Errors on VMware guest and reboots
I couldn’t find a more suitable category.
Running HA on VMware Workstation. I’m getting messages as the image below. Once there have been a few, none of my zigbee network responds. Only restarting the guest VM works but then a few days will pass and I’ll need to do it again.
Workstation is installed on a Ryzen 9 machine. This is the only issue I’m having.
The guest is passing through a Sonoff Zigbee 3.0 USB dongle.
Any ideas?
HA is designed to work on flat networks, so you are using advanced mode with little or no support like that.
I’m not sure why you would assume I’m not using a flat network. The host is on the same network and the guest which HA is running on is also on the same network running in bridged mode. Unless you mean the zigbee network which can only be flat as far as I know as the Sonoff device just gets passed through from the host.
You were talking about a guest VM, so I guess that’s not a second network. I thought that is that you meant.
