Hi!
I’m building a garden watering system with 6 sprinklers and magnatic valves.
The hardware is already done, but I need some help with the code.
I found one in the web:
The only problem is that I dont wnat a switch to turn it on or off. I want to enter a time for watering on each day of the week.
How do I have to change the code???
Preformatted text
esphome:
friendly_name: bewcmp
esp8266:
board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
ota:
password: "XXXXXXXXXXXXXXXXXXXXXXXXXXX"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Bewcmp Fallback Hotspot"
password: "OFD81nQudVj7"
captive_portal:
switch:
- platform: gpio
pin: D1
# Stellt sicher, dass die Relais beim neustart des ESPs ausgeschaltet sind
restore_mode: ALWAYS_OFF
# Schaltet sicherheitshalber den GPIO-Switch nach 10 Minuten aus. Im Bearfsfall die Dauer anpassen ;)
on_turn_on:
- delay: 600s
- switch.turn_off: rasen_sprinkler_valve
- platform: gpio
pin: D2
on_turn_on:
- delay: 600s
- switch.turn_off: blumenwiese_sprinkler_valve
- platform: gpio
pin: D3
on_turn_on:
- delay: 600s
- switch.turn_off: gemuese_sprinkler_valve
- platform: gpio
pin: D4
on_turn_on:
- delay: 600s
- platform: wifi_signal # Reports the WiFi signal strength/RSSI in dB
name: "WiFi Signal dB"
update_interval: 60s
entity_category: "diagnostic"
- platform: copy # Reports the WiFi signal strength in %
source_id: wifi_signal_db
name: "WiFi Signal Percent"
filters:
- lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
unit_of_measurement: "Signal %"
sprinkler:
- id: garden_sprinkler_ctrlr
main_switch: "Garten Sprinkler"
auto_advance_switch: "Garten Sprinkler Auto Advance"
reverse_switch: "Garten Sprinkler Reverse"
multiplier_number: "Garten Sprinkler Multiplier"
repeat_number: "Garten Sprinkler Repeat"
valve_overlap: 5s
valves:
- valve_switch: "Rasen Oben"
enable_switch: "Aktiviere Rasen oben"
run_duration_number: "Rasen oben Laufzeit"
valve_switch_id: rasen_sprinkler_valve
- valve_switch: "Blumenwiese"
enable_switch: "Aktiviere Blumenwiese"
run_duration_number: "Blumenwiese Laufzeit"
valve_switch_id: blumenwiese_sprinkler_valve
- valve_switch: "Gemüse"
enable_switch: "Aktiviere Gemüse"
run_duration_number: "Gemüse Laufzeit"
valve_switch_id: gemuese_sprinkler_valve
- valve_switch: "Himbeeren"
enable_switch: "Aktiviere Himbeeren"
run_duration_number: "Himbeeren Laufzeit"
valve_switch_id: himbeeren_sprinkler_valve
button:
- platform: restart
name: "Garten Sprinkler neu starten"
