Since the upgrade of ESPHone Device Builder 2305.3.0 earlier this week, my ESP-01s thermometers are failing to join my WiFi network? I have five and as far as I can tell, they are all the same.
My esp32 devices seem to be unaffected.
My AP log shows:
Fri Mar 21 10:08:38 2025 daemon.notice hostapd: phy0-ap0: STA ec:fa:bc:34:c7:c9 IEEE 802.11: did not acknowledge authentication response
Fri Mar 21 10:08:42 2025 daemon.notice hostapd: phy0-ap0: STA 48:55:19:6b:ca:a8 IEEE 802.11: did not acknowledge authentication response
Fri Mar 21 10:08:53 2025 daemon.notice hostapd: phy0-ap0: STA 48:55:19:6b:ca:a8 IEEE 802.11: did not acknowledge authentication response
Fri Mar 21 10:08:59 2025 daemon.notice hostapd: phy0-ap0: STA ec:fa:bc:34:c7:c9 IEEE 802.11: did not acknowledge authentication response
… over and over again.
If left to there own devices (whatever that is) they will sometimes connect (tens of minuets) and then fail some time later.
This is my yaml:
esphome:
#friendly_name: "esp01-ds18b20-1"
esp8266:
board: esp01_1m #The compiler "says" that this will always work!
# Enable logging
logger:
level: DEBUG
# Enable Home Assistant API
api:
ota:
- platform: esphome
password: !secret ota_password
wifi:
ssid: !secret wifi_ssid
domain: .peritonlane
ap:
captive_portal:
web_server:
port: 80
text_sensor:
- platform: wifi_info
ip_address:
name: "DS18B20-1 IP Address"
#dallas:
one_wire:
- platform: gpio
pin: GPIO0
- platform: dallas_temp
address: 0x3500000001c3ba28 #ROM code backwards!
name: "DS18B20-1 Temperature"
update_interval: 10s
#The source of "status LED" is: https://community.home-assistant.io/t/status-led-status-led-light-binary-light-light-components/443263/2
#Healthy = 0.2Hz (once every 5sec)
#Warning = 1Hz
#Error = 2Hz
light:
- platform: status_led
#pin: GPIO16 #Marked D0 on D1 Mini board
pin: GPIO2
restore_mode: ALWAYS_ON
internal: true
effects:
- strobe:
name: "Slow Blink" # 0.05s on, 5s off
colors:
- state: true
duration: 5s
- state: false
duration: 1ms
on_turn_on:
- light.turn_on:
effect: "Slow Blink"
This has not changed. Nor, as far as I know has anything else.
Is anyone else seeing this?
Regards, Martin
