I’m using an Adafruit QT Py ESP32-C3 WiFi Dev Board, I’m trying to control a pwm fan with this board. I can install the yaml fine, the device shows up as online in esphome. However if I click view logs I get this error. WARNING Can't connect to ESPHome API for v44.local: Error connecting to ('192.168.2.169', 6053): [Errno 111] Connect call failed ('192.168.2.169', 6053)
. If I try to connect the board to Home assistant in the integrations tab I get this error. Can't connect to ESP. Please make sure your YAML file contains an 'api:' line.
Here is my yaml.
esphome:
platformio_options:
board_build.f_flash: 40000000L
board_build.flash_mode: dio
board_build.flash_size: 4MB
esp32:
# At some point the actual board might be supported.
# board: adafruit_qt_py_esp32-c3
board: esp32-c3-devkitm-1
framework:
type: esp-idf
variant: ESP32C3
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "key"
password: "153"
port: "6053"
ota:
password: "password"
wifi:
ssid: !secret wifi_ssid
# Enable fallback hotspot in case wifi connection fails
ap:
ssid: "V44 Fallback Hotspot"
output:
# Wire this pin (4) into the PWM pin of your 12v fan
# ledc is the name of the pwm output system on an esp32
- platform: ledc
pin: 4
# 25KHz is standard PC fan frequency, minimises buzzing
frequency: "25000 Hz"
# my fans stop working below 13% powerful.
# also they're powerful and loud, cap their max speed to 80%
min_power: 0%
max_power: 100%
# Good for debugging, you can manually set the fan speed.
fan:
- platform: speed
output: noctua_fan_speed
name: "Noctua Fan Speed"
- platform: pulse_counter
pin: 3
update_interval: 2.5s
filters:
- multiply: 0.5 # 2 pulses per revolution
