Lately I got some errors when automations are being processed. This happens with the Tuya integration and the Tado integration as well. Anybody an idea where to search?
- Core2024.1.3
- Supervisor2023.12.1
- Operating System11.4
- Frontend20240104.0
Here is the error see in the logs:
Logger: homeassistant.components.automation.19_00_boiler_uit
Source: components/automation/__init__.py:669
Integration: Automation (documentation, issues)
First occurred: January 15, 2024 at 7:00:00 PM (3 occurrences)
Last logged: 7:00:00 PM
While executing automation automation.19_00_boiler_uit
File "/usr/local/lib/python3.11/site-packages/urllib3/connectionpool.py", line 715, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.11/site-packages/urllib3/connectionpool.py", line 467, in _make_request
six.raise_from(e, None)
File "<string>", line 3, in raise_from
File "/usr/local/lib/python3.11/site-packages/urllib3/connectionpool.py", line 462, in _make_request
httplib_response = conn.getresponse()
File "/usr/local/lib/python3.11/http/client.py", line 1378, in getresponse
response.begin()
File "/usr/local/lib/python3.11/http/client.py", line 318, in begin
version, status, reason = self._read_status()
File "/usr/local/lib/python3.11/http/client.py", line 287, in _read_status
raise RemoteDisconnected("Remote end closed connection without"
http.client.RemoteDisconnected: Remote end closed connection without response
File "/usr/local/lib/python3.11/site-packages/requests/adapters.py", line 486, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.11/site-packages/urllib3/connectionpool.py", line 799, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.11/site-packages/urllib3/util/retry.py", line 550, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.11/site-packages/urllib3/packages/six.py", line 769, in reraise
raise value.with_traceback(tb)
response.begin()
urllib3.exceptions.ProtocolError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 669, in async_trigger
await self.action_script.async_run(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1587, in async_run
return await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 426, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 479, in _async_step
self._handle_exception(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 502, in _handle_exception
raise exception
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 476, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 713, in _async_call_service_step
response_data = await self._async_run_long_action(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 675, in _async_run_long_action
return long_task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 2149, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2186, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 272, in handle_service
return await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 882, in entity_service_call
single_response = await _handle_entity_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 952, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1580, in async_turn_off
await self.hass.async_add_executor_job(ft.partial(self.turn_off, **kwargs))
File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/tuya/switch.py", line 777, in turn_off
self._send_command([{"code": self.entity_description.key, "value": False}])
File "/usr/src/homeassistant/homeassistant/components/tuya/base.py", line 275, in _send_command
self.device_manager.send_commands(self.device.id, commands)
File "/usr/local/lib/python3.11/site-packages/tuya_iot/device.py", line 488, in send_commands
return self.device_manage.send_commands(device_id, commands)
File "/usr/local/lib/python3.11/site-packages/tuya_iot/device.py", line 649, in send_commands
return self.api.post(
File "/usr/local/lib/python3.11/site-packages/tuya_iot/openapi.py", line 316, in post
return self.__request("POST", path, None, body)
File "/usr/local/lib/python3.11/site-packages/tuya_iot/openapi.py", line 266, in __request
response = self.session.request(
File "/usr/local/lib/python3.11/site-packages/requests/sessions.py", line 589, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.11/site-packages/requests/sessions.py", line 703, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.11/site-packages/requests/adapters.py", line 501, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
