Salve qualcuno mi può dire se c’è un errore di sintassi nell’inserire la voce script nel file configuration.yaml ?
mi serve per richiamare un trigger tramite il servizio webhook
Non riesco a venirne a capo, mi si blocca tutto il sistema se abilito queste righe
Hi, can anyone tell me if there is a syntax error in inserting the script entry in the configuration.yaml file?
I need to call a trigger via the webhook service
I can not get through, I crashed the whole system if I enable these lines
Thank you
@petro nailed it. the pretty unicode quotation marks are the cause.
Additionally though ,if this is in your configuration.yaml, you can’t !include configuration.yaml inside. For all I know (I’m new), you CAN, but it doesn’t make sense.
