Wonder if someone can offer something to get me in the right direction.
So, I’m trying to connect the ESP32 S3 Dev board BLE to a Duracell Dura Hybrid inverter to mimc the application and once connected I need to read the advertising data and send back to the inverter commands.
How would one connect to the device in question? I do see a number of BLE devices on the advertisements section.
Config
`substitutions:
friendly_name: ESP32 Bluetooth Proxy
packages:
esphome.bluetooth-proxy: github://esphome/bluetooth-proxies/esp32-generic/esp32-generic-s3.yaml@main
esphome:
name_add_mac_suffix: false
friendly_name: ${friendly_name}
api:
encryption:
key: blah blah
wifi:
ssid: !secret wifi_ssid
Enable logging
logger:
ota:
- platform: esphome
password: “”
captive_portal:
esp32_ble_tracker:
scan_parameters:
# We currently use the defaults to ensure Bluetooth
# can co-exist with WiFi In the future we may be able to
# enable the built-in coexistence logic in ESP-IDF
active: true
interval: 1100ms
window: 1100ms
bluetooth_proxy:
active: true
ble_client:
- mac_address: E4:38:19:22:93:C9
Logs
INFO ESPHome 2026.2.1
INFO Reading configuration /config/esphome/esp32-bluetooth-proxy-8965ac.yaml…
WARNING Found and merged multiple configurations for ota platform esphome port(s) [3232]
WARNING BLE components require 4 connection slot(s) but only 3 configured. Please set ‘max_connections: 4’ in the ‘esp32_ble’ component. Components: bluetooth_proxy, bluetooth_proxy, bluetooth_proxy, ble_client
INFO Starting log output from esp32-bluetooth-proxy-8965ac.local using esphome API
INFO Successfully resolved esp32-bluetooth-proxy-8965ac.local in 0.171s
INFO Successfully connected to esp32-bluetooth-proxy-8965ac @ 192.168.0.73 in 0.006s
INFO Successful handshake with esp32-bluetooth-proxy-8965ac @ 192.168.0.73 in 0.175s
[14:45:10.822][I][app:215]: ESPHome version 2026.2.1 compiled on 2026-02-25 12:18:17 +0000
[14:45:10.879][I][app:222]: ESP32 Chip: ESP32-S3 rev0.2, 2 core(s)
[14:45:10.880][C][logger:237]: Logger:
[14:45:10.880][C][logger:237]: Max Level: DEBUG
[14:45:10.880][C][logger:237]: Initial Level: DEBUG
[14:45:10.887][C][logger:244]: Log Baud Rate: 115200
[14:45:10.887][C][logger:244]: Hardware UART: USB_SERIAL_JTAG
[14:45:10.887][C][logger:254]: Task Log Buffer Size: 768 bytes
[14:45:10.887][C][bluetooth_proxy:124]: Bluetooth Proxy:
[14:45:10.887][C][bluetooth_proxy:124]: Active: YES
[14:45:10.887][C][bluetooth_proxy:124]: Connections: 3
[14:45:10.902][C][safe_mode.button:014]: Safe Mode Button ‘Safe Mode Boot’
[14:45:10.902][C][safe_mode.button:157]: Icon: ‘mdi:restart-alert’
[14:45:10.902][C][factory_reset.button:014]: Factory Reset Button ‘Factory reset’
[14:45:10.918][C][factory_reset.button:157]: Icon: ‘mdi:restart-alert’
[14:45:10.919][C][esp32_ble:650]: BLE:
[14:45:10.919][C][esp32_ble:650]: MAC address: 7C:2C:67:89:65:AE
[14:45:10.919][C][esp32_ble:650]: IO Capability: none
[14:45:10.919][C][esp32_ble_tracker:676]: BLE Tracker:
[14:45:10.933][C][esp32_ble_tracker:677]: Scan Duration: 300 s
[14:45:10.933][C][esp32_ble_tracker:677]: Scan Interval: 1100.0 ms
[14:45:10.933][C][esp32_ble_tracker:677]: Scan Window: 1100.0 ms
[14:45:10.933][C][esp32_ble_tracker:677]: Scan Type: ACTIVE
[14:45:10.933][C][esp32_ble_tracker:677]: Continuous Scanning: YES
[14:45:10.933][C][esp32_ble_tracker:685]: Scanner State: RUNNING
[14:45:10.933][C][esp32_ble_tracker:685]: Connecting: 0, discovered: 0, disconnecting: 0
[14:45:10.933][C][bluetooth_proxy.connection:091]: BLE Connection:
[14:45:10.996][C][esp32_ble_client:071]: Address:
[14:45:10.996][C][esp32_ble_client:071]: Auto-Connect: FALSE
[14:45:10.996][C][esp32_ble_client:071]: State: IDLE
[14:45:10.996][C][bluetooth_proxy.connection:091]: BLE Connection:
[14:45:11.006][C][bluetooth_proxy.connection:091]: BLE Connection:
[14:45:11.006][C][esp32_ble_client:071]: Address:
[14:45:11.006][C][esp32_ble_client:071]: Auto-Connect: FALSE
[14:45:11.006][C][esp32_ble_client:071]: State: IDLE
[14:45:11.006][C][ble_client:026]: BLE Client:
[14:45:11.014][C][esp32_ble_client:071]: Address: E4:38:19:22:93:C9
[14:45:11.014][C][esp32_ble_client:071]: Auto-Connect: TRUE
[14:45:11.014][C][esp32_ble_client:071]: State: ESTABLISHED
[14:45:11.014][C][captive_portal:134]: Captive Portal:
[14:45:11.014][C][wifi:1450]: WiFi:
[14:45:11.014][C][wifi:1450]: Local MAC: 7C:2C:67:89:65:AC
[14:45:11.014][C][wifi:1450]: Connected: YES
[14:45:11.026][C][wifi:1202]: IP Address: 192.168.0.73
[14:45:11.026][C][wifi:1213]: SSID: [redacted]
[14:45:11.026][C][wifi:1213]: BSSID: [redacted]
[14:45:11.026][C][wifi:1213]: Hostname: ‘esp32-bluetooth-proxy-8965ac’
[14:45:11.026][C][wifi:1213]: Signal strength: -65 dB ▂▄▆█
[14:45:11.026][C][wifi:1213]: Channel: 9
[14:45:11.026][C][wifi:1213]: Subnet: 255.255.255.0
[14:45:11.026][C][wifi:1213]: Gateway: 192.168.0.1
[14:45:11.026][C][wifi:1213]: DNS1: 192.168.0.1
[14:45:11.026][C][wifi:1213]: DNS2: 0.0.0.0
[14:45:11.026][C][esphome.ota:075]: Over-The-Air updates:
[14:45:11.026][C][esphome.ota:075]: Address: esp32-bluetooth-proxy-8965ac.local:3232
[14:45:11.026][C][esphome.ota:075]: Version: 2
[14:45:11.096][C][esphome.ota:082]: Password configured
[14:45:11.096][C][safe_mode:022]: Safe Mode:
[14:45:11.096][C][safe_mode:022]: Successful after: 60s
[14:45:11.096][C][safe_mode:022]: Invoke after: 10 attempts
[14:45:11.096][C][safe_mode:022]: Duration: 300s
[14:45:11.096][C][safe_mode:039]: Bootloader rollback: supported
[14:45:11.117][C][web_server.ota:238]: Web Server OTA
[14:45:11.117][C][api:237]: Server:
[14:45:11.117][C][api:237]: Address: esp32-bluetooth-proxy-8965ac.local:6053
[14:45:11.117][C][api:237]: Listen backlog: 4
[14:45:11.117][C][api:237]: Max connections: 8
[14:45:11.117][C][api:244]: Noise encryption: YES
[14:45:11.131][C][mdns:177]: mDNS:
[14:45:11.131][C][mdns:177]: Hostname: esp32-bluetooth-proxy-8965ac
[14:47:20.210][D][esp32_ble_tracker:815]: Scan complete, set scanner state to IDLE.
[14:47:20.216][D][esp32_ble_tracker:240]: Starting scan, set scanner state to STARTING.
