I have and ESP32 with DHT sensors attached and all the sensors more often than not report unknow readings. I’ve tried different sensors, checked wiring and connections.
Sensors I have have a pull up resistor on them. Attaching another made no difference.
Log shows.
[16:59:26][D][dht:048]: Got Temperature=-25.1°C Humidity=33.7%
[16:59:26][D][sensor:094]: 'Garage Refrigerator Freezer Temperature': Sending state -23.48712 °C with 1 decimals of accuracy
[16:59:26][D][sensor:094]: 'Garage Refrigerator Freezer Humidity': Sending state 33.70000 % with 0 decimals of accuracy
[16:59:32][W][dht:163]: Waiting for DHT communication to clear failed!
[16:59:32][W][dht:060]: Invalid readings! Please check your wiring (pull-up resistor, pin number).
[16:59:32][D][sensor:094]: 'Garage Refrigerator Refrigerator Temperature': Sending state nan °C with 0 decimals of accuracy
[16:59:32][D][sensor:094]: 'Garage Refrigerator Refrigerator Humidity': Sending state nan % with 0 decimals of accuracy
[16:59:32][W][component:214]: Component dht.sensor took a long time for an operation (0.05 s).
[16:59:32][W][component:215]: Components should block for at most 20-30ms.
[16:59:38][D][dht:048]: Got Temperature=-13.6°C Humidity=37.9%
[16:59:38][D][sensor:094]: 'Garage Refrigerator Deep Freezer Temperature': Sending state -13.60000 °C with 1 decimals of accuracy
[16:59:38][D][sensor:094]: 'Garage Refrigerator Deep Freezer Humidity': Sending state 37.90000 % with 0 decimals of accuracy
[16:59:46][D][text_sensor:064]: 'Garage Refrigerator Uptime': Sending state '2d 20h 55m 53s'
[16:59:46][D][sensor:094]: 'Garage Refrigerator Uptime': Sending state 248153.45312 s with 0 decimals of accuracy
[16:59:51][D][sensor:094]: 'Garage Refrigerator WiFi Strength': Sending state -39.00000 dBm with 0 decimals of accuracy
[17:00:26][W][dht:169]: Requesting data from DHT failed!
[17:00:26][W][dht:060]: Invalid readings! Please check your wiring (pull-up resistor, pin number).
[17:00:26][D][sensor:094]: 'Garage Refrigerator Freezer Temperature': Sending state nan °C with 1 decimals of accuracy
[17:00:26][D][sensor:094]: 'Garage Refrigerator Freezer Humidity': Sending state nan % with 0 decimals of accuracy
[17:00:32][W][dht:163]: Waiting for DHT communication to clear failed!
[17:00:32][W][dht:060]: Invalid readings! Please check your wiring (pull-up resistor, pin number).
[17:00:32][D][sensor:094]: 'Garage Refrigerator Refrigerator Temperature': Sending state nan °C with 0 decimals of accuracy
[17:00:32][D][sensor:094]: 'Garage Refrigerator Refrigerator Humidity': Sending state nan % with 0 decimals of accuracy
[17:00:32][W][component:214]: Component dht.sensor took a long time for an operation (0.06 s).
[17:00:32][W][component:215]: Components should block for at most 20-30ms.
Code for ESP32 is
substitutions:
v_friendly_name: Garage Refrigerator
esphome:
friendly_name: ${v_friendly_name}
# Throttle writing parameters to the internal flash memory to reduce ESP memory wear / degradation
preferences:
flash_write_interval: 15min
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "XXXXXXXXX"
ota:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "XXXXXXXXX"
password: "XXXXXXX"
text_sensor:
# Send IP Address
- platform: wifi_info
ip_address:
name: ${v_friendly_name} IP Address
# Send Uptime in raw seconds
icon: mdi:clock-start
captive_portal:
# Send WiFi signal strength & uptime to HA
- platform: wifi_signal
name: ${v_friendly_name} WiFi Strength
update_interval: 60s
# This is a bit of overkill. It sends a human readable
# uptime string 1h 41m 32s instead of 6092 seconds
- platform: uptime
on_raw_value:
then:
- text_sensor.template.publish:
# Custom C++ code to generate the result
state: !lambda |-
int seconds = round(id(uptime_sensor).raw_state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return (
(days ? to_string(days) + "d " : "") +
(hours ? to_string(hours) + "h " : "") +
(minutes ? to_string(minutes) + "m " : "") +
(to_string(seconds) + "s")
).c_str();
# GET TEMP/HUMIDITY FROM DHT11
- platform: dht
pin: GPIO4
model: DHT11
temperature:
name: "${v_friendly_name} Refrigerator Temperature"
accuracy_decimals: 0
filters:
- exponential_moving_average:
alpha: 0.1
send_every: 1
humidity:
name: "${v_friendly_name} Refrigerator Humidity"
# the DHT11 can only be read every 1s. Use 1.3s to be safe.
# GET TEMP/HUMIDITY FROM DHT22
- platform: dht
pin: GPIO16
model: DHT22
temperature:
name: "${v_friendly_name} Freezer Temperature"
accuracy_decimals: 1
filters:
alpha: 0.1
send_every: 1
humidity:
name: "${v_friendly_name} Freezer Humidity"
- platform: dht
pin: GPIO17
model: DHT22
temperature:
name: "${v_friendly_name} Deep Freezer Temperature"
humidity:
name: "${v_friendly_name} Deep Freezer Humidity"
switch:
# Expose an ESP32 restart button to HA
- platform: restart
name: ${v_friendly_name} ESP32 Restart
web_server:
port: 80
