Hi, thanks to the home-assistant community, read a lot of threads and I found my issues.
Firstly, I forgot that my relay board is 12VDC and I was powering it thought USB 5VDC so esp-01 whole whole board was working except relays was not switching.
Another issue was that not pressed S2 button. To do this I turned off relay board, removed esp01, press and hold s2 button then turn board on and hold until blue led comes red. Then I powered off the board and put esp01 back and turned on. (there might be the other manual for that but this worked for me).
This is my working config:
substitutions:
# Modify variables based on your settings
hostname: "esprelay-rekuperacia-v2"
devicename: esprelay-rekuperacia-v2
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: !secret wifi_ssid
captive_portal:
# Enable Home Assistant API
api:
password: "XXX"
logger:
baud_rate: 0 #need this to free up UART pins
uart:
baud_rate: 115200
tx_pin: GPIO1
rx_pin: GPIO3
switch:
turn_on_action:
# turn on hvac
- uart.write: [0xA0, 0x04, 0x01, 0xA5]
- delay: 100ms
- lambda: id(rekuperacia_on).publish_state(true);
# turn on heating
- uart.write: [0xA0, 0x01, 0x01, 0xA2]
- delay: 100ms
- lambda: id(rekuperacia_heating).publish_state(true);
turn_off_action:
- uart.write: [0xA0, 0x01, 0x00, 0xA1]
- delay: 100ms
- lambda: id(rekuperacia_heating).publish_state(false);
optimistic: false
turn_on_action:
# turn on hvac
- delay: 100ms
# turn on boost
- uart.write: [0xA0, 0x02, 0x01, 0xA3]
- delay: 100ms
- lambda: id(rekuperacia_boost).publish_state(true);
# turn of mode 2
- uart.write: [0xA0, 0x03, 0x00, 0xA3]
- delay: 100ms
- lambda: id(rekuperacia_mode2).publish_state(false);
turn_off_action:
- uart.write: [0xA0, 0x02, 0x00, 0xA2]
- delay: 100ms
- lambda: id(rekuperacia_boost).publish_state(false);
optimistic: false
name: 'Rekuperacia mode 2'
turn_on_action:
# turn on hvac
- delay: 100ms
# turn on mode 2
- uart.write: [0xA0, 0x03, 0x01, 0xA4]
- delay: 100ms
- lambda: id(rekuperacia_mode2).publish_state(true);
# turn off boost
- delay: 100ms
turn_off_action:
- delay: 100ms
optimistic: false
turn_on_action:
# turn on hvac
- delay: 100ms
turn_off_action:
# turn off heating
- delay: 100ms
# turn off boost
- delay: 100ms
# turn off mode 2
- delay: 100ms
# turn off hvac
- uart.write: [0xA0, 0x04, 0x00, 0xA4]
- delay: 100ms
- lambda: id(rekuperacia_on).publish_state(false);
optimistic: false
- platform: wifi_signal
name: ${devicename} wifi signal
update_interval: 600s
# human readable uptime sensor output to the text sensor above
- platform: uptime
name: ${devicename} Uptime in Seconds
update_interval: 60s
on_raw_value:
then:
- text_sensor.template.publish:
state: !lambda |-
int seconds = round(id(uptime_sensor_secs).raw_state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return (
(days ? String(days) + "d " : "") +
(hours ? String(hours) + "h " : "") +
(minutes ? String(minutes) + "m " : "") +
(String(seconds) + "s")
).c_str();
time:
- platform: homeassistant
# Text sensors with general information.
text_sensor:
# Expose ESPHome version as sensor.
- platform: version
# Expose WiFi information as sensors.
- platform: wifi_info
ip_address:
bssid:
# human readable update text sensor from sensor:uptime
name: Uptime Human Readable
icon: mdi:clock-start
A couple notes:
This is config for 4ch relay, it controls HVAC with preheating, so there are multiple commands for each switch.
I am not using
optimistic: true
becuase it told to home-assistant that state was changed before completed which caused a bug. I used - lambda: id(rekuperacia_on).publish_state(false);
to control state change manually.
Reason why I am sending uart.write instead of switch.turn_on: swichname it is becuase it didn’t worked with lambda publish_state.
Delay between commands. Minimum which I used is 100ms, maybe lower number is possible, theoretically a couple ms should be fine, but I didn’t have time to try different settings. Please let me know what was your minimum.
