Error with Home Assistant
I woke up to this morning to no automations and I’m getting this error,
I have unplugged the home assistant yellow, waiting 10 sec and plugged it back in, and I’m still getting the same error
Please help
See “Troubleshooting” section here: Documentation – Home Assistant Yellow
But want I’m i looking for in the troubleshooting
Are the LEDs on the Yellow flashing the correct pattern? Have you connected to the serial console to access the CLI and issue commands, view the logs, etc.?
Everything worked fine last night, lights went off at 10 like they are supposed to, I went to bed. This morning they did not come back on at 5:30 like they should have. The light was Solid yellow this morning. I am not at home, so I can not access the system through local IP. And Nabu Casa is telling me
Remote UI
Your instance is not connected to Home Assistant Cloud
Remote address: Not available
So something happen overnight
can i fix this remotely or I have to be local
