I get every day at 12:00 the following errors:
2025-10-05 12:00:00.642 ERROR (MainThread) [homeassistant.helpers.script.trigger_update_coordinator] Trigger Update Coordinator: Error executing script. Error for call_service at pos 1: Service call requested response data but did not match any entities
2025-10-05 12:00:00.962 ERROR (DbWorker_2) [homeassistant] Error doing job: Task exception was never retrieved (None)
File "/usr/src/homeassistant/homeassistant/components/template/coordinator.py", line 140, in _handle_triggered_with_script
if script_result := await self._script.async_run(run_variables, script_context):
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1836, in async_run
return await asyncio.shield(create_eager_task(run.async_run()))
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 460, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 526, in _async_step
self._handle_exception(
ex, continue_on_error, self._log_exceptions or log_exceptions
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 556, in _handle_exception
raise exception
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 524, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1012, in _async_step_call_service
response_data = await self._async_run_long_action(
...<9 lines>...
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 624, in _async_run_long_action
return await long_task
File "/usr/src/homeassistant/homeassistant/core.py", line 2835, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2878, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 844, in entity_service_call
raise HomeAssistantError(
"Service call requested response data but did not match any entities"
homeassistant.exceptions.HomeAssistantError: Service call requested response data but did not match any entities
How to understand which script is causing these errors? At 12:00 i don’t have any script running…
