Error with Zigbee2mqtt in HA version 7.0
Since I updated HA version 6.6 (I have raspberry and HomeAssistant OS) to version 7.0, the Zigbee2mqtt addon gives me an error, I only have 3 test devices with zigbee and it takes around 4-5 minutes to load map (the devices near the raspberry) and when loading the map, no connection lines or LQIs appear on the map. In the log I get an error saying “failed to execute LQI for ‘Coordinator’”
I have reinstalled mosquitto and zigbee2mqtt several times and the problem persisted.
I installed HA 6.6 version from scratch and zigbee2mqtt works perfectly.
I install HA version 7.0 again and zigbee2mqtt gives another problem (clean installation all)
I use usb 2.0 extension cable and ConbeeII antenna
Any ideas? HA 7.0 incompatibility with zigbee2mqtt?
I attach some images of the error (after 4-5 minutes loading the map the following error appears)
Captura2
Captura3
And this is how it looks in HA 6.6
photo_2021-12-15_16-42-44
Well, finally, it is not the version because it also makes it to me in 6.6 now …
I can’t think of what else to do, I have changed the usb port, changed the usb cable of the conbeeII, I have put the firm before the conbeeII, I have put the raspberry in another room and it keeps giving me an error.
If I run ConbeeII on Windows with the official application (Deconz), the devices detect them without problem
Any ideas?
