ervo
(Erik Vassøy Olsen)
December 24, 2022, 12:09pm
1
Bought this camera from aliexpress:
Is it possible to integrate this camera into home assistant through ESP home?
I don’t know what board it is and it oly says OV5640 (which I believe is the camera?).
I red on a form that people has implemented this camera as a web server. I still end up with the same problem with not knowing the name of the board.
Is there anyone that has got this working that could help me out here?
ervo
(Erik Vassøy Olsen)
December 24, 2022, 2:31pm
3
I know about these web sites.
I have tasted all the sample code there, noe of them is working.
I guess i have to set up custom pins?
I dont understand the table below (OV5640)
nerocide
(nerocide)
March 2, 2023, 8:14pm
4
This board is working fine in esphome & home assistant .
With esp32_camera component:
esp32_camera:
external_clock:
pin: GPIO15
frequency: 20MHz
i2c_pins:
sda: GPIO22
scl: GPIO23
data_pins: [GPIO2, GPIO14, GPIO35, GPIO12, GPIO27, GPIO33, GPIO34 , GPIO39]
vsync_pin: GPIO18
href_pin: GPIO36
pixel_clock_pin: GPIO26
reset_pin: GPIO5
resolution: 800x600
or with Arduino example CameraWebserver (in camera_pins.h):
#elif defined(CAMERA_MODEL_ESP_OV5640)
#define RESET_GPIO_NUM 5
#define XCLK_GPIO_NUM 15
#define SIOD_GPIO_NUM 22
#define SIOC_GPIO_NUM 23
#define Y9_GPIO_NUM 39
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 33
#define Y6_GPIO_NUM 27
#define Y5_GPIO_NUM 12
#define Y4_GPIO_NUM 35
#define Y3_GPIO_NUM 14
#define Y2_GPIO_NUM 2
#define VSYNC_GPIO_NUM 18
#define HREF_GPIO_NUM 36
#define PCLK_GPIO_NUM 26
#define LED_GPIO_NUM 25
Did anyone get an external antenna on IPEX port working? Do I have to resolder a resistor to do this? I still didn’t found any information on this…
