ESP32-H2 sample config
Hi, with help of https://github.com/EwoutBergsma/OTA-Update-OpenThread-ESPHome I’ve got my ESP32-H2 (no wifi, only thread and BLE) working.
Please find below my config.
# esp32h2-c # this device has no WIFI !, only Thread over IPv6, BLE (and Zigbee if compiled into it)
substitutions:
  devname: "esp32h2-c"
esphome:
  friendly_name: ${devname}
  min_version: 2025.9.0
  name_add_mac_suffix: false
  on_boot:
    - priority: 500
      then:
        - logger.log: "* prevent deep sleep during boot/wake-up"
        - deep_sleep.prevent: deep_sleep_control
        - if:
            condition:
              lambda: return esp_sleep_get_wakeup_cause()==0;
            then:
              - logger.log: "* normal boot"
              - light.turn_on: red
              - wait_until:
                  condition:
                    api.connected:
                      state_subscription_only: true
              - logger.log: 'Home Assistant is connected!'
              - light.turn_off: red
              - script.execute: fast_blink_green
              - homeassistant.event:
                  event: esphome.device_booted
            else:
              - logger.log: "* wake-up event"
              - script.execute: fast_blink_orange
        - deep_sleep.allow: deep_sleep_control
esp32:
  variant: ESP32H2
  framework:
    type: esp-idf
deep_sleep:
  run_duration: 1 minutes
  sleep_duration: 1 minutes
# Enable logging
logger:
  hardware_uart: USB_SERIAL_JTAG
  level: INFO
  baud_rate: 115200
# Enable Home Assistant API
api:
  encryption:
    key: !secret esphome_api_key
# Allow Over-The-Air updates
ota:
- platform: esphome
  on_begin:
    then:
    - logger.log: "OTA start"
  on_end:
    then:
      - logger.log: "OTA end"
time:
  - platform: homeassistant
network:
  enable_ipv6: true
openthread:
  device_type: FTD
  tlv: [YOUR TLV]
  force_dataset: true
globals:
  - id: dim_set
    type: float
    restore_value: yes
    initial_value: '100'
output:
  - platform: ledc
    pin: GPIO10
  - platform: ledc
    pin: GPIO11
  - platform: ledc
    pin: GPIO12
light:
  - platform: monochromatic
    output: gpio_10
    default_transition_length: 0s
    on_turn_on:
        then:
          - light.turn_off: green
          - light.turn_off: orange
          - script.execute:
    effects: !include common/esphome_light_effects.yaml
    output: gpio_11
    on_turn_on:
        then:
          - script.execute:
    output: gpio_12
    on_turn_on:
        then:
          - script.execute:
#  - platform: esp32_rmt_led_strip
#    rgb_order: GRB
#    pin: GPIO08
#    num_leds: 1
#    chipset: ws2812
#    name: "sobRGB"
text_sensor:
  - platform: openthread_info
    ip_address:
      name: "Thread IP Address"
    channel:
    role:
      name: "Thread Device Role"
    rloc16:
    ext_addr:
      name: "Thread Extended Address"
    eui64:
    network_name:
      name: "Thread Network Name"
    network_key:
      name: "Thread Network Key"
    pan_id:
      name: "Thread PAN ID"
    ext_pan_id:
      name: "Thread Extended PAN ID"
binary_sensor:
  - platform: status
  - platform: gpio
    pin:
      number: GPIO13
      mode:
        input: true
        pulldown: true
    interrupt_type: ANY
  - platform: gpio
    pin:
      number: GPIO14
      mode:
        input: true
        pulldown: true
    interrupt_type: ANY
switch:
  - platform: restart
  - platform: safe_mode
    optimistic: True
    turn_on_action:
      then:
        - globals.set:
            value: '20'
        - script.execute:
        - logger.log: 'Dimmer on'
    turn_off_action:
      then:
        - globals.set:
            value: '100'
        - script.execute:
        - logger.log: 'Dimmer off'
    name: Enter DeepSleep
    turn_on_action:
      then:
        - deep_sleep.enter: deep_sleep_control
    name: Prevent DeepSleep
    turn_on_action:
      then:
  - platform: uptime
    accuracy_decimals: 0
    lambda: return esp_sleep_get_wakeup_cause();
script:
  - id: fast_blink_green
    then:
    - repeat:
        count: 3
        then:
          - light.turn_on: green
          - delay: 250ms
          - delay: 200ms
  - id: fast_blink_orange
    then:
    - repeat:
        count: 3
        then:
          - light.turn_on: orange
          - delay: 250ms
          - delay: 200ms
  - id: fast_blink_red
    then:
    - repeat:
        count: 3
        then:
          - delay: 250ms
          - delay: 200ms
  - id: dim_light
    then:
       - if:
            condition:
              light.is_on:
            then:
              - light.turn_on:
                  brightness: !lambda |-
                    // output value must be in range 0 - 1.0
                    return id(dim_set) / 100.0;
       - if:
            condition:
              light.is_on:
            then:
              - light.turn_on:
       - if:
            condition:
              light.is_on:
            then:
              - light.turn_on:
and common/esphome_light_effects.yaml for completeness
- strobe:
    colors:
      - state: true
        brightness: 100%
        duration: 5ms
      - state: false
        duration: 2995ms
- lambda:
   update_interval: 16s
   lambda: |-
    static int state = 0;
    static int color = 1;
    auto call = id(red).turn_on(); //the id of your light
    call.set_transition_length(5000);
    if (state == 0)
     call.set_brightness(1.0);
     else if (state == 1)
     call.set_brightness(0.01);
     call.perform();
     state ++;
     if (state == 2){
     state = 0;
