Why does ESPHome say
HARDWARE: ESP32C3 160MHz, 320KB RAM, 4MB Flash
and then
Flash: [====== ] 58.5% (used 1073158 bytes from 1835008 bytes)
In other words, despite 4 MB Flash it claims it can only use shy of 2 MB. Why is that?
and then
You can not update a running system, so the flash is divided in two partitions.
The running system can then update the system in the dormant partition and when it is down the bootloader can reboot to the dormant system.
