Esp32 gpio pins not working
Good afternoon, I have a Yaml file that uploads correctly into my ESP WROOM 32U and partially works. The Yaml file is below.
As can be seen, this controls 5*5v relays via GPIO pins. The issue is that GPIO pins 21 and 22 do not control the Ralays as the other GPIO pins do. I must be doing something wrong, if anyone cpould assist I would be grateful.
esphome:
  friendly_name: ESPHome Web 13ebdc
  min_version: 2025.9.0
  name_add_mac_suffix: false
esp32:
  variant: esp32
  framework:
    type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
# Allow Over-The-Air updates
ota:
- platform: esphome
wifi:
  ssid: !secret wifi_ssid
switch:
  - platform: gpio
    pin: GPIO17
    #name: "Lounge A/C"
    icon: "mdi:air-conditioning"
    on_turn_on:
    - delay: 500ms
    - switch.turn_off: relay1
  - platform: gpio
    pin: GPIO18
    #name: "Master Bedroom A/c"
    icon: "mdi:house"
    on_turn_on:
    - delay: 500ms
    - switch.turn_off: relay2
  - platform: gpio
    pin: GPIO19
    #name: "Dining Room A/C"
    icon: "mdi:air"
    on_turn_on:
    - delay: 500ms
    - switch.turn_off: relay3
  - platform: gpio
    pin: GPIO021
    #name: "Breakfast Room A/C"
    icon: "mdi:air"
    on_turn_on:
    - delay: 500ms
    - switch.turn_off: relay4
  - platform: gpio
    pin: GPIO22
    #name: "Utility Room A/C"
    icon: "mdi:air"
    on_turn_on:
    - delay: 500ms
    - switch.turn_off: relay5
What kind of relays and how they are wired? Post a link.
just to rule out defective relays, did you try the working relays on GPIO21/22 and the non-working relays on GPIO17/18/19?
Hi thanks for replying, yes the realys work if connected to the other GPIO pins
I notice with your current code, the relays will be on by default, if you want them to be off by default, you must add the inverted: true option.
maybe that’s the issue, the relays are already on?
  - platform: gpio
    pin: GPIO21
    inverted: true
    icon: "mdi:air"
    on_turn_on:
    - delay: 500ms
If you use 5V relays incorrectly with 3.3V Esp32, soon you have other pins that don’t work.
And they are defined GPIO21, not GPIO021.
Try this:
  - platform: gpio
    pin: GPIO021
    inverted: true
    icon: "mdi:air"
    on_turn_on:
      then:
        - delay: 500ms
Good catch, but it will still work fine otherwise. GPIO021 will work too.
But better to use the correct syntax/indentations indeed.
Thank you :slight_smile:
Yizhet 5V 8 Channel-Relay, DC 5V 230V Relay Shield Module Control Board with Optocoupler for Raspberry Pi Arduino PIC AVR MCU DSP ARM TTL Logi
From Amazon.
With gnd from ESP32 to gnd pin next to the control pins and 5v from the ESPP32 to the VCC pin next to the control pins. A seperate 5v DC power supply conected to GND (-5v) and vcc (+5v) connected to JD-VCC.
Sounds pretty bad.
Connect your 5v psu to jd-vcc and gnd , jumper REMOVED.
Connect the trigger side VCC to 3.3V pin of esp, and IN pins to esp gpios.
