Hi everyone,
I’ve set up an ESP8266 WeMos D1 board running ESPHome with the Haier Climate component to communicate with my Haier ducted air conditioner. Everything went smoothly and I had it up and running in one evening, I thought it was almost too easy!
However, during testing, I noticed an issue. While the integration updates both ways and all modes appear to work, the compressor doesn’t start in either Heat or Cool mode.
Interestingly, as soon as I disconnect the TX and RX wires between the ESP board and the air conditioner’s main board, the system works as expected. It’s almost as if there’s a compressor lockout function being triggered.
Has anyone experienced something similar or have any insights to share?
Below is the current esp code.
esphome:
friendly_name: Haier AirCon
esp8266:
board: d1
# Disable UART logging
logger:
level: DEBUG
baud_rate: 0
# Enable Home Assistant API
api:
encryption:
key: "abc"
ota:
- platform: esphome
password: "abc"
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: 192.168.65.31
gateway: 192.168.65.1
subnet: 255.255.255.0
ap:
ssid: "Haier-Aircon Fallback Hotspot"
password: "abc"
captive_portal:
# UART to AC
uart:
- id: ac_port
tx_pin: GPIO1
rx_pin: GPIO3
baud_rate: 9600
climate:
- platform: haier
protocol: smartair2
uart_id: ac_port
name: "Haier Ducted AC"
wifi_signal: false
display: true
visual:
min_temperature: 16 °C
max_temperature: 30 °C
temperature_step: 1 °C
supported_modes:
- 'OFF'
- COOL
- HEAT
- FAN_ONLY
I feel like I might be missing a function or configuration in the code that’s preventing proper operation.
Any help or insight would be greatly appreciated!
