Esp32-2432s028 Yellow display
Hi
I have problem to get my screen working on this. I have tried alot of diffrent configs.
Its a esp32-2432s028 with dual usb (micro/usb-c).
Anu suggestions?
Looks like a sunton-esp32-2432s028R with a resistive touch screen. Resistive touch doesn’t work that well but this file should get you going.
Or openhasp
Thanks I will try this code and check on yours
Hi everyone thanks for all help. I manage to get it working I just had to add “color_palette: 8BIT” under display section.
Interesting. I have one of these screens and I did not need to add that to get it working.
Can you post your final working configuration?
Yes I just made alot of testing diffrent examples
display:
  - platform: ili9xxx
    # model: tft 2.4
    model: ili9342
    color_palette: 8BIT
    spi_id: tft
    cs_pin: GPIO15
    dc_pin: GPIO2
    rotation: 0
    invert_colors: true
Does this work? That is what works for me
display:
  - id: my_display
    platform: ili9xxx
    model: ILI9341
    spi_id: tft
    cs_pin:
      number: 15
      ignore_strapping_warning: true
    dc_pin:
      number:  2
    invert_colors: false
    update_interval: never
    auto_clear_enabled: false
I will try that
You’ll want to add:
lvgl:
  buffer_size: 25%
It’s not likely to work with the native display lambda functions.
Righ I have that in my config
# sunton-esp32-2432s028R
# Hardware configuration file
esphome:
  min_version: 2025.2.2
esp32:
  board: esp32dev
  framework:
    type: arduino
lvgl:
  buffer_size: 25%
i2c:
  - sda: 27
    scl: 22
# sensor:
#   - platform: adc
#     pin: 34
#     name: "Brightness"
#     update_interval: 60s
# Backlight
output:
  - platform: ledc
    pin: 21
    frequency: 1000hz
  - id: output_red
    platform: ledc
    pin: 4
    inverted: true
  - id: output_green
    platform: ledc
    pin: 16
    inverted: true
  - id: output_blue
    platform: ledc
    pin: 17
    inverted: true
light:
  - platform: monochromatic # Define a monochromatic, dimmable light for the backlight
    output: gpio_backlight_pwm
    name: Display Backlight
    restore_mode: ALWAYS_ON
  - platform: rgb
    red: output_red
    green: output_green
    blue: output_blue
    restore_mode: ALWAYS_OFF
spi:
  - id: tft
    clk_pin: 14
    mosi_pin: 13
    miso_pin:
      number: 12
  - id: touch
    clk_pin: 25
    mosi_pin: 32
    miso_pin: 39
touchscreen:
  - id: main_touchscreen
    platform: xpt2046
    spi_id: touch
    cs_pin: 33
    interrupt_pin: 36
    threshold: 400
    calibration:
      x_min: 280
      x_max: 3860
      y_min: 340
      y_max: 3860
    transform:
      mirror_x: true
    on_touch:
      - lambda: |-
            ESP_LOGI("cal", "x=%d, y=%d, x_raw=%d, y_raw=%0d",
              touch.x,
              touch.y,
              touch.x_raw,
              touch.y_raw
display:
  - id: main_display
    platform: ili9xxx
    model: ILI9341
    spi_id: tft
    cs_pin:
      number: 15
    dc_pin:
      number:  2
