number
[18:26:00.355][E][sht3xd:060]:   Communication with SHT3xD failed!
[18:26:00.355][E][component:154]:   sht3xd.sensor is marked FAILED: unspecified
esphome:
  friendly_name: essai
  on_boot:
    priority: 200
    then:
      - lambda: |-
          delay(500);
esp8266:
  board: esp01_1m
# Example configuration entry for ESP32
i2c:
  sda: GPIO4
  scl: GPIO5
  scan: true
  frequency: 800khz
  timeout: 10ms
  - platform: sht3xd
    i2c_id: bus_a
    temperature:
      name: "Living Room Temperature"
    humidity:
      name: "Living Room Humidity"
    address: 0x40
    update_interval: 60s
    heater_enabled: false
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "3NKfZUQ7skFrMfc8I+2qdC/0FIUEJX8uq6tHEVqaJV8="
ota:
  - platform: esphome
    password: "5993182d1721886c1f17f4a7f8a3c970"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Essai Fallback Hotspot"
    password: "6NsbtmNemQBs"
captive_portal:
That hints your sensor might be sht2x
Try what you get with this:
i2c:
  sda: GPIO4
  scl: GPIO5
  - platform: htu21d
    temperature:
    humidity:
Doesn’t this ESP01 only have GPIOs 0-3? Which pins is the sensor connected to?
