I have an automation that should activate a change in thermostat setting if one of my TRVs needs heat, but I’m getting some errors in the log I cannot figure out.
This is my automation:
alias: Study Ask Heat
description: ""
value_template: |-
{% set therm = states['climate.big_study_radiator'] %}
{{ therm.attributes.current_temperature < therm.attributes.temperature }}
value_template: |-
{% set therm = states['climate.small_study_radiator'] %}
condition:
- condition: template
value_template: |-
{% set therm = states['climate.incomfort_1'] %}
{{ therm.attributes.current_temperature > therm.attributes.temperature }}
- device_id: 90ed87e3fcc7dbd52e4ad12748189c45
domain: mobile_app
type: notify
message: Living Room 19
- service: climate.set_temperature
temperature: 19
entity_id: climate.incomfort_1
mode: single
And here’s the error code:
Logger: homeassistant.helpers.event
Source: helpers/template.py:425
First occurred: 11:35:11 (4 occurrences)
Last logged: 11:35:11
Error while processing template: Template("{% set therm = states['climate.big_study_radiator'] %} {{ therm.attributes.current_temperature < therm.attributes.temperature }}")
Error while processing template: Template("{% set therm = states['climate.small_study_radiator'] %} {{ therm.attributes.current_temperature < therm.attributes.temperature }}")
Error while processing template: Template("{% set therm = states['climate.big_study_radiator'] %} {{ therm.attributes.current_temperature >= therm.attributes.temperature }}")
Error while processing template: Template("{% set therm = states['climate.small_study_radiator'] %} {{ therm.attributes.current_temperature >= therm.attributes.temperature }}")
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 423, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1950, in _render_with_context
return template.render(**kwargs)
File "/usr/local/lib/python3.10/site-packages/jinja2/environment.py", line 1301, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.10/site-packages/jinja2/environment.py", line 936, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<template>", line 2, in top-level template code
TypeError: '<' not supported between instances of 'NoneType' and 'NoneType'
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 540, in async_render_to_info
render_info._result = self.async_render(variables, strict=strict, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 425, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: TypeError: '<' not supported between instances of 'NoneType' and 'NoneType'
