ESP32-024 CYD Clone (Small Screen) - Working with Home Assistant
Hi All
My need was to create a small screen that could display the temperature of our hot water at home.
Lots of messing about and finally have a base working version which you can adopt (note the one feed here is numerical and you will need to adjust for text etc)
  1. Create Your Device in Home Assistant ESPHome
First, you need to create a new device in ESPHome within Home Assistant:
  • Go to ESPHome in your Home Assistant interface.
  • Click + NEW DEVICE.
  • Follow the prompts to create a new ESP32 device. You can give it a name like “My Display Device”.
  1. Add the Custom Font File
For your display to work correctly, you need to place the specified font file in the correct location within your Home Assistant configuration.
  • Download Arimo-Regular.ttf: Obtain the Arimo-Regular.ttf font file. You can usually find this font online from open-source font repositories.
  • Place in Home Assistant:
    • Using the File Editor add-on in Home Assistant (if installed): Navigate to /config/esphome/ and create a new folder named fonts. Upload Arimo-Regular.ttf into this fonts folder.
    • Using Samba Share (if configured): Access your Home Assistant configuration share, navigate to the esphome directory, create a fonts folder inside it, and copy Arimo-Regular.ttf into esphome/fonts/.The final path should be config/esphome/fonts/Arimo-Regular.ttf.
  1. Paste Your YAML Configuration and Build the Firmware
Now, it’s time to add your specific configuration and compile the firmware:
  • Once your new device is created in ESPHome, click EDIT on it.
  • Crucially, paste your YAML code after the captive_portal: section in the editor.
i2c:
  - sda: 21
    scl: 22
    scan: true
spi:
  - id: tft
    clk_pin: 14
    mosi_pin: 13
    miso_pin: 12
output:
  - id: backlight_ctrl
    platform: gpio
    pin: 27
    inverted: false
light:
  - platform: binary
    name: "${device_name} Display Backlight"
    output: backlight_ctrl
    restore_mode: ALWAYS_ON
font:
  - file: "fonts/Arimo-Regular.ttf"
time:
  - platform: homeassistant
    entity_id: input_number.hot_water_temperature_helper
    on_value:
      then:
        - logger.log:
            format: "HA Temp Received: %.1f°C"
            args: [id(ha_temp).state]
        - component.update: main_display
# Display Configuration
display:
  - id: main_display
    platform: ili9xxx
    model: TFT 2.4R
    spi_id: tft
    cs_pin:
      number: 15
      ignore_strapping_warning: true
    dc_pin:
      number: 2
    invert_colors: true
    color_palette: 8BIT
    update_interval: 60s # Or 60000ms. This will redraw the screen every minute.
    auto_clear_enabled: true
    transform:
      swap_xy: true
      mirror_x: false
    dimensions:
      height: 320
      width: 240
    lambda: |-
      it.fill(Color::BLACK);
      if (id(ha_temp).has_state()) {
        if (!isnan(id(ha_temp).state)) {
          it.printf(10, 10, id(my_font), "Water: %.1f°C", id(ha_temp).state);
        } else {
          it.printf(10, 10, id(my_font), "Water: --°C");
          ESP_LOGD("DISPLAY", "Sensor state: NaN");
      } else {
        it.printf(10, 10, id(my_font), "Water: N/A");
        ESP_LOGD("DISPLAY", "Sensor has no state");
touchscreen:
  - platform: xpt2046
    cs_pin: 33
    calibration:
      x_min: 280
      x_max: 3860
      y_min: 340
      y_max: 3860
    transform:
      swap_xy: true
      mirror_x: false
      mirror_y: true`
  • SAVE your changes.
  • Click INSTALL on your device in ESPHome.
  • Select “USB” or “Manual Download” (depending on the options presented). If you select “USB”, it will directly proceed to the flashing step using web.esphome.io. If you select “Manual Download”, you’ll be prompted to download the .bin file. The key here is that ESPHome will compile your YAML into a .binfirmware file.
  1. Flash Your Device Using web.esphome.io
Now, flash the firmware onto your ESP32:
  • If you chose “USB” in the previous step, you should already be on web.esphome.io. If you chose “Manual Download”, open your browser and go to https://web.esphome.io/.
  • Connect your ESP32 to your computer via USB.
  • On web.esphome.io, click CONNECT and select the serial port for your ESP32.
  • Then, click INSTALL (or “Upload” if you previously downloaded the .bin file and need to select it). Follow the on-screen instructions to flash your ESP32.
  1. Verify Connection in Home Assistant ESPHome Logs
Once flashed, connect your ESP32 to power and verify its connection:
  • Go back to Home Assistant and navigate to ESPHome.
  • Click LOGS for your device.
  • Crucially, check the logs for messages indicating a successful connection to your Wi-Fi and Home Assistant. Look for phrases like “Connected to Home Assistant.”
  1. Install the Device in Home Assistant Devices
This is a critical step for values to update correctly:
  • If the logs confirm a successful connection, go to Settings > Devices & Services in Home Assistant.
  • You should see a new ESPHome integration discovered. Click CONFIGURE or ADD DEVICE for this integration.
  • Follow the prompts to add your ESP32 device. This action makes the entities defined in your YAML (like the display and backlight) available in Home Assistant.
Important Note on Data Display:
Your YAML uses entity_id: input_number.hot_water_temperature_helper to retrieve data. For your display to show meaningful values, you need to ensure this input_number entity in Home Assistant is being updated with the correct data. If you’re not using a temperature value, adjust the input_number entity and the corresponding display text in your YAML to match your desired data type (e.g., “Humidity: %.1f%%”, “Status: %s”).
Tip for Other Entity Types:
If you need to display or interact with other types of data like text or binary sensor states, the ESPHome lambda syntax for display and on_value for sensor can handle various formats. Don’t hesitate to use AI tools to get hints and examples on how to adapt your YAML for text-based entities (text_sensor) or binary states (binary_sensor) if your project evolves beyond numerical values.
Hope this helps someone not waste days on trying to get this to work
Thanks. It did worked on my esp32-024.
Adding the information, that this display uses rgb:
color_order: rgb
