ESP Home will not start since upgrade to 2022.5
I get the following error when starting ESPHome.
Failed to start add-on
Image ghcr.io/esphome/esphome-hassio-amd64:2022.4.0 does not exist for addon_15ef4d2f_esphome
Did you change to using the official repository?
The Community Addons version is no longer available.
Thanks for the reply!
No I have the addon that is listed under ESPHome.
Should I try to uninstall and re -install?
Ok so you have the official repository then.
A reinstall is worth a try.
That did it! I did not un-install, just installed again and it is back with all of my files!
Thanks for the help!!
