Hi all,
I am having a problem when I try to turn on/off the zigbee relay ( NodOn Zigbee 1-Channel 16A Relay Switch SIN-4-1-20 ) from zigbee2mqtt. However, from the physical button of the relay it works perfectly, which indicates that it is not broken.
the relay has a good connection with my sonoff router,but this is the error code from z2m:
<small>2022-11-11 23:34:00</small>`Publish 'set' 'state' to 'Caldera_nodon' failed: 'Error: Command 0x04cd15fffea579be/242 genOnOff.off({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 54056 - 242 - 38 - 6 - 11 after 10000ms)'
I want to use it to start a boiler and it is the only zigbee that I have been able to find, I don’t know if someone there has this same model and it works correctly or maybe I have had a bad unit.
Thanks you.
