Error writing to I2S: ESP_ERR_INVALID_STATE
I have made a custom ESP S3 board with some voice assist hardware. The hardware is largely based on the ESPbox reference. As of now the mic is working great but every time the assist tries to play audio it throws an unexpected error, and if I try to play audio directly the logs fill up with the message “Error writing to I2S: ESP_ERR_INVALID_STATE”
The I2C buses appear fine, sensors work. Lights work. I am connecting via W5500 ethernet. I just do no know enough about the audio segment to begin to troubleshoot if I have a hardware issue, config issue, or some other issue.
Can anyone help point me int he right direction? Relevant config below
external_components:
  - source: github://rpatel3001/esphome@es7210
    components:
      - es7210
  - source:
      type: git
      url: https://github.com/esphome/home-assistant-voice-pe
      ref: dev
    components:
      - media_player
      - nabu
i2s_audio:
  i2s_lrclk_pin: GPIO45
  i2s_bclk_pin: GPIO17
  i2s_mclk_pin: GPIO02
audio_dac:
  - platform: es8311
    bits_per_sample: 24bit
    sample_rate: 16000
    i2c_id: audio_i2c
    use_mclk: true
es7210:
  i2c_id: audio_i2c
speaker:
  - platform: i2s_audio
    i2s_audio_id: audio_bus
    i2s_dout_pin: GPIO15
    dac_type: external
    channel: mono
    audio_dac: es8311_dac
    sample_rate: 16000
    i2s_comm_fmt: stand_i2s
media_player:
  - platform: nabu
    audio_dac:
    speaker:
    volume_increment: 0.05
    volume_min: 0.4
    volume_max: 0.85
    files:
      - id: timer_finished_sound
        file: https://github.com/esphome/home-assistant-voice-pe/raw/dev/sounds/timer_finished.flac
      - id: wake_word_triggered_sound
        file: https://github.com/esphome/home-assistant-voice-pe/raw/dev/sounds/wake_word_triggered.flac
      - id: easter_egg_tick_sound
        file: https://github.com/esphome/home-assistant-voice-pe/raw/dev/sounds/easter_egg_tick.mp3
      - id: easter_egg_tada_sound
        file: https://github.com/esphome/home-assistant-voice-pe/raw/dev/sounds/easter_egg_tada.mp3
microphone:
    adc_type: external
    pdm: false
    i2s_din_pin: GPIO16
    bits_per_sample: 16bit
