I saw these errors in my log :
Logger: homeassistant.helpers.event
Source: helpers/template.py:645
First occurred: 13:28:20 (12 occurrences)
Last logged: 13:28:20
Error while processing template: Template<template=({% if states('vacuum.roborock_q8_max') == 'unavailable' %} Niet bereikbaar {% else %} nog {{ ((states("sensor.roborock_q8_max_side_brush_left") | int ) / 3600) | round(0) }} uren ({{ ((((states("sensor.roborock_q8_max_side_brush_left") | int(0) ) / 3600) / 200) * 100)| round(0, 'ceil') }}%) {% endif %}) renders=6>
Error while processing template: Template<template=({% set vacrooms = namespace(roomtot=0) %} {% for rooms in state_attr('sensor.roborock_rooms','rooms') -%} {% if is_state(rooms.boolean,'on') %} {% set vacrooms.roomtot = vacrooms.roomtot + 1 %} {% endif %} {%- endfor %} {% if vacrooms.roomtot > 0 %} green {% else %} grey {% endif %}) renders=8>
Error while processing template: Template<template=({% if states('vacuum.roborock_q8_max') == 'unavailable' %} Niet bereikbaar {% else %} nog {{ ((states("sensor.roborock_q8_max_filter_left") | int ) / 3600) | round(0) }} uren ({{ ((((states("sensor.roborock_q8_max_filter_left") | int(0) ) / 3600) / 150) * 100)| round(0, 'ceil') }}%) {% endif %}) renders=8>
Error while processing template: Template<template=({% if states('vacuum.roborock_q8_max') == 'unavailable' %} Niet bereikbaar {% else %} nog {{ ((states("sensor.roborock_q8_max_main_brush_left") | int ) / 3600) | round(0) }} uren ({{ ((((states("sensor.roborock_q8_max_main_brush_left") | int(0) ) / 3600) / 300) * 100)| round(0, 'ceil') }}%) {% endif %}) renders=8>
Error while processing template: Template<template=({% if states('vacuum.roborock_q8_max') == 'unavailable' %} Niet bereikbaar {% else %} nog {{ ((states("sensor.roborock_q8_max_side_brush_left") | int ) / 3600) | round(0) }} uren ({{ ((((states("sensor.roborock_q8_max_side_brush_left") | int(0) ) / 3600) / 200) * 100)| round(0, 'ceil') }}%) {% endif %}) renders=8>
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 643, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2756, in _render_with_context
return template.render(**kwargs)
File "/usr/local/lib/python3.13/site-packages/jinja2/environment.py", line 1295, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.13/site-packages/jinja2/environment.py", line 942, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<template>", line 2, in top-level template code
TypeError: 'NoneType' object is not iterable
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 760, in async_render_to_info
render_info._result = self.async_render( # noqa: SLF001
variables, strict=strict, log_fn=log_fn, **kwargs
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 645, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: TypeError: 'NoneType' object is not iterable
These templates are on my dashbord, so I made some modifications :
secondary: |
{% if not has_value('vacuum.roborock_q8_max') %}
Niet bereikbaar
{% else %}
{% endif %}
icon_color: >
{% set vacrooms = namespace(roomid=[]) %} {% for rooms in
{% set vacrooms.roomid = vacrooms.roomid + [rooms.id] %}
{% endif %}
{%- endfor %} {% if vacrooms.roomid |count > 0 %}
green
{% else %}
grey
{% endif %}
secondary: |
Niet bereikbaar
{% else %}
{% endif %}
secondary: |
Niet bereikbaar
{% else %}
{% endif %}
But now when I restart HA I still get these errors with the old code ??
What do I miss here ?
