Hi
I’m running the esp 32 (esphome) talking to a VFD in combination with Homey(home automation).
And I want to have a slider (0/100%) in homey, and the esp to output 0hz to 100hz.
first I had written a code to have it working with PWM but my VFD doesn’t support PWM.
This code works good with esp.
number:
optimistic: true
min_value: 0
max_value: 100
step: 1
mode: slider
on_value:
then:
lambda: 'id(PWM).set_level(x/100);'
output:
- platform: ledc
pin: GPIO26
frequency: 100Hz
inverted: true
But when I change the code to get variable frequency the output of the esp goes all over the place (frequency and pulse with) and output doesn’t change with the slider.
number:
optimistic: true
min_value: 0
max_value: 100
step: 1
mode: slider
on_value:
then:
lambda: 'id(freq).set_frequency(x);'
output:
- platform: ledc
pin: GPIO26
how do I get this working
