i’m new to this all and have no experience programming but i try to get my first project to work.
I’m trying to build a display with an esp that has 3 icons, on pressing on one icon it should e.g toggle a light.
I got the display working, it shows my three icon and the first icon coordinates a programmed in. But when i tocuh the icon i get in the loggs it toggles the script but the lights don’t go on.
My Code:
esphome:
friendly_name: Arbeitszimmer Touchdisplay
platformio_options:
build_flags: "-DBOARD_HAS_PSRAM"
esp32:
board: esp32dev
framework:
type: arduino
logger:
api:
encryption:
key: ""
ota:
- platform: esphome
password: ""
wifi:
ssid: ""
password: ""
spi:
clk_pin: GPIO18
mosi_pin: GPIO23
miso_pin: GPIO19
display:
- platform: ili9xxx
model: ILI9341
cs_pin: GPIO17
dc_pin: GPIO4
reset_pin: GPIO16
rotation: 90
invert_colors: false
color_palette: 8bit
update_interval: never
data_rate: 20000000
lambda: |-
it.image(35, 30, id(icon_lamp)); // Links
it.image(125, 30, id(icon_alarm)); // Mitte
it.image(215, 30, id(icon_gaming)); // Rechts
touchscreen:
- platform: xpt2046
cs_pin: GPIO13
interrupt_pin: GPIO34
update_interval: 50ms
threshold: 400
calibration:
x_min: 200
x_max: 3900
y_min: 200
y_max: 3900
on_touch:
then:
- lambda: |-
id(tft_display).update();
int x = touch.x;
int y = touch.y;
ESP_LOGD("touch", "Touch coordinates: (%d, %d)", x, y);
if (x > 196 && x < 286 && y > 170 && y < 217) {
ESP_LOGD("touch", "Toggle Lamp Triggered");
id(toggle_lamp).execute();
} else {
ESP_LOGD("touch", "Touch outside range: %d, %d", x, y);
image:
- file: "images/icon_lamp.bmp"
type: RGB
- file: "images/icon_alarm.bmp"
type: RGB
- file: "images/icon_gaming.bmp"
type: RGB
script:
- id: toggle_lamp
then:
- homeassistant.service:
service: homeassistant.toggle
entity_id: switch.licht_esszimmer
- id: toggle_alarm
then:
service: automation.toggle
entity_id: automation.alarm_arbeitszimmer
- id: toggle_gaming
then:
entity_id: switch.gaming
Logs after pressing the icon:
[10:47:55][D][xpt2046:055]: Touchscreen Update [2661, 3275], z = 1373
[10:47:55][D][touch:068]: Touch coordinates: (212, 199)
[10:47:55][D][touch:070]: Toggle Lamp Triggered
[10:47:55][W][component:239]: Component touchscreen took a long time for an operation (144 ms).
[10:47:55][W][component:240]: Components should block for at most 30 ms.
[10:47:55][D][xpt2046:055]: Touchscreen Update [2655, 3263], z = 1575
[10:47:56][D][touch:068]: Touch coordinates: (212, 198)
[10:47:56][D][touch:070]: Toggle Lamp Triggered
[10:47:56][W][component:239]: Component touchscreen took a long time for an operation (145 ms).
[10:47:56][W][component:240]: Components should block for at most 30 ms.
[10:47:57][D][xpt2046:055]: Touchscreen Update [2796, 3362], z = 958
[10:47:58][D][touch:068]: Touch coordinates: (224, 205)
[10:47:58][D][touch:070]: Toggle Lamp Triggered
[10:47:58][W][component:239]: Component touchscreen took a long time for an operation (145 ms).
[10:47:58][W][component:240]: Components should block for at most 30 ms.
Every help is needed
