ESP32 crashing connected to ESPHome and CAN bus
I have an ESP32 connected to an integrated MCP2515 module (with TJA1050 Receiver) which is then connected to a CAN bus. For software I am using the ESPHome CANBus component.
The problem is after receiving approx 40 to 50 CAN Frames (8 bytes each) the ESP goes offline. The power is still on but I get this error msg: WARNING 192.168.1.50: Connection error occurred: [Errno 104] Connection reset by peer
INFO Processing unexpected disconnect from ESPHome API for 192.168.1.50
WARNING Disconnected from API
WARNING Can’t connect to ESPHome API for 192.168.1.50: Error connecting to (‘192.168.1.50’, 6053): [Errno 111] Connect call failed (‘192.168.1.50’, 6053) (SocketAPIError)
And the only way I can get it back online is to disconnect the CAN bus and recycle the power to the ESP32 and MCP2515. Then it does the same again. Receives 40+ frames and crashes.
The data received before it goes offline is fine. But something is crashing and I cannot figure out what.
I have tried connecting to 2 totally different CAN Bus networks with the same problem.
I power my ESP32 and the MCP2515 separately with a 5V power module.
These are the PIN assignments:
MCP2515 - ESP32
SCK - P18
SI - P23
SO - P19
CS - P5
GND - GND
VCC - 5V
spi:
  clk_pin: GPIO18
  miso_pin: GPIO19
  mosi_pin: GPIO23
canbus:
  - platform: mcp2515
    cs_pin: GPIO5
    spi_id: spi_bus
    can_id: 0
    use_extended_id: True
    bit_rate: 250kbps
    on_frame:
    - can_id: 0
      can_id_mask: 0
      then:
      - lambda: |-
          ESP_LOGD("can_id", "Received CAN message with ID: %x", can_id);
          for (int i = 0; i < 8; i++) {
              ESP_LOGD("can_data", "Byte %d: %02x", i, x[i]);
          ESP_LOGD("can_id", "+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++");
Any suggestions?
HI, I don´t have a solution for your problem so, I`m trying to configure CAN bus communication with ESPHome too. I think I have a similar configuration as yours, but I´m not be able to receive or send can frames. Would you be so Kind to show me your wire diagram? Than you very much
Too much logging. If the CANbus traffic is high, your device will get hung up trying to send logs out the serial port.
I did get it going very well. The problem as the debug level.
I made this video and it shows how the CAN is connected with a ESP32 and ESPHome
Yes. That was exactly the problem. The newer S3 can handle it better though.
Yes, if it’s using the native USB “serial” interface, which has no actual baud rate to limit throughput.
