On the home page config, I see heating_status, but if in my climate , when heating is active, I don’t see on the home page this is active?
Hi! The project is still under development. The icon display isn’t finished yet. But it will be soon.
Hi, I tried to get some more information about whats new for P4 in dev version. I am trying to get OTA working on my device - ESP-P4-ETH from waveshare. I basically coppied bits of essential configuration from this project.
Hi! In version 2025.12.0 dev OTA works in my project, but there is screen flickering
What does anyone think about an intercom function? Perhaps a “Push to announce/talk” setup. This is not a feature request, just looking for input on utility and feasibility.
funny, i also have screen flickering with the old guition 4" when doing ota, not that it matters
On Guition ESP32-48480S40, it also flickers during OTA if you don’t specify rodata in the SDK settings, but on Waveshare-86-panel this doesn’t help.
Qualcuno ha delle info sulle impostazioni inerenti al settaggio del nuovo display elecrow 9 pollici esp32p4?
Use the execute_from_psram option rather than setting sdkconfig options.
I’ve just bought a Waveshare ESP32-P4-WIFI6-Touch-LCD-4B and have got @alaltitov’s project working on it, but the wifi range on it is absolutely terrible. Even at 3m with direct line of sight to the router, it’s less than 50% signal strength. By contrast, I have plenty of other ESP32 devices with PCB antennas working reliably off the same routers in different rooms.
Are reasons other than broken hardware that might explain this? I’ve checked that the antenna is attached and not visibly damaged.
I’m using esphome 2025.11.5.
Mine is about 25 feet and two floors away from my access point and I get about 70% signal strength. It could be a hardware issue or an issue with your access point.
My button panel is working great with this screen if you want to try the latest.
Thank you - I have also got your configuration working too, with exactly the same wifi issue.
I’ve tried two completely different access points and both show the same issue (and both work just fine with plenty of other ESP32 devices).
I’m going to attempt to update the co-processor firmware, but I fear this may be a hardware issue. EDIT: now done, no change.
Unfortunately, I didn’t try connecting to wifi using the demo firmware that it shipped with, and that firmware doesn’t seem to be available anywhere.
Turns out that it’s a faulty antenna - it’s shorted in the connector on the cable. I’ve not got anything with the right connector to replace it with, but if I carefully touch the centre pin of the connector on the PCB with tweezers, wifi strength jumps to 75%.
Good find. This unit does have an external antenna at the top of the housing. This is a good design unless the cable is damaged or disconnected!
I figured I had nothing to lose, so I got the microscope and tweezers out and had a go at fixing it. I managed to prise open the ipex connector and sure enough, found a single loose strand of wire. Probably less than 1mm long, but obviously enough to short it. Against the odds I managed to get it back together and it’s now working perfectly!
Now I can get on with playing with LVGL ![]()
The wifi on these is so bad, so lucky that I bought the Ethernet version.
Has anybody found a way to stop this screen from flickering during OTA?
Does it happen over USB as well? I typically only flash by usb and don’t see any flickering. I noticed some of the earlier codes by people have some weird libraries and display settings that did it. I wrote mine from scratch and I don’t see it anymore.
No only over Wi-Fi
This is my config. I removed the "CONFIG_SPIRAM_XIP_FROM_PSRAM: y " because my ESP won’t boot if I use it.
# Hardware configuration file for Waveshare ESP32-P4-86-Panel 720px x 720px smart panel
# https://www.waveshare.com/wiki/ESP32-P4-86-Panel-ETH-2RO
esphome:
min_version: 2025.12.0
project:
version: "1.0.0"
esp32:
variant: esp32p4
flash_size: 32MB
framework:
type: esp-idf
advanced:
enable_idf_experimental_features: true
cpu_frequency: 400MHz
psram:
speed: 200MHz
preferences:
flash_write_interval: 5min
esp_ldo:
- channel: 3
voltage: 2.5V
# Network hardware
# Ethernet settings
# ethernet:
# type: IP101
# mdc_pin: GPIO31
# mdio_pin: GPIO52
# clk:
# pin: GPIO50
# mode: CLK_EXT_IN
# phy_addr: 1
# power_pin: GPIO51
esp32_hosted:
active_high: true
variant: ESP32C6
reset_pin: GPIO54
cmd_pin: GPIO19
clk_pin: GPIO18
d0_pin: GPIO14
d1_pin: GPIO15
d2_pin: GPIO16
d3_pin: GPIO17
# LCD Back light and Relays
output:
- platform: ledc
pin: GPIO26
frequency: 100Hz
inverted: true
min_power: 0.1 # To prevent the backlight from being too dim
max_power: 0.8 # To prevent overheating due to excessive lighting
- id: internal_relay_1
platform: gpio
pin: GPIO32
- id: internal_relay_2
platform: gpio
pin: GPIO46
light:
- platform: monochromatic
output: gpio_backlight_pwm
name: Display Backlight
icon: mdi:lightbulb-on
restore_mode: ALWAYS_ON
# Touchscreen gt911
i2c:
- id: i2c_bus_a
sda: GPIO7
scl: GPIO8
scan: true
frequency: 400kHz
touchscreen:
platform: gt911
display: my_display
i2c_id: i2c_bus_a
# on_touch:
# - lambda: |-
# ESP_LOGI("Touch", "Touch detected at x=%d, y=%d", touch.x, touch.y);
# on_update:
# - lambda: |-
# for (auto touch: touches) {
# if (touch.state <= 2) {
# ESP_LOGI("Touch points:", "id=%d x=%d, y=%d x.raw=%d, y.raw=%d", touch.id, touch.x, touch.y, touch.x_raw, touch.y_raw);
# Display mipi_dsi
display:
- platform: mipi_dsi
model: WAVESHARE-P4-86-PANEL
# Special LVGL settings required for this display
lvgl:
buffer_size: 100%
byte_order: little_endian
# Audio
i2s_audio:
- id: i2s_audio_bus
i2s_mclk_pin: GPIO13
i2s_lrclk_pin: GPIO10
i2s_bclk_pin: GPIO12
audio_dac:
- platform: es8311
i2c_id: i2c_bus_a
address: 0x18
audio_adc:
- platform: es7210
i2c_id: i2c_bus_a
address: 0x40
microphone:
- platform: i2s_audio
i2s_audio_id: i2s_audio_bus
i2s_din_pin: GPIO11
sample_rate: 16000
bits_per_sample: 16bit
adc_type: external
# on_data:
# - logger.log:
# format: "Microphone data received: %d bytes"
# args: [x.size()]
speaker:
i2s_dout_pin: GPIO9
audio_dac: es8311_dac
dac_type: external
channel: mono
buffer_duration: 100ms
sample_rate: 48000
- platform: mixer
output_speaker: esp32_speaker
source_speakers:
- id: announcement_mixing_input
timeout: never
- id: media_mixing_input
timeout: never
- platform: resampler
output_speaker: announcement_mixing_input
sample_rate: 48000
bits_per_sample: 16
output_speaker: media_mixing_input
sample_rate: 48000
bits_per_sample: 16
switch:
- platform: gpio
pin: GPIO53 # BSP_POWER_AMP_IO
name: "Audio Amplifier"
restore_mode: ALWAYS_OFF
# Media Player
media_player:
- platform: speaker
name: "ESP32 P4 Media Player"
codec_support_enabled: true
# buffer_size: 2000000
# task_stack_in_psram: true
volume_min: 0.5
volume_max: 0.75
volume_increment: 0.05
announcement_pipeline:
speaker: announcement_resampling_speaker
format: FLAC
sample_rate: 48000
num_channels: 1
media_pipeline:
speaker: media_resampling_speaker
format: FLAC
num_channels: 1
sample_rate: 48000
on_announcement:
- if:
condition:
- microphone.is_capturing:
then:
- micro_wake_word.stop
- voice_assistant.stop
- mixer_speaker.apply_ducking:
decibel_reduction: 20
duration: 0.0s
- switch.turn_on: audio_amplifier
- delay: 100ms
on_state:
if:
condition:
and:
- not:
voice_assistant.is_running:
- not:
media_player.is_announcing:
then:
decibel_reduction: 0
duration: 1.0s
on_play:
- logger.log: "Media player started playing, disabling microphone"
- delay: 100ms
on_idle:
- delay: 100ms
- switch.turn_off: audio_amplifier
- if:
condition:
not:
then:
- micro_wake_word.start
name: "Voice Assistant State"
lambda: |-
if (id(esp32_microphone).is_running()) {
return 1;
} else {
return 0;
update_interval: 2s
text_sensor:
name: "Voice Assistant Status"
update_interval: 5s
lambda: |-
return {"Listening"};
} else {
return {"Idle"};
micro_wake_word:
models:
- model: alexa
on_wake_word_detected:
then:
- logger.log: "Wake word detected"
- voice_assistant.start:
wake_word: !lambda return wake_word;
voice_assistant:
microphone: esp32_microphone
media_player: speaker_media_player
micro_wake_word: my_wake_word
noise_suppression_level: 2
auto_gain: 31dBFS
volume_multiplier: 2.0
conversation_timeout: 300s
on_end:
# Wait a short amount of time to see if an announcement starts
- wait_until:
condition:
- media_player.is_announcing:
timeout: 0.5s
# Announcement is finished and the I2S bus is free
- wait_until:
- and:
- not:
- not:
media_player.is_playing:
- micro_wake_word.start:
on_client_connected:
on_client_disconnected:
