[esp32_ble_server] Send advertisements with data
For some weeks I’m playing around with BLE and got it working sort of. The only thing I dislike is that it needs to connect to the ESPHome BLE server in order to get updates. In the process added some PRs to fix/improve the ESPHome documentation.
The disadvantage is that mostly only one BLE client can be connected. At least that is my experience. Might be because
I would like to have ESPHome advertise the values in the advertisement packets like Xiaomi temperature sensors do. I thought if I did ble_server.characteristic.notify it would automatically advertise this, but it looks like that is not the case.
Can it be done? Does it need custom lambda code?
This is my current code.
Server (sends a random int every second):
esp32_ble_server:
  services:
    - uuid: 0f502a49-9c9b-4788-b86e-5248e50d14b3
      advertise: true
      characteristics:
        - uuid: cf7e7a4b-4f74-4cbe-9d41-bfa40f846c5a
          description: "BLE random test int"
          broadcast: true
          read: true
          notify: true
          value:
            type: int32_t
            data: 1
interval:
  - interval: 1sec
    then:
      - ble_server.characteristic.set_value:
          value: !lambda
            float my_float_value = rand() % 2000;
            std::string my_string = str_sprintf("%.0f", my_float_value);
            std::vector<unsigned char> byte_vector(my_string.begin(), my_string.end());
            return byte_vector;
      - ble_server.characteristic.notify:
Client (logs advertisements):
esp32_ble_tracker:
  scan_parameters:
    continuous: false
  on_ble_advertise:
    - mac_address: XX:XX:XX:XX:XX:XX
      then:
        - lambda: |-
            ESP_LOGD("ble_adv", "New BLE device");
            ESP_LOGD("ble_adv", "  address: %s", x.address_str().c_str());
            ESP_LOGD("ble_adv", "  name: %s", x.get_name().c_str());
            ESP_LOGD("ble_adv", "  Advertised service UUIDs:");
            for (auto uuid : x.get_service_uuids()) {
                ESP_LOGD("ble_adv", "    - %s", uuid.to_string().c_str());
            ESP_LOGD("ble_adv", "  Advertised service data:");
            for (auto data : x.get_service_datas()) {
                ESP_LOGD("ble_adv", "    - %s: (length %i)", data.uuid.to_string().c_str(), data.data.size());
                ESP_LOGD("ble_adv", "    - %s:", format_hex_pretty(data.data).c_str());
            ESP_LOGD("ble_adv", "  Advertised manufacturer data:");
            for (auto data : x.get_manufacturer_datas()) {
  on_ble_service_data_advertise:
      service_uuid: 0f502a49-9c9b-4788-b86e-5248e50d14b3
      then:
        - lambda: |-
            ESP_LOGD("ble_service_data_advertise", "    - %s", x);
The only thing I’m getting is:
[17:08:14][D][ble_adv:068]: New BLE device
[17:08:14][D][ble_adv:069]:   address: XX:XX:XX:XX:XX:XX
[17:08:14][D][ble_adv:070]:   name: esp32-ble-server
[17:08:14][D][ble_adv:072]:   Advertised service UUIDs:
[17:08:14][D][ble_adv:074]:     - 0F502A49-9C9B-4788-B86E-5248E50D14B3
[17:08:14][D][ble_adv:077]:   Advertised service data:
[17:08:14][D][ble_adv:083]:   Advertised manufacturer data:
Without any Advertised service data… Also tried with using capitals for service_uuid: 0f502a49-9c9b-4788-b86e-5248e50d14b3
Perhaps try with manufacturer’s data, that should be simpler. I don’t quite remember many details, since I did it a long time ago but I used manufacturer’s data to send time+distance from my treadmill to Home Assistant, and it worked well.
I can’t give you ESPhome code for sending end, as I used Arduino for that. But the code is very simple: create a buffer with made-up manufacturer’s ID + any data you want.
Arduino
char buff[6] = {
  // manufacturer's ID (e.g. Apple = 0x4C00)
  (unsigned byte)0xF0, (unsigned byte)0xFF,
  // 2 bytes, time
  (unsigned byte)0, (unsigned byte)0,
  // 2 bytes, distance
BLEAdvertisementData oAdvertisementData = BLEAdvertisementData();
oAdvertisementData.setManufacturerData(std::string(buff, 6));
pAdvertising->setAdvertisementData(oAdvertisementData);
Code for receiving end (ESPHome)
esp32_ble_tracker:
  on_ble_manufacturer_data_advertise:
    - mac_address: 4c:eb:d6:43:5d:82
      manufacturer_id: FFF0
      then:
        - lambda: |-
            uint16_t time = x[0] + (x[1] << 8);
            uint16_t dist = x[2] + (x[3] << 8);
            uint16_t oldTime = 0;
            uint16_t oldDist = 0;
            if (id(ble_xt285_helper_time_sensor).has_state() && !isnan(id(ble_xt285_helper_time_sensor).state))
              oldTime = id(ble_xt285_helper_time_sensor).state;
            if (id(ble_xt285_helper_distance_sensor).has_state() && !isnan(id(ble_xt285_helper_distance_sensor).state))
              oldDist = id(ble_xt285_helper_distance_sensor).state;
            if (time != oldTime || dist != oldDist) {
              id(ble_xt285_helper_time_sensor).publish_state(time);
              id(ble_xt285_helper_distance_sensor).publish_state(dist);
    name: "BLE XT285 time"
    accuracy_decimals: 0
    name: "BLE XT285 distance"
Thanks @slimak
Yesterday I was searching for the code I found, and now I’ve found it again. It’s the equivalent of what you are doing in Arduino code, but then in ESPHome yaml/lambda.
And a couple of comments earlier something that might work with a real advertisement.
I’ll try to see if the advertisement part works, if not there is only the misusing of the manufacturers ‘field’ until.
Also I don’t understand the broadcast property of a characteristic, and if it’s linked in any way with advertise
Hmm, I see that ashald added a commit on a copy of esphome-docs for esp32_ble, but it isn’t on the real repo.
esphome-docs/components/esp32_ble.rst at 42fe5663127f9233d157eb300d9d30af030e71e8 · ashald/esphome-docs
Related forum post, but is also based on manufacturer data/field:
Is BLE in itself uncapable of sending ‘random’ data, I think not because Xiaomi thermometers sending it. What I want looks like BTHome, but then in ESPHome yaml code.
Here another thing, in Arduino, not sure how it sends it:
Demonstrate BLE broadcast for connectionless data transfer
And I see that the notify does not have any effect if there are no clients connected:
Received more info from @jesserockz (thanks!), and would like to see ESPHome using the BTHome standard, that would be great. And I might just have an example of it at the bottom :innocent:
There’s advertising_set_manufacturer_data and advertising_set_service_data in the documentation.
ESPHome: esphome::esp32_ble::ESP32BLE Class Reference
And another example using manufacturer data:
And… one which is using this advertising_set_service_data :eyes::eyes::eyes::
https://www.reddit.com/r/Esphome/comments/1gimjed/reading_bluetooth_power_pedals/
ESPHOME BTHome
So. next steps (for me), find out if advertising_set_service_data works.
