EDIT: For anyone else that has this issue, I replaced the camera module and that fixed it, it must have been faulty.
I’ve managed to get my ESP32 cam set up with ESPHome however the images seem to be corrupted? I’m not sure if this is a software or hardware issue. I don’t have another ESP32 cam to test unfortunately.
I’ve tried a few different power supplies so I don’t think that is it. I’m brand new to ESP Home so I’m not too sure where to start with troubleshooting, any help would be appreciated!
This is my config yaml:
substitutions:
# Modify variables based on your settings
hostname: "esp32cam"
esphome:
platform: ESP32
board: esp32dev
wifi:
ssid: redacted
password: redacted
fast_connect: True
# Enable logging
logger:
# Enable Home Assistant API
api:
reboot_timeout: 0s
web_server:
port: 80
ota:
- platform: esphome
time:
- platform: homeassistant
# ESP32-CAM
esp32_camera:
external_clock:
pin: GPIO0
frequency: 10MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
vsync_pin: GPIO25
href_pin: GPIO23
pixel_clock_pin: GPIO22
power_down_pin: GPIO32
resolution: 640x480
jpeg_quality: 10
# Flashlight
output:
- platform: gpio
pin: GPIO4
## GPIO_4 is the flash light pin
light:
- platform: binary
output: gpio_4
Note: I’m using this board: https://www.aliexpress.com/item/1005006501528278.html?spm=a2g0o.order_list.order_list_main.11.43e81802Ouveo7 (ESP32-CAM-MB)
