ESP32 BLE Scanning 8 devices
I just got my battery details in home assistant using the BMS BLE connection and an ESP32 with ESP home. I know in the docs it says the connections are limited to 3-4 because of memory limitations. I seem to be limited to one connection, even a second one made the ESP32 crash every few seconds. I am wondering if it might be possible to offset each scan and be able to read all 8 with one ESP32.
I only need updates every minuet at the most, could I just rotate through one battery update at a time in a loop?
This is the setup for each battery in the primary YAML
packages:
  jk-bms1: !include
    file: kv-bms.yaml
    vars:
      device: '01'
      mac_address: 30:45:11:FB:0A:52
      protocol_version: JK02_32S
      short_name: battery1
  jk-bms2: !include
    file: kv-bms.yaml
    vars:
      device: '02'
      mac_address: 50:33:8B:12:69:42
      short_name: battery2
And this is the kv-bms.yaml
ble_client:
  - mac_address: ${mac_address}
    on_connect:
      then:
        - lambda: |-
            ESP_LOGD("${short_name} ${mac_address}", "Connected to BLE device");
    on_disconnect:
      then:
        - lambda: |-
            ESP_LOGD("${short_name} ${mac_address}", "Disconnected from BLE device");
            if (id(ble_client_switch${device}).state) {
              id(ble_client_switch${device}).turn_off();
              id(ble_client_switch${device}).turn_on();
kilovault_bms_ble:
  - ble_client_id: client${device}
    update_interval: 10s
  - platform: total_daily_energy
    name: "${short_name} Total Daily Energy battery in"
    power_id: charging_power${device}
    filters:
        - multiply: 0.001
    unit_of_measurement: kWh
    device_class: energy
    name: "${short_name} Total Daily Energy battery out"
    power_id: discharging_power${device}
    filters:
        - multiply: 0.001
  - platform: kilovault_bms_ble
    kilovault_bms_ble_id: bms${device}
    voltage:
      filters:
        - throttle_average: ${throttle_time}
        - filter_out: nan
    current:
      filters:
        - filter_out: nan
    power:
      filters:
        - filter_out: nan
    charging_power:
      name: "${short_name} charging power"
      filters:
        - filter_out: nan
    discharging_power:
      name: "${short_name} discharging power"
      filters:
        - filter_out: nan
    cycles:
      filters:
        - throttle: 60s
    state_of_charge:
      name: "${short_name} state of charge"
      filters:
        - throttle: 60s
    total_capacity:
      name: "${short_name} total capacity"
      filters:
        - throttle: 60s
    current_capacity:
      name: "${short_name} current capacity"
      filters:
        - throttle: 60s
    status:
      filters:
        - throttle: 60s
        - lambda: |-
            ESP_LOGD("${short_name} ${mac_address}", "Status changed to 0");
            if (x == 0) {
            return x;
    afestatus:
      name: "${short_name} afe status"
      filters:
        - throttle: 60s
    min_cell_voltage:
      name: "${short_name} min cell voltage"
      filters:
        - throttle: 60s
    max_cell_voltage:
      name: "${short_name} max cell voltage"
      filters:
        - throttle: 60s
    min_voltage_cell:
      name: "${short_name} min voltage cell"
      filters:
        - throttle: 60s
    max_voltage_cell:
      name: "${short_name} max voltage cell"
      filters:
        - throttle: 60s
    delta_cell_voltage:
      name: "${short_name} delta cell voltage"
      filters:
        - throttle: 60s
    temperature:
      name: "${short_name} temperature"
      filters:
        - throttle: 60s
    cell_voltage_1:
      name: "${short_name} cell voltage 1"
      filters:
        - filter_out: nan
    cell_voltage_2:
      name: "${short_name} cell voltage 2"
      filters:
        - filter_out: nan
    cell_voltage_3:
      name: "${short_name} cell voltage 3"
      filters:
        - filter_out: nan
    cell_voltage_4:
      name: "${short_name} cell voltage 4"
      filters:
        - filter_out: nan
switch:
  - platform: ble_client
    name: "${short_name} enable bluetooth connection"
text_sensor:
    battery_mac:
      name: "${short_name} battery MAC"
    message:
