Thanks, full uninstall and reinstall fixed it
Anybody getting boot loop recently? I have not changed my code, seems to have happened at some point after ESPHome update. I’ve been reading something about version 2.0.14 being the last one working:
esp32:
board: esp32-c3-devkitm-1
framework:
type: arduino
version: 2.0.14
but that doesn’t work for me, all kinds of issues compiling it.
My suggestion is to check out my updated code - I’ve gone over to
framework:
type: esp-idf
version: recommended
as well as LVGL and - painful as converting over was - not looking back. Most of my stability issues were due to running out of memory, and migrating over to esp-idf has freed up a noticeable amount of memory making them more responsive. I do have one device that reboots every now and then, but as I have a number of them and the one has issues I think that is a hardware fault.
Thanks for the code, I got the device back to life now. Using lvgl now. Also the screen seems to be more responsive. I was using some early touchscreen and display platforms before. I was about to throw it away, but it’s usable again. I might still be tempted to get Waveshare ESP32-C6 1.47inch.
I’m getting an error suggesting the display is not initialized properly. Copilot says in such cases LVGL might still work, and it does, I can draw in LVGL even with that error still there.
But when not using LVGL the display is just covered with random dots and the display initialization error is also shown in logs.
I already tried data_rate: 4MHz and update_interval: 1s
substitutions:
screenstart: ALWAYS_ON
#GPIO pins for the LCD screen
repin: GPIO1
dcpin: GPIO2
bkpin: GPIO3
clpin: GPIO6
mopin: GPIO7
cspin: GPIO10
# GPIO pins for the touch screen
sdapin: GPIO4
sclpin: GPIO5
intpin: GPIO8
display:
- platform: ili9xxx
model: GC9A01A
invert_colors: true
reset_pin: $repin
cs_pin: $cspin
dc_pin:
number: $dcpin
ignore_strapping_warning: true
update_interval: 200ms
pages:
- id: page1
lambda: |-
it.image(0, 00, id(bathroom2));
spi:
mosi_pin: $mopin
clk_pin: $clpin
miso_pin: GPIO8 # free pin, not connected
i2c:
sda: $sdapin
scl: $sclpin
esp32:
framework:
type: esp-idf
[15:10:09.378][C][ili9xxx:089]: ili9xxx
[15:10:09.378][C][ili9xxx:089]: Rotations: 0 °
[15:10:09.378][C][ili9xxx:089]: Dimensions: 240px x 240px
[15:10:09.378][C][ili9xxx:090]: Width Offset: 0
[15:10:09.378][C][ili9xxx:090]: Height Offset: 0
[15:10:09.380][C][ili9xxx:099]: Color mode: 16bit
[15:10:09.383][C][ili9xxx:108]: Data rate: 8MHz
[15:10:09.385][C][ili9xxx:111]: CS Pin: GPIO10
[15:10:09.388][C][ili9xxx:112]: DC Pin: GPIO2
[15:10:09.391][C][ili9xxx:114]: Color order: BGR
[15:10:09.391][C][ili9xxx:114]: Swap_xy: NO
[15:10:09.391][C][ili9xxx:114]: Mirror_x: YES
[15:10:09.391][C][ili9xxx:114]: Mirror_y: NO
[15:10:09.391][C][ili9xxx:114]: Invert colors: YES
[15:10:09.398][C][ili9xxx:124]: => Failed to init Memory: YES!
[15:10:09.398][C][ili9xxx:362]: Update Interval: 1.0s
[15:10:09.399][E][component:154]: display is marked FAILED: unspecified
[15:10:09.452][C][light:088]: Light 'Display Backlight'
[15:10:09.454][C][light:091]: Default Transition Length: 1.0s
[15:10:09.454][C][light:091]: Gamma Correct: 2.80
Hmmmm… AI is a handy tool, and in general is getting better, but can still be misleading. First thing I’d do would be to do a ‘clean build files’ and recompile just in case. If the error is still there then can investigate further! ![]()
[FWIW I just recompiled my code under esphome 2025.10.5 and HA 2025.11.2, and no errors…]
Use the mipi_spi driver instead of ili9xxx, it will cope better with limited memory as it can use a partial buffer.
Thanks - that fixed it.
First I replaced ili9xxx with mipi_spi with no other changes and LVGL still worked, but no more memory initialization error.
Then I replaced LVGL with Display Lambda to show a picture and that also worked.
Did you get this working?
I am looking to do something similar using Music Assistant.
If your willing to share your code that would be amazing.
As an aside, FWIW I think this has a lot of promise to help generate a decent looking display:
substitutions:
friendly_name: Round Display
screensaver: 30s
esphome:
friendly_name: $friendly_name
esp32:
framework:
type: arduino
logger:
level: INFO
baud_rate: 0
api:
ota:
- platform: esphome
wifi:
ssid: "123"
password: "123123123"
ap:
ssid: "RDisplay Fallback Hotspot"
captive_portal:
web_server:
version: 3
local: True
log: False
time:
- platform: sntp
timezone: "Europe/Moscow"
servers:
- time.apple.com
- time.google.com
- 1.pool.ntp.org
globals:
- id: is_day
type: bool
restore_value: false
initial_value: 'true'
- id: touch_start_x
type: int
initial_value: '0'
- id: touch_start_y
type: int
initial_value: '0'
- id: touch_end_x
type: int
initial_value: '0'
- id: touch_end_y
type: int
initial_value: '0'
- id: touch_start_time
type: unsigned long
initial_value: '0'
- platform: scd4x
update_interval: 20s
co2:
temperature:
name: "SCD41 Temperature"
humidity:
name: "SCD41 Humidity"
- platform: bh1750
name: "BH1750 Illuminance"
address: 0x23
- platform: bmp085
temperature:
name: "BMP180 Temperature"
pressure:
name: "BMP180 Pressure"
- platform: htu21d
model: htu21d
temperature:
name: "HTU21D Temperature"
humidity:
name: "HTU21D Humidity"
spi:
mosi_pin: GPIO7
clk_pin: GPIO6
i2c:
sda: GPIO20
scl: GPIO21
frequency: 100kHz
scan: true
# Using native CST816 touchscreen platform
touchscreen:
- platform: cst816
address: 0x15
reset_pin: GPIO8
skip_probe: true
i2c_id: touchscreen_i2c
transform:
mirror_x: false
mirror_y: false
swap_xy: false
on_touch:
then:
- lambda: |-
ESP_LOGI("TOUCH", "=== TOUCH x=%d, y=%d ===", touch.x, touch.y);
id(touch_start_x) = touch.x;
id(touch_start_y) = touch.y;
id(touch_end_x) = touch.x;
id(touch_end_y) = touch.y;
id(touch_start_time) = millis();
- script.execute: screentime
on_release:
then:
- lambda: |-
ESP_LOGI("TOUCH", "=== RELEASE ===");
unsigned long touch_duration = millis() - id(touch_start_time);
int delta_x = id(touch_end_x) - id(touch_start_x);
int delta_y = id(touch_end_y) - id(touch_start_y);
int abs_delta_x = abs(delta_x);
int abs_delta_y = abs(delta_y);
ESP_LOGI("TOUCH", "Duration=%lu ms, delta_x=%d, delta_y=%d",
touch_duration, delta_x, delta_y);
// CST816 в polling mode генерирует только одно событие touch
// Используем ДЛИТЕЛЬНОСТЬ касания и ПОЛОЖЕНИЕ для определения жестов:
// - Касание в верхней части экрана (y < 60) = SWIPE UP
// - Касание в нижней части (y > 180) = SWIPE DOWN
// - Касание слева (x < 60) = SWIPE LEFT
// - Касание справа (x > 180) = SWIPE RIGHT
// - В центре экрана - клик или долгое нажатие
int touch_x = id(touch_start_x);
int touch_y = id(touch_start_y);
if (touch_duration > 500) {
// Длинное нажатие
ESP_LOGI("TOUCH", "Gesture: LONG PRESS");
id(my_touch_screen).publish_state("LONG PRESS");
} else if (touch_y < 60) {
// Верхняя часть экрана
ESP_LOGI("TOUCH", "Gesture: SWIPE UP (top area)");
id(my_touch_screen).publish_state("SWIPE UP");
} else if (touch_y > 180) {
// Нижняя часть экрана
ESP_LOGI("TOUCH", "Gesture: SWIPE DOWN (bottom area)");
id(my_touch_screen).publish_state("SWIPE DOWN");
} else if (touch_x < 60) {
// Левая часть экрана
ESP_LOGI("TOUCH", "Gesture: SWIPE LEFT (left area)");
id(my_touch_screen).publish_state("SWIPE LEFT");
} else if (touch_x > 180) {
// Правая часть экрана
ESP_LOGI("TOUCH", "Gesture: SWIPE RIGHT (right area)");
id(my_touch_screen).publish_state("SWIPE RIGHT");
} else {
// Центр экрана - короткое нажатие
ESP_LOGI("TOUCH", "Gesture: SINGLE CLICK (center)");
id(my_touch_screen).publish_state("SINGLE CLICK");
# скрипт управления подсветкой
script:
- id: screentime
mode: restart
then:
- light.control:
brightness: 100%
- delay: $screensaver
- if:
condition:
lambda: 'return id(is_day);'
then:
- light.control:
brightness: 100%
else:
- light.control:
brightness: 20%
text_sensor:
internal: true
on_value:
then:
- if:
condition:
text_sensor.state:
state: 'SINGLE CLICK'
then:
- logger.log: "Single click detected"
- if:
condition:
text_sensor.state:
state: 'SWIPE RIGHT'
then:
- display.page.show_next: watchface
- component.update: watchface
- logger.log: "Swiped right, next page"
- if:
condition:
text_sensor.state:
state: 'SWIPE LEFT'
then:
- display.page.show_previous: watchface
- delay: 0.5s
- logger.log: "Swiped left, previous page"
- if:
condition:
and:
- text_sensor.state:
state: 'LONG PRESS'
- display.is_displaying_page: page2
then:
- logger.log: "Long press on page2"
- display.page.show: page2
output:
- platform: ledc
pin: GPIO3
frequency: 1000Hz
light:
- platform: monochromatic
output: gpio_3_backlight_pwm
name: "Display Backlight"
restore_mode: RESTORE_DEFAULT_ON
font:
- file: "gfonts://Roboto"
- file: "gfonts://Material Design Icons"
glyphs: [
"\U000F0E0E", # mdi:air-filter (CO2)
"\U000F0E02", # mdi:thermometer (температура)
"\U000F058E", # mdi:water-percent (влажность)
"\U000F0F55", # mdi:gauge (давление)
"\U000F0335", # mdi:brightness-6 (освещенность)
"\U000F0954" # mdi:clock-outline (время)
glyphs: [
color:
- id: my_red
hex: FF0000
- id: my_green
hex: 008000
- id: my_blue
hex: 0000FF
- id: my_yellow
hex: FFFF00
- id: my_cyan
hex: 00FFFF
- id: my_white
hex: FFFFFF
display:
- platform: ili9xxx
invert_colors: true
model: GC9A01A
reset_pin: GPIO1
cs_pin: GPIO10
dc_pin:
number: GPIO2
update_interval: 1s
pages:
- id: page1
lambda: |-
// CO2 с иконкой
it.printf(60, 65, id(icon_font_24), id(my_yellow), TextAlign::CENTER, "\U000F0E0E");
it.printf(180, 65, id(font_32), id(my_yellow), TextAlign::CENTER, "%.0f ppm", id(scd41_co2).state);
// Время с иконкой
it.printf(60, 120, id(icon_font_24), id(my_yellow), TextAlign::CENTER, "\U000F0954");
it.strftime(180, 120, id(font_64), TextAlign::CENTER, "%H:%M:%S", id(esptime).now());
// Температура с иконкой
it.printf(60, 170, id(icon_font_24), id(my_yellow), TextAlign::CENTER, "\U000F0E02");
it.printf(180, 170, id(font_32), id(my_yellow), TextAlign::CENTER, "%.1f°C", id(scd41_temp).state);
// Влажность с иконкой
it.printf(60, 205, id(icon_font_24), id(my_yellow), TextAlign::CENTER, "\U000F058E");
it.printf(180, 205, id(font_32), id(my_yellow), TextAlign::CENTER, "%.1f%%", id(scd41_hum).state);
it.circle(120, 120, 119, id(my_yellow));
- id: page2
lambda: |-
// CO2 с иконкой
it.printf(60, 65, id(icon_font_24), id(my_red), TextAlign::CENTER, "\U000F0E0E");
it.printf(180, 65, id(font_32), id(my_red), TextAlign::CENTER, "%.0f ppm", id(scd41_co2).state);
// Время с иконкой
it.printf(60, 120, id(icon_font_24), id(my_red), TextAlign::CENTER, "\U000F0954");
it.strftime(180, 120, id(font_32), TextAlign::CENTER, "%H:%M:%S", id(esptime).now());
// Температура HTU21D с иконкой
it.printf(60, 170, id(icon_font_24), id(my_red), TextAlign::CENTER, "\U000F0E02");
it.printf(180, 170, id(font_32), id(my_red), TextAlign::CENTER, "%.1f°C", id(htu21d_temp).state);
// Влажность HTU21D с иконкой
it.printf(60, 205, id(icon_font_24), id(my_red), TextAlign::CENTER, "\U000F058E");
it.printf(180, 205, id(font_32), id(my_red), TextAlign::CENTER, "%.1f%%", id(htu21d_hum).state);
it.circle(120, 120, 119, id(my_red));
- id: page3
lambda: |-
// Заголовок
it.printf(120, 15, id(font_20), id(my_cyan), TextAlign::CENTER, "ALL SENSORS");
// SCD41 данные с иконками
it.printf(20, 40, id(icon_font_16), id(my_white), TextAlign::CENTER, "\U000F0E0E");
it.printf(50, 40, id(font_16), id(my_white), TextAlign::LEFT, "CO2: %.0f ppm", id(scd41_co2).state);
it.printf(20, 58, id(icon_font_16), id(my_white), TextAlign::CENTER, "\U000F0E02");
it.printf(50, 58, id(font_16), id(my_white), TextAlign::LEFT, "T: %.1f°C", id(scd41_temp).state);
it.printf(140, 58, id(icon_font_16), id(my_white), TextAlign::CENTER, "\U000F058E");
it.printf(170, 58, id(font_16), id(my_white), TextAlign::LEFT, "H: %.1f%%", id(scd41_hum).state);
// HTU21D данные с иконками
it.printf(20, 85, id(icon_font_16), id(my_green), TextAlign::CENTER, "\U000F0E02");
it.printf(50, 85, id(font_16), id(my_green), TextAlign::LEFT, "HTU T: %.1f°C", id(htu21d_temp).state);
it.printf(20, 103, id(icon_font_16), id(my_green), TextAlign::CENTER, "\U000F058E");
it.printf(50, 103, id(font_16), id(my_green), TextAlign::LEFT, "HTU H: %.1f%%", id(htu21d_hum).state);
// BMP180 данные с иконками
it.printf(20, 130, id(icon_font_16), id(my_yellow), TextAlign::CENTER, "\U000F0E02");
it.printf(50, 130, id(font_16), id(my_yellow), TextAlign::LEFT, "BMP T: %.1f°C", id(bmp180_temp).state);
it.printf(20, 148, id(icon_font_16), id(my_yellow), TextAlign::CENTER, "\U000F0F55");
it.printf(50, 148, id(font_16), id(my_yellow), TextAlign::LEFT, "P: %.0f hPa", id(bmp180_pres).state);
it.printf(20, 175, id(icon_font_16), id(my_blue), TextAlign::CENTER, "\U000F0335");
it.printf(50, 175, id(font_16), id(my_blue), TextAlign::LEFT, "Light: %.0f lx", id(bh1750_lux).state);
// Время с иконкой
it.printf(80, 210, id(icon_font_16), id(my_cyan), TextAlign::CENTER, "\U000F0954");
it.strftime(160, 210, id(font_20), id(my_cyan), TextAlign::CENTER, "%H:%M:%S", id(esptime).now());
// Рамка
it.circle(120, 120, 119, id(my_cyan));
sun:
latitude: 10.00
longitude: 20.00
on_sunrise:
- then:
- globals.set:
value: 'true'
- light.control:
brightness: 100%
- logger.log: "Sunrise: brightness set to 100%"
on_sunset:
- elevation: -1
then:
- globals.set:
value: 'false'
- light.control:
brightness: 20%
- logger.log: "Sunset: brightness set to 20%"
I spent the whole evening trying to get the display to work on the new version of esphome %)
Been trying to get a bluetooth proxy working and a display… really struggling, though i cant see any problems with my config? can anyone else
substitutions:
repin: GPIO1
dcpin: GPIO2
# Note - you may see an error on compilation "WARNING GPIO2 is a Strapping PIN and should be avoided" - ignore this as you have no choice
# This error message may be removed via the "ignore_strapping_warning" option for the screen driver
bkpin: GPIO3
clpin: GPIO6
mopin: GPIO7
cspin: GPIO10
sdapin: GPIO4
sclpin: GPIO5
intpin: GPIO8
esphome:
friendly_name: ESPHome Web e90f20
esp32:
framework:
type: esp-idf
sdkconfig_options:
# CRITICAL: Fix for C3 Memory crashes with Bluetooth + Display
CONFIG_BT_NIMBLE_MEM_ALLOC_MODE_EXTERNAL: n
CONFIG_BT_NIMBLE_MAX_CONNECTIONS: "2"
CONFIG_ESP32C3_REV_MIN_3: "y"
globals:
- id: last_device_name
type: std::string
initial_value: '"Scanning..." '
# Enable logging
# Change to avoid "Components should block for at most 20-30ms" warning messages in the log - an issue since 2023.7.0
# Not really a breaking change - it's an issue I suspect due to the device being slow and this error previously
# simply not being reported
logger:
level: DEBUG #makes uart stream available in esphome logstream
logs:
component: ERROR
#Turn off UART logging over RX/TX
baud_rate: 0
#uart:
# rx_pin: GPIO20
# tx_pin: GPIO21
# baud_rate: 9600
# id: uart_bus
# Enable Home Assistant API
api:
encryption:
key: !secret api_key
ota:
- platform: esphome
password: !secret ota_password
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esphome-Web-E90F20"
password: ""
# Optimization: Move BLE settings to the 2026-standard component
esp32_ble:
max_connections: 2
bluetooth_proxy:
active: true
esp32_ble_tracker:
scan_parameters:
interval: 1100ms
window: 1100ms
active: true
on_ble_advertise:
- then:
- lambda: |-
if (x.get_name().length() > 0) {
id(last_device_name) = x.get_name();
spi:
mosi_pin: $mopin
clk_pin: $clpin
i2c:
sda: $sdapin
scl: $sclpin
font:
- file: 'fonts/GoogleSans-Medium.ttf'
# Existing Display Fix: Use 8-bit color to save 50% RAM
display:
- platform: ili9xxx
model: GC9A01A
color_palette: 8BIT
invert_colors: true
reset_pin: $repin
cs_pin: $cspin
dc_pin:
number: $dcpin
update_interval: 1s
lambda: |-
// Use your defined fonts from your original YAML
it.print(120, 40, id(font_16), TextAlign::CENTER, "BT Proxy Active");
it.line(40, 60, 200, 60);
it.printf(120, 100, id(font_16), TextAlign::CENTER, "Last Found:");
it.printf(120, 140, id(font_32), TextAlign::CENTER, "%s", id(last_device_name).c_str());
# ... (Keep your wifi, api, ota, and touch components exactly as they were)
As you’re setting up bluetooth, make sure that the first time you set it up that you do it via a serial cable - otherwise the partitions won’t be created properly and could lead to weird issues. Otherwise, or just to be safe, add into the esp32: section
partitions: "esp_part.csv"
and create a text file called “esp_part.csv” in cour config directory with the following in it:
padding, data, undefined, , 0x4000,
phy_init, data, phy, , 0x1000,
otadata, data, ota, , 0x2000,
app0, app, ota_0, , 0x1C0000,
app1, app, ota_1, , 0x1C0000,
nvs, data, nvs, , 0x6D000,
Separately, my hopes and prayers are with you.
The bluetooth proxy stuff takes up a lot of memory to work reliably, and the device does not have a lot of ram. I did get it working but even when trimming everything down as much as I could the poor thing would struggle . I would at the very least put this in to track both uptime and available memory. If it drops below 80kb free to consider alternatives…
- platform: uptime
lambda: return heap_caps_get_free_size(MALLOC_CAP_INTERNAL);
icon: "mdi:memory"
entity_category: diagnostic
state_class: measurement
unit_of_measurement: "b"
update_interval: 60s
Oh, and if you are having issues seeing anything on the screen, make sure that you are turning on the backlight. Check my sample code eg:
output:
- platform: ledc
pin: $bkpin
light:
restore_mode: $screenstart
FWIW My bad. On further checking I found that the capacitor I had put in to smooth the power being fed to the device had failed. Replaced and all good again.
I don’t know if this will help anyone else, but I had a hell of a slog getting the Elecrow 1.28 inch CrowPanel to play nice with ESPhome. That’s this unit, btw: Crowpanel -ESP32 Display-1.28(R) inch 240*240 Round IPS Display Capacitive Touch SPI Screen
Compared to the rotary-knob model, the i2c tapdance was rather arcane.
Anyway, this works with ESPHOME 2026.2.1 - and works around the nigh-impossibility of finding a 240x240x16b contiguous buffer for the display.
Sorry, no touch. I was just happy to get the display running properly at last.
esphome:
on_boot:
priority: 550.0
then:
- lambda: |-
ESP_LOGD("boot", "Applying hard power sequences...");
id(buzzer_pin).turn_off();
id(lcd_power_en).turn_on();
delay(250);
id(lcd_backlight).turn_on();
esp32:
variant: esp32c3
framework:
type: arduino
spi:
clk_pin: GPIO6
mosi_pin: GPIO7
i2c:
sda: GPIO4
scl: GPIO5
pi4ioe5v6408:
address: 0x43
output:
- platform: gpio
pin: GPIO3
- platform: gpio
pin:
number: 2
pi4ioe5v6408: io_ext
- platform: gpio
pin:
number: 3
display:
- platform: ili9xxx
model: GC9A01A
spi_id: spi_bus
cs_pin: GPIO10
dc_pin: GPIO2
reset_pin:
number: 4
invert_colors: true
# Switched to BGR as red background indicated flipped color channels
color_order: BGR
dimensions:
width: 240
height: 240
transform:
mirror_x: true
# LVGL Component
lvgl:
# buffer_size: 10% of 240x240 is 5760.
# This only requires ~11KB of RAM, which is almost guaranteed to succeed.
buffer_size: 10%
displays:
- my_display
# LVGL draws widgets instead of raw lines/pixels in a lambda.
widgets:
- obj:
height: 100%
width: 100%
bg_color: 0x0000FF # Blue background
widgets:
- label:
text: "LVGL SUCCESS!"
align: CENTER
text_color: 0xFFFFFF # White text
wifi:
api:
max_connections: 2
ota:
- platform: esphome
logger:
level: DEBUG
hardware_uart: USB_SERIAL_JTAG
