ESP32 constantly disconnecting and reconnecting
Hello everyone,
I’m trying to set up ESPresense in my Home Assistant as a Bluetooth beacon, but my ESP32 keeps disconnecting and reconnecting every second.
At first, I suspected an issue with the MQTT server, then I thought it might be due to my Wi-Fi not running on 2.4 GHz. However, I’ve checked both multiple times, and the problem persists.
Any ideas on what could be causing this?
Who knows? This is not the espresence forum.
Your best off asking there (as above), or searching through github issues to see if its know.
As it doesn’t use esphome your in the wrong place.
