Hi all,
I am very new to esp32 and zigbee. While I am very well versed with hardware, the software part alludes me.
All I need is to set up the ESP_ZB_Light example to have 2 light endpoints instead of one. after that I think I can handle it.
I tried simply making 2 endpoints and doubling all the calls from the example. I have a basic understanding of matter but I dont see what I am doing wrong here. I have two distinct endpoints, each being added to the endpoint list and registered… why do I only see one light in Home Assistant?
Code below is basically the example code except for adding the second enpoint in zigbee config and then setting it up in esp_zb_task.
esp_zb_light.h
#include "esp_zigbee_core.h"
#include "light_driver.h"
/* Zigbee configuration */
#define INSTALLCODE_POLICY_ENABLE false /* enable the install code policy for security */
#define ED_AGING_TIMEOUT ESP_ZB_ED_AGING_TIMEOUT_64MIN
#define ED_KEEP_ALIVE 3000 /* 3000 millisecond */
////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////<- changes from example here to add second enpoint<- changes from example here to add second endpoint
#define HA_ESP_LIGHT_ENDPOINT 10 /* esp light bulb device endpoint, used to process light controlling commands */
#define HA_ESP_LIGHT2_ENDPOINT 11 /* esp light bulb device endpoint, used to process light controlling commands */
#define ESP_ZB_PRIMARY_CHANNEL_MASK ESP_ZB_TRANSCEIVER_ALL_CHANNELS_MASK /* Zigbee primary channel mask use in the example */
#define ESP_ZB_ZED_CONFIG() \
.esp_zb_role = ESP_ZB_DEVICE_TYPE_ED, \
.install_code_policy = INSTALLCODE_POLICY_ENABLE, \
.nwk_cfg.zed_cfg = { \
.ed_timeout = ED_AGING_TIMEOUT, \
.keep_alive = ED_KEEP_ALIVE, \
#define ESP_ZB_DEFAULT_RADIO_CONFIG() \
.radio_mode = RADIO_MODE_NATIVE, \
#define ESP_ZB_DEFAULT_HOST_CONFIG() \
.host_connection_mode = HOST_CONNECTION_MODE_NONE, \
esp_zb_light.c
#include "esp_log.h"
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "ha/esp_zigbee_ha_standard.h"
#include "esp_zb_light.h"
#include "nvs_flash.h"
* @note Make sure set idf.py menuconfig in zigbee component as zigbee end device!
#if !defined ZB_ED_ROLE
#error Define ZB_ED_ROLE in idf.py menuconfig to compile light (End Device) source code.
#endif
int registration_err_status;
static const char *TAG = "ESP_ZB_ON_OFF_LIGHT";
/********************* Define functions **************************/
static void bdb_start_top_level_commissioning_cb(uint8_t mode_mask)
ESP_ERROR_CHECK(esp_zb_bdb_start_top_level_commissioning(mode_mask));
void attr_cb(uint8_t status, uint8_t endpoint, uint16_t cluster_id, uint16_t attr_id, void *new_value)
if (cluster_id == ESP_ZB_ZCL_CLUSTER_ID_ON_OFF) {
uint8_t value = *(uint8_t *)new_value;
if (attr_id == ESP_ZB_ZCL_ATTR_ON_OFF_ON_OFF_ID) {
/* implemented light on/off control */
ESP_LOGI(TAG, "on/off light set to %hd", value);
light_driver_set_power((bool)value);
} else {
/* Implement some actions if needed when other cluster changed */
ESP_LOGI(TAG, "cluster:0x%x, attribute:0x%x changed ", cluster_id, attr_id);
void esp_zb_app_signal_handler(esp_zb_app_signal_t *signal_struct)
uint32_t *p_sg_p = signal_struct->p_app_signal;
esp_err_t err_status = signal_struct->esp_err_status;
esp_zb_app_signal_type_t sig_type = *p_sg_p;
switch (sig_type) {
case ESP_ZB_ZDO_SIGNAL_SKIP_STARTUP:
ESP_LOGI(TAG, "Zigbee stack initialized");
esp_zb_bdb_start_top_level_commissioning(ESP_ZB_BDB_MODE_INITIALIZATION);
break;
case ESP_ZB_BDB_SIGNAL_DEVICE_FIRST_START:
case ESP_ZB_BDB_SIGNAL_DEVICE_REBOOT:
if (err_status == ESP_OK) {
ESP_LOGI(TAG, "Start network steering");
esp_zb_bdb_start_top_level_commissioning(ESP_ZB_BDB_MODE_NETWORK_STEERING);
} else {
/* commissioning failed */
ESP_LOGW(TAG, "Failed to initialize Zigbee stack (status: %d)", err_status);
break;
case ESP_ZB_BDB_SIGNAL_STEERING:
esp_zb_ieee_addr_t extended_pan_id;
esp_zb_get_extended_pan_id(extended_pan_id);
ESP_LOGI(TAG, "Joined network successfully (Extended PAN ID: %02x:%02x:%02x:%02x:%02x:%02x:%02x:%02x, PAN ID: 0x%04hx, Channel:%d)",
extended_pan_id[7], extended_pan_id[6], extended_pan_id[5], extended_pan_id[4],
extended_pan_id[3], extended_pan_id[2], extended_pan_id[1], extended_pan_id[0],
esp_zb_get_pan_id(), esp_zb_get_current_channel());
} else {
ESP_LOGI(TAG, "Network steering was not successful (status: %d)", err_status);
esp_zb_scheduler_alarm((esp_zb_callback_t)bdb_start_top_level_commissioning_cb, ESP_ZB_BDB_MODE_NETWORK_STEERING, 1000);
break;
default:
ESP_LOGI(TAG, "ZDO signal: %d, status: %d", sig_type, err_status);
break;
static void esp_zb_task(void *pvParameters)
/* initialize Zigbee stack with Zigbee end-device config */
esp_zb_cfg_t zb_nwk_cfg = ESP_ZB_ZED_CONFIG();
esp_zb_init(&zb_nwk_cfg);
/* set the on-off light device config for light 1 */
esp_zb_on_off_light_cfg_t light1_cfg = ESP_ZB_DEFAULT_ON_OFF_LIGHT_CONFIG();
esp_zb_ep_list_t *esp_zb_on_off_light1_ep = esp_zb_on_off_light_ep_create(HA_ESP_LIGHT1_ENDPOINT, &light1_cfg);
/* set the on-off light device config for light 2 */
esp_zb_on_off_light_cfg_t light2_cfg = ESP_ZB_DEFAULT_ON_OFF_LIGHT_CONFIG();
esp_zb_ep_list_t *esp_zb_on_off_light2_ep = esp_zb_on_off_light_ep_create(HA_ESP_LIGHT2_ENDPOINT, &light2_cfg);
esp_zb_device_register(esp_zb_on_off_light1_ep);
esp_zb_device_register(esp_zb_on_off_light2_ep);
esp_zb_device_add_set_attr_value_cb(attr_cb);
esp_zb_set_primary_network_channel_set(ESP_ZB_PRIMARY_CHANNEL_MASK);
ESP_ERROR_CHECK(esp_zb_start(false));
esp_zb_main_loop_iteration();
void app_main(void)
esp_zb_platform_config_t config = {
.radio_config = ESP_ZB_DEFAULT_RADIO_CONFIG(),
.host_config = ESP_ZB_DEFAULT_HOST_CONFIG(),
ESP_ERROR_CHECK(nvs_flash_init());
/* load Zigbee light_bulb platform config to initialization */
ESP_ERROR_CHECK(esp_zb_platform_config(&config));
/* hardware related and device init for both light bulbs */
light_driver_init(LIGHT1_DEFAULT_OFF); // Assuming there's a function to initialize each light separately
//light_driver_init(LIGHT2_DEFAULT_OFF); // You might need to adjust these calls as per your hardware setup
xTaskCreate(esp_zb_task, "Zigbee_main", 4096, NULL, 5, NULL);
