I have tried most guides, including the ones from randomnerd. While installing via arduino, I get the Camera init/issue. So, I thought my camera or ZIF/connector was wonky…
When trying to add the camera via espHome, I also get no picture, plus a “[E][esp32_camera:095]: Setup Failed: ERROR” error message. Again,confirming that I seem to have a camera issue… But then I notice that the camera has created an access-point named “ESP32-CAM-MB”. That I can connect to, and by going to 192.168.4.1, I can see the camera controls, plus see stills and a forking video stream… So the camera IS working…
After the espHome-install I can also access the camera controls via the IP address locally on my own networkk
Can someone point me in the right direction of what I might be doing wrong?
nickrout
(Nick Rout)
March 27, 2022, 8:31pm
2
No logs, no yaml = no issue.
Sure. That can be shared. But I would believe that asking a question in general would be possible without:
esphome:
esp32:
board: esp32dev
# board: esp-wrover-kit
framework:
type: arduino
version: latest
substitutions:
# Modify variables based on your settings
hostname: 'BirdyBirdy'
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: "xx"
web_server:
port: 80
wifi:
ssid: !secret wifi_ssid # <-- My primary home SSID
ap:
ssid: "Birdycam Fallback Hotspot"
password: "XX"
captive_portal:
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
vsync_pin: GPIO25
href_pin: GPIO23
pixel_clock_pin: GPIO22
power_down_pin: GPIO32
# Image settings
max_framerate: 5 fps # default: 10 fps, max 60
idle_framerate: 0.2 fps # default: 0.1 fps - framerate for 'picture' in HA dashboard
resolution: 800x600 # default: 640x480 (VGA) - higher res requires more memory
jpeg_quality: 10 # 10 (best) to 63 (worst)
output:
#flashlight
- platform: gpio
pin: GPIO4
#statuslight
- platform: gpio
pin:
number: GPIO33
inverted: True
light:
#flashlight
- platform: binary
output: gpio_4
#statuslight
- platform: binary
output: gpio_33
- platform: wifi_signal
name: $hostname WiFi Signal
update_interval: 60s
- platform: uptime
text_sensor:
- platform: version
name: $hostname ESPHome Version
- platform: wifi_info
ssid:
switch:
- platform: restart
binary_sensor:
- platform: status
log:
[23:32:18][I][app:102]: ESPHome version 2022.3.1 compiled on Mar 27 2022, 23:30:57
[23:32:18][C][wifi:491]: WiFi:
[23:32:18][C][wifi:353]: Local MAC: XX
[23:32:18][C][wifi:354]: SSID: [redacted]
[23:32:18][C][wifi:355]: IP Address: XX
[23:32:18][C][wifi:357]: BSSID: [redacted]
[23:32:18][C][wifi:358]: Hostname: 'birdycam'
[23:32:18][C][wifi:360]: Signal strength: -52 dB ▂▄▆█
[23:32:18][C][wifi:364]: Channel: 1
[23:32:18][C][wifi:365]: Subnet: 255.255.255.0
[23:32:18][C][wifi:366]: Gateway: 192.168.0.1
[23:32:18][C][wifi:367]: DNS1: 192.168.0.1
[23:32:18][C][wifi:368]: DNS2: 0.0.0.0
[23:32:19][C][logger:233]: Logger:
[23:32:19][C][logger:234]: Level: DEBUG
[23:32:19][C][logger:235]: Log Baud Rate: 115200
[23:32:19][C][logger:236]: Hardware UART: UART0
[23:32:19][C][gpio.output:010]: GPIO Binary Output:
[23:32:19][C][gpio.output:011]: Pin: GPIO4
[23:32:19][C][gpio.output:011]: Pin: GPIO33
[23:32:19][C][uptime.sensor:031]: Uptime Sensor 'BirdyBirdy Uptime'
[23:32:19][C][uptime.sensor:031]: State Class: 'total_increasing'
[23:32:19][C][uptime.sensor:031]: Unit of Measurement: 's'
[23:32:19][C][uptime.sensor:031]: Accuracy Decimals: 0
[23:32:19][C][uptime.sensor:031]: Icon: 'mdi:timer-outline'
[23:32:19][C][light:104]: Light 'BirdyBirdy flash'
[23:32:19][C][light:104]: Light 'BirdyBirdy status'
[23:32:19][C][esp32_camera:048]: ESP32 Camera:
[23:32:19][C][esp32_camera:049]: Name: Pippipcam
[23:32:19][C][esp32_camera:050]: Internal: NO
[23:32:19][C][esp32_camera:052]: Data Pins: D0:5 D1:18 D2:19 D3:21 D4:36 D5:39 D6:34 D7:35
[23:32:19][C][esp32_camera:053]: VSYNC Pin: 25
[23:32:19][C][esp32_camera:054]: HREF Pin: 23
[23:32:19][C][esp32_camera:055]: Pixel Clock Pin: 22
[23:32:19][C][esp32_camera:056]: External Clock: Pin:0 Frequency:20000000
[23:32:19][C][esp32_camera:057]: I2C Pins: SDA:26 SCL:27
[23:32:19][C][esp32_camera:058]: Reset Pin: -1
[23:32:19][C][esp32_camera:079]: Resolution: 800x600 (SVGA)
[23:32:19][E][esp32_camera:095]: Setup Failed: ERROR
[23:32:19][C][version.text_sensor:021]: Version Text Sensor 'BirdyBirdy ESPHome Version'
[23:32:19][C][version.text_sensor:021]: Icon: 'mdi:new-box'
[23:32:19][C][restart:022]: Restart Switch 'BirdyBirdy restart'
[23:32:19][C][restart:022]: Icon: 'mdi:restart'
[23:32:19][C][status:034]: Status Binary Sensor 'BirdyBirdy status'
[23:32:19][C][status:034]: Device Class: 'connectivity'
[23:32:19][C][psram:020]: PSRAM:
[23:32:19][C][psram:021]: Available: NO
[23:32:19][C][captive_portal:088]: Captive Portal:
[23:32:19][C][web_server:129]: Web Server:
[23:32:19][C][web_server:130]: Address: birdycam.local:80
[23:32:19][C][mdns:084]: mDNS:
[23:32:19][C][mdns:085]: Hostname: birdycam
[23:32:19][C][ota:085]: Over-The-Air Updates:
[23:32:19][C][ota:086]: Address: birdycam.local:3232
[23:32:19][C][ota:089]: Using Password.
[23:32:19][C][api:138]: API Server:
[23:32:19][C][api:139]: Address: birdycam.local:6053
[23:32:19][C][api:143]: Using noise encryption: NO
[23:32:19][C][wifi_signal.sensor:009]: WiFi Signal 'BirdyBirdy WiFi Signal'
[23:32:19][C][wifi_signal.sensor:009]: Device Class: 'signal_strength'
[23:32:19][C][wifi_signal.sensor:009]: State Class: 'measurement'
[23:32:19][C][wifi_signal.sensor:009]: Unit of Measurement: 'dBm'
[23:32:19][C][wifi_signal.sensor:009]: Accuracy Decimals: 0
[23:32:19][C][wifi_info:011]: WifiInfo SSID 'BirdyBirdy WiFi'
Screenshots of website reached after connecting to the AP named “ESP32-CAM-MB” and going to 192.168.4.1
nickrout
(Nick Rout)
March 28, 2022, 7:23am
5
Those screenshots seem to be the web server installed by the tutorial from the randomnerds tutorial (compare here at about 3:23 ESP32-CAM Video Streaming and Face Recognition with Arduino IDE | Random Nerd Tutorials )
These esp32 camera modules are pretty flaky. Try a lower res like 640x480.
sachinss
(Sac)
March 28, 2022, 10:56am
6
This line in the log seems important:
In the past, this happened to me when the camera cable was not inserted properly in its slot. Try cleaning it with some isopropyl alcohol and inserting it again. You won’t be able to start the camera unless you get rid of this error.
Thats right. I’ve seen those post on several forums. And I have tried to reposition in the ZIF. But as in the first post I can see the image on the Accesspoint the camera is setting up (for some reason). So the camera is working fine…
That’s the funny thing. The webserver/accesspoint is not working when I install the arduino-based reciepie from randomnerd. But when I install the camera component via esphome, it pops up…
PS, I tick “erase board” when uploading in esphome.
btw, I have another cam in the mail… Will try the same with that one.
I managed to resolve this eventually, but I believe I had issues by updating the board wirelessly. So when connecting the dedicated esp32-cam-programmer board, I managed to get it working as a with this code:
esphome:
esp32:
board: esp32cam
# board: esp32dev
# board: m5stack-core-esp32
substitutions:
# Enable logging
logger:
level: DEBUG
api:
reboot_timeout: 0s
web_server:
port: 80
ota:
password: "XX"
wifi:
fast_connect: True
ap:
ssid: "XX"
password: "XX"
time:
- platform: homeassistant
# ESP32-CAM
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
vsync_pin: GPIO25
href_pin: GPIO23
# Image settings
max_framerate: 1 fps
resolution: 1600x1200
jpeg_quality: 20
# contrast: 2
# saturation: 2
output:
#flashlight
- platform: gpio
pin: GPIO4
#statuslight
- platform: gpio
pin:
number: GPIO33
inverted: True
light:
#flashlight
- platform: binary
output: gpio_4
#statuslight
- platform: binary
output: gpio_33
- platform: uptime
text_sensor:
- platform: version
ssid:
switch:
- platform: restart
binary_sensor:
- platform: status
Now everything works and I can re-grow my hair…
Try 10MHz instead of 20!!!
nareddyt
(Teju Nareddy)
November 23, 2022, 4:20am
12
For me, it was because my ESP32cam board could not handle the resolution: 800x600.
ESP32 Camera Component — ESPHome mentions this. I fixed the error by just using the default resolution of 640x480
KoStard
(Ruben Kostandyan)
November 26, 2025, 7:53pm
13
I needed to change from frame_buffer_location: DRAM to frame_buffer_location: PSRAM and reduce to frequency: 10MHz, then it could support higher qualities
