ESP32-P4 Waveshare Module
Hello everyone.
I recently got a ESP32-P4-Module from Waveshare but have been running into some issues with the WiFi and now, rebooting. Here is the module that I am using.
I found some similar topics that provided guidance with the WiFi configuration and the
esp32_hosted
Originally, the WiFi scan would find my network, but it wouldn’t connect. Subsequent scans after that did not find any networks.
Now, the watchdog gets triggered and the whole ESP reboots. Below are the logs and the configuration. Any help would be greatly appreciated!
CONFIG
esphome:
  friendly_name: P4-ESP
esp32:
  variant: esp32p4
  flash_size: 16MB
  framework:
    type: esp-idf
    advanced:
      enable_idf_experimental_features: true
  cpu_frequency: 360MHz
psram:
  mode: hex
  speed: 200MHz
preferences:
  flash_write_interval: 5min
esp_ldo:
  - voltage: 2.5V
    channel: 3
esp32_hosted:
  variant: ESP32C6
  reset_pin: GPIO54
  cmd_pin: GPIO19
  clk_pin: GPIO18
  d0_pin: GPIO14
  d1_pin: GPIO15
  d2_pin: GPIO16
  d3_pin: GPIO17
  active_high: true
logger:
  hardware_uart: UART0
api:
ota:
  - platform: esphome
    password: "3cb5b7d2ba8284dac9231fca1ef39c52"
wifi:
  ssid: !secret wifi_ssid
  power_save_mode: NONE
  reboot_timeout: 0s
LOGS
[09:03:24][C][wifi:475]: Starting
[09:03:24][D][wifi:1098]: Starting scan
[09:03:24][C][component:249]: Setup wifi took 2279ms
[09:03:24][W][component:386]: api set Warning flag: unspecified
[09:03:24][I][app:134]: setup() finished successfully!
[09:03:24][W][component:395]: wifi set Warning flag: scanning for networks
[09:03:24][I][app:206]: ESPHome version 2026.1.1 compiled on 2026-01-24 09:01:55 -0600
[09:03:24][I][app:213]: ESP32 Chip: ESP32-P4 r1.3, 2 core(s)
[09:03:24][C][logger:316]: Logger:
[09:03:24][C][logger:316]:  Max Level: DEBUG
[09:03:24][C][logger:316]:  Initial Level: DEBUG
[09:03:24][C][logger:322]:   Log Baud Rate: 115200
[09:03:24][C][logger:322]:  Hardware UART: UART0
[09:03:24][C][logger:332]:   Task Log Buffer Size: 768 bytes
[09:03:24][C][esp_ldo:024]: ESP LDO Channel 3:
[09:03:24][C][esp_ldo:024]:  Voltage: 2.500000V
[09:03:24][C][esp_ldo:024]:  Adjustable: NO
[09:03:24][C][wifi:1304]: WiFi:
[09:03:24][C][wifi:1304]:  Local MAC: 30:ED:A0:EA:6E:0D
[09:03:24][C][wifi:1304]:  Connected: NO
[09:03:24][C][esphome.ota:075]: Over-The-Air updates:
[09:03:24][C][esphome.ota:075]:  Address: p4-esp.local:3232
[09:03:24][C][esphome.ota:075]:  Version: 2
[09:03:24][C][esphome.ota:082]:   Password configured
[09:03:24][C][safe_mode:021]: Safe Mode:
[09:03:24][C][safe_mode:021]:  Successful after: 60s
[09:03:24][C][safe_mode:021]:  Invoke after: 10 attempts
[09:03:24][C][safe_mode:021]:  Duration: 300s
[09:03:24][C][safe_mode:038]:   Bootloader rollback: support unknown
[09:03:24][C][api:221]: Server:
[09:03:24][C][api:221]:  Address: p4-esp.local:6053
[09:03:24][C][api:221]:  Listen backlog: 4
[09:03:24][C][api:221]:  Max connections: 8
[09:03:24][C][api:233]:   Noise encryption: NO
[09:03:24][C][mdns:177]: mDNS:
[09:03:24][C][mdns:177]:  Hostname: p4-esp
[09:03:30]E (19822) task_wdt: Task watchdog got triggered. The following tasks/users did not reset the watchdog in time:
[09:03:30]E (19822) task_wdt:  - loopTask (CPU 1)
[09:03:30]E (19822) task_wdt: Tasks currently running:
[09:03:30]E (19822) task_wdt: CPU 0: IDLE0
[09:03:30]E (19822) task_wdt: CPU 1: IDLE1
[09:03:30]E (19822) task_wdt: Aborting.
[09:03:30]E (19822) task_wdt: Print CPU 1 registers
[09:03:31]
[09:03:31]
[09:03:31]Core  1 register dump:
[09:03:31]MEPC    : 0x4ff022a8  RA      : 0x4ff02296  SP      : 0x4ff1d720  GP      : 0x4ff0b680
[09:03:31]TP      : 0x4ff1d770  T0      : 0x00000000  T1      : 0x4ff01d50  T2      : 0x00000000
[09:03:31]S0/FP   : 0x00000000  S1      : 0x4ff10000  A0      : 0x00000000  A1      : 0x00000000
[09:03:31]A2      : 0x00000000  A3      : 0x00000000  A4      : 0x00000000  A5      : 0x3ff06000
[09:03:31]A6      : 0x00000000  A7      : 0x00000000  S2      : 0x00000000  S3      : 0x4ff0e000
[09:03:31]S4      : 0x4ff10000  S5      : 0x00000000  S6      : 0x00000000  S7      : 0x00000000
[09:03:31]S8      : 0x00000000  S9      : 0x00000000  S10     : 0x00000000  S11     : 0x00000000
[09:03:31]T3      : 0x00000000  T4      : 0x00000000  T5      : 0x00000000  T6      : 0x00000000
[09:03:31]MSTATUS : 0x00000000  MTVEC   : 0x4ff10000  MCAUSE  : 0x00000000  MTVAL   : 0x40060c8a
[09:03:31]MHARTID : 0x00000000
[09:03:31]
[09:03:31]Stack memory:
[09:03:31]4ff1d720: 0x00000000 0x4ff10000 0x00000000 0x40060c8a 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:31]4ff1d740: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:31]4ff1d760: 0x00000000 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0x00000000 0x4ff1d194 0x4ff1d194 0x00000000
[09:03:31]4ff1d780: 0x00000000 0x00000000 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0x00000160 0x4ff1d6a0 0x00000000
[09:03:31]4ff1d7a0: 0x4ff0e36c 0x4ff1d034 0x4ff1d798 0x4ff0e364 0x00000019 0x00000000 0x00000000 0x4ff1d798
[09:03:31]4ff1d7c0: 0x00000000 0x00000000 0x4ff1d194 0x454c4449 0x00000031 0x00000000 0x00000000 0x00000001
[09:03:31]4ff1d7e0: 0x4ff1d790 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x4ff10698 0x4ff10700
[09:03:31]4ff1d800: 0x4ff10768 0x00000000 0x00000000 0x00000001 0x00000000 0x00000000 0x00000000 0x40048634
[09:03:31]4ff1d820: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:31]4ff1d840: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:31]4ff1d860: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:31]4ff1d880: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:31]4ff1d8a0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:31]4ff1d8c0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:31]4ff1d8e0: 0x00000000 0x00000000 0x00000200 0x6599f643 0x9edb2eaf 0x4ff1d790 0x00000010 0x0008010a
[09:03:31]4ff1d900: 0x00000035 0x00000000 0x4ff3b2c8 0x00000010 0x0001010a 0x00000050 0x00000000 0x4ff1d924
[09:03:31]4ff1d920: 0x00000010 0x0003010a 0x00000036 0x00000000 0x4ff3fb98 0x0000000c 0x00000000 0x4ff10044
[09:03:31]4ff1d940: 0x4ff1d930 0x00000160 0x4ff3f800 0x000039b2 0x4ff0e358 0x4ff176ac 0x4ff1d948 0x4ff0e350
[09:03:31]4ff1d960: 0x00000018 0x4ff2343c 0x4ff2343c 0x4ff1d948 0x4ff23434 0x00000001 0x4ff3db0c 0x706f6f6c
[09:03:31]4ff1d980: 0x6b736154 0x00000000 0x00000000 0x00000001 0x4ff3fb00 0x00000001 0x00000000 0x4ff217a0
[09:03:31]4ff1d9a0: 0x4004be08 0x00000000 0x4ff10698 0x4ff10700 0x4ff10768 0x00000000 0x00000000 0x00000001
[09:03:31]4ff1d9c0: 0x00000000 0x00000000 0x4ff1dc20 0x40048634 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:31]4ff1d9e0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:31]4ff1da00: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:31]4ff1da20: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:31]4ff1da40: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:31]4ff1da60: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:31]4ff1da80: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0xaa84bcbf
[09:03:31]4ff1daa0: 0x358c2ef0 0x4ff1d940 0x0000000c 0x00000000 0x4ff10044 0x4ff1daa4 0x00000014 0x0defe4e3
[09:03:31]4ff1dac0: 0x4ff1daac 0x00000004 0x4ff10044 0x4ff1dab4 0x00000024 0x35626333 0x32643762 0x32386162
[09:03:31]4ff1dae0: 0x61643438 0x33323963 0x61636631 0x33666531 0x32356339 0x4ff1da00 0x00000028 0x4009ac4c
[09:03:31]4ff1db00: 0x4007bf68 0x00020032 0x0000ea60 0x000493e0 0x00000000 0x00000066 0x00000a00 0x00000002
[09:03:31]
[09:03:31]
[09:03:31]
[09:03:31]ELF file SHA256: b33544a89
[09:03:31]
[09:03:31]Rebooting...
[09:03:31]ESP-ROM:esp32p4-eco2-20240710
[09:03:31]Build:Jul 10 2024
[09:03:31]rst:0xc (SW_CPU_RESET),boot:0xe (SPI_FAST_FLASH_BOOT)
[09:03:31]Core0 Saved PC:0x40032390
[09:03:31]Core1 Saved PC:0x4ff04ef2
[09:03:31]SPI mode:DIO, clock div:1
[09:03:31]load:0x4ff33ce0,len:0x164c
[09:03:31]load:0x4ff29ed0,len:0xe08
[09:03:31]load:0x4ff2cbd0,len:0x360c
[09:03:31]entry 0x4ff29ed0
[09:03:31]I (33) boot: ESP-IDF 5.5.2 2nd stage bootloader
[09:03:31]I (33) boot: compile time Jan 24 2026 08:57:39
[09:03:31]I (34) boot: Multicore bootloader
[09:03:31]I (35) boot: chip revision: v1.3
[09:03:31]I (36) boot: efuse block revision: v0.3
[09:03:31]I (40) boot.esp32p4: SPI Speed      : 80MHz
[09:03:31]I (43) boot.esp32p4: SPI Mode       : DIO
[09:03:31]I (47) boot.esp32p4: SPI Flash Size : 16MB
[09:03:31]I (51) boot: Enabling RNG early entropy source...
[09:03:31]I (56) boot: Partition Table:
[09:03:31]I (58) boot: ## Label            Usage          Type ST Offset   Length
[09:03:31]I (64) boot:  0 otadata          OTA data         01 00 00009000 00002000
[09:03:31]I (71) boot:  1 phy_init         RF data          01 01 0000b000 00001000
[09:03:31]I (77) boot:  2 app0             OTA app          00 10 00010000 007c0000
[09:03:31]I (84) boot:  3 app1             OTA app          00 11 007d0000 007c0000
[09:03:31]I (90) boot:  4 nvs              WiFi data        01 02 00f90000 0006d000
[09:03:31]I (98) boot: End of partition table
[09:03:31]I (101) esp_image: segment 0: paddr=00010020 vaddr=40070020 size=306e0h (198368) map
[09:03:31]I (136) esp_image: segment 1: paddr=00040708 vaddr=30100000 size=00044h (    68) load
[09:03:31]I (138) esp_image: segment 2: paddr=00040754 vaddr=4ff00000 size=0ae34h ( 44596) load
[09:03:31]I (148) esp_image: segment 3: paddr=0004b590 vaddr=4ff0ae80 size=025fch (  9724) load
[09:03:31]I (151) esp_image: segment 4: paddr=0004db94 vaddr=00000000 size=02484h (  9348)
[09:03:31]I (157) esp_image: segment 5: paddr=00050020 vaddr=40000020 size=62e4ch (405068) map
[09:03:31]I (222) boot: Loaded app from partition at offset 0x10000
[09:03:31]I (222) boot: Disabling RNG early entropy source...
[09:03:31][I][logger:121]: Log initialized
[09:03:31][C][safe_mode:118]: Unsuccessful boot attempts: 1
[09:03:31][D][esp32.preferences:155]: Writing 1 items: 0 cached, 1 written, 0 failed
[09:03:31][I][app:087]: Running through setup()
[09:03:31][D][esp_ldo:020]: Acquired LDO channel 3 with voltage 2.500000V
[09:03:33][C][wifi:475]: Starting
[09:03:33][D][wifi:1098]: Starting scan
[09:03:34][C][component:249]: Setup wifi took 2278ms
[09:03:34][W][component:386]: api set Warning flag: unspecified
[09:03:34][I][app:134]: setup() finished successfully!
[09:03:34][W][component:395]: wifi set Warning flag: scanning for networks
[09:03:34][I][app:206]: ESPHome version 2026.1.1 compiled on 2026-01-24 09:01:55 -0600
[09:03:34][I][app:213]: ESP32 Chip: ESP32-P4 r1.3, 2 core(s)
[09:03:34][C][logger:316]: Logger:
[09:03:34][C][logger:316]:  Max Level: DEBUG
[09:03:34][C][logger:316]:  Initial Level: DEBUG
[09:03:34][C][logger:322]:   Log Baud Rate: 115200
[09:03:34][C][logger:322]:  Hardware UART: UART0
[09:03:34][C][logger:332]:   Task Log Buffer Size: 768 bytes
[09:03:34][C][esp_ldo:024]: ESP LDO Channel 3:
[09:03:34][C][esp_ldo:024]:  Voltage: 2.500000V
[09:03:34][C][esp_ldo:024]:  Adjustable: NO
[09:03:34][C][wifi:1304]: WiFi:
[09:03:34][C][wifi:1304]:  Local MAC: 30:ED:A0:EA:6E:0D
[09:03:34][C][wifi:1304]:  Connected: NO
[09:03:34][C][esphome.ota:075]: Over-The-Air updates:
[09:03:34][C][esphome.ota:075]:  Address: p4-esp.local:3232
[09:03:34][C][esphome.ota:075]:  Version: 2
[09:03:34][C][esphome.ota:082]:   Password configured
[09:03:34][C][safe_mode:021]: Safe Mode:
[09:03:34][C][safe_mode:021]:  Successful after: 60s
[09:03:34][C][safe_mode:021]:  Invoke after: 10 attempts
[09:03:34][C][safe_mode:021]:  Duration: 300s
[09:03:34][C][safe_mode:038]:   Bootloader rollback: support unknown
[09:03:34][C][api:221]: Server:
[09:03:34][C][api:221]:  Address: p4-esp.local:6053
[09:03:34][C][api:221]:  Listen backlog: 4
[09:03:34][C][api:221]:  Max connections: 8
[09:03:34][C][api:233]:   Noise encryption: NO
[09:03:34][C][mdns:177]: mDNS:
[09:03:34][C][mdns:177]:  Hostname: p4-esp
[09:03:41]E (19785) task_wdt: Task watchdog got triggered. The following tasks/users did not reset the watchdog in time:
[09:03:41]E (19785) task_wdt:  - loopTask (CPU 1)
[09:03:41]E (19785) task_wdt: Tasks currently running:
[09:03:41]E (19785) task_wdt: CPU 0: IDLE0
[09:03:41]E (19785) task_wdt: CPU 1: IDLE1
[09:03:41]E (19785) task_wdt: Aborting.
[09:03:41]E (19785) task_wdt: Print CPU 1 registers
[09:03:41]
[09:03:41]
[09:03:41]Core  1 register dump:
[09:03:41]MEPC    : 0x4ff022a8  RA      : 0x4ff02296  SP      : 0x4ff1d720  GP      : 0x4ff0b680
[09:03:41]TP      : 0x4ff1d770  T0      : 0x00000000  T1      : 0x4ff01d50  T2      : 0x00000000
[09:03:41]S0/FP   : 0x00000000  S1      : 0x4ff10000  A0      : 0x00000000  A1      : 0x00000000
[09:03:41]A2      : 0x00000000  A3      : 0x00000000  A4      : 0x00000000  A5      : 0x3ff06000
[09:03:41]A6      : 0x00000000  A7      : 0x00000000  S2      : 0x00000000  S3      : 0x4ff0e000
[09:03:41]S4      : 0x4ff10000  S5      : 0x00000000  S6      : 0x00000000  S7      : 0x00000000
[09:03:41]S8      : 0x00000000  S9      : 0x00000000  S10     : 0x00000000  S11     : 0x00000000
[09:03:41]T3      : 0x00000000  T4      : 0x00000000  T5      : 0x00000000  T6      : 0x00000000
[09:03:41]MSTATUS : 0x00000000  MTVEC   : 0x4ff10000  MCAUSE  : 0x00000000  MTVAL   : 0x40060c8a
[09:03:41]MHARTID : 0x00000000
[09:03:41]
[09:03:41]Stack memory:
[09:03:41]4ff1d720: 0x00000000 0x4ff10000 0x00000000 0x40060c8a 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:41]4ff1d740: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:41]4ff1d760: 0x00000000 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0x00000000 0x4ff1d194 0x4ff1d194 0x00000000
[09:03:41]4ff1d780: 0x00000000 0x00000000 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0x00000160 0x4ff1d6a0 0x00000000
[09:03:41]4ff1d7a0: 0x4ff0e36c 0x4ff1d034 0x4ff1d798 0x4ff0e364 0x00000019 0x00000000 0x00000000 0x4ff1d798
[09:03:41]4ff1d7c0: 0x00000000 0x00000000 0x4ff1d194 0x454c4449 0x00000031 0x00000000 0x00000000 0x00000001
[09:03:41]4ff1d7e0: 0x4ff1d790 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x4ff10698 0x4ff10700
[09:03:41]4ff1d800: 0x4ff10768 0x00000000 0x00000000 0x00000001 0x00000000 0x00000000 0x00000000 0x40048634
[09:03:41]4ff1d820: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:41]4ff1d840: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:41]4ff1d860: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:41]4ff1d880: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:41]4ff1d8a0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:41]4ff1d8c0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:41]4ff1d8e0: 0x00000000 0x00000000 0x00000200 0x6599f643 0x9edb2eaf 0x4ff1d790 0x00000010 0x0008010a
[09:03:41]4ff1d900: 0x00000035 0x00000000 0x4ff3b2c8 0x00000010 0x0001010a 0x00000050 0x00000000 0x4ff1d924
[09:03:41]4ff1d920: 0x00000010 0x0003010a 0x00000036 0x00000000 0x4ff3fb98 0x0000000c 0x00000000 0x4ff10044
[09:03:41]4ff1d940: 0x4ff1d930 0x00000160 0x4ff3f800 0x000039b1 0x4ff0e358 0x4ff176ac 0x4ff1d948 0x4ff0e350
[09:03:41]4ff1d960: 0x00000018 0x4ff23478 0x4ff23478 0x4ff1d948 0x4ff23470 0x00000001 0x4ff3db0c 0x706f6f6c
[09:03:41]4ff1d980: 0x6b736154 0x00000000 0x00000000 0x00000001 0x4ff3fb00 0x00000001 0x00000000 0x4ff217a0
[09:03:41]4ff1d9a0: 0x4004be08 0x00000000 0x4ff10698 0x4ff10700 0x4ff10768 0x00000000 0x00000000 0x00000001
[09:03:41]4ff1d9c0: 0x00000000 0x00000000 0x4ff1dc20 0x40048634 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:41]4ff1d9e0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:41]4ff1da00: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:41]4ff1da20: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:41]4ff1da40: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:41]4ff1da60: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:41]4ff1da80: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0xaa84bcbf
[09:03:41]4ff1daa0: 0x358c2ef0 0x4ff1d940 0x0000000c 0x00000000 0x4ff10044 0x4ff1daa4 0x00000014 0x0defe4e3
[09:03:41]4ff1dac0: 0x4ff1daac 0x00000004 0x4ff10044 0x4ff1dab4 0x00000024 0x35626333 0x32643762 0x32386162
[09:03:41]4ff1dae0: 0x61643438 0x33323963 0x61636631 0x33666531 0x32356339 0x4ff1da00 0x00000028 0x4009ac4c
[09:03:41]4ff1db00: 0x4007bf68 0x00020032 0x0000ea60 0x000493e0 0x00000001 0x00000064 0x00000a00 0x00000002
[09:03:41]
[09:03:41]
[09:03:41]
[09:03:41]ELF file SHA256: b33544a89
[09:03:41]
[09:03:41]Rebooting...
[09:03:41]ESP-ROM:esp32p4-eco2-20240710
[09:03:41]Build:Jul 10 2024
[09:03:41]rst:0xc (SW_CPU_RESET),boot:0xe (SPI_FAST_FLASH_BOOT)
[09:03:41]Core0 Saved PC:0x40032390
[09:03:41]Core1 Saved PC:0x4ff04ef2
[09:03:41]SPI mode:DIO, clock div:1
[09:03:41]load:0x4ff33ce0,len:0x164c
[09:03:41]load:0x4ff29ed0,len:0xe08
[09:03:41]load:0x4ff2cbd0,len:0x360c
[09:03:41]entry 0x4ff29ed0
[09:03:41]I (33) boot: ESP-IDF 5.5.2 2nd stage bootloader
[09:03:41]I (33) boot: compile time Jan 24 2026 08:57:39
[09:03:41]I (34) boot: Multicore bootloader
[09:03:41]I (35) boot: chip revision: v1.3
[09:03:41]I (36) boot: efuse block revision: v0.3
[09:03:41]I (40) boot.esp32p4: SPI Speed      : 80MHz
[09:03:41]I (43) boot.esp32p4: SPI Mode       : DIO
[09:03:41]I (47) boot.esp32p4: SPI Flash Size : 16MB
[09:03:41]I (51) boot: Enabling RNG early entropy source...
[09:03:41]I (56) boot: Partition Table:
[09:03:41]I (58) boot: ## Label            Usage          Type ST Offset   Length
[09:03:41]I (64) boot:  0 otadata          OTA data         01 00 00009000 00002000
[09:03:41]I (71) boot:  1 phy_init         RF data          01 01 0000b000 00001000
[09:03:41]I (77) boot:  2 app0             OTA app          00 10 00010000 007c0000
[09:03:41]I (84) boot:  3 app1             OTA app          00 11 007d0000 007c0000
[09:03:41]I (90) boot:  4 nvs              WiFi data        01 02 00f90000 0006d000
[09:03:41]I (98) boot: End of partition table
[09:03:41]I (101) esp_image: segment 0: paddr=00010020 vaddr=40070020 size=306e0h (198368) map
[09:03:41]I (136) esp_image: segment 1: paddr=00040708 vaddr=30100000 size=00044h (    68) load
[09:03:41]I (138) esp_image: segment 2: paddr=00040754 vaddr=4ff00000 size=0ae34h ( 44596) load
[09:03:41]I (148) esp_image: segment 3: paddr=0004b590 vaddr=4ff0ae80 size=025fch (  9724) load
[09:03:41]I (151) esp_image: segment 4: paddr=0004db94 vaddr=00000000 size=02484h (  9348)
[09:03:41]I (157) esp_image: segment 5: paddr=00050020 vaddr=40000020 size=62e4ch (405068) map
[09:03:41]I (222) boot: Loaded app from partition at offset 0x10000
[09:03:41]I (222) boot: Disabling RNG early entropy source...
[09:03:42][I][logger:121]: Log initialized
[09:03:42][C][safe_mode:118]: Unsuccessful boot attempts: 2
[09:03:42][D][esp32.preferences:155]: Writing 1 items: 0 cached, 1 written, 0 failed
[09:03:42][I][app:087]: Running through setup()
[09:03:42][D][esp_ldo:020]: Acquired LDO channel 3 with voltage 2.500000V
[09:03:44][C][wifi:475]: Starting
[09:03:44][D][wifi:1098]: Starting scan
[09:03:44][C][component:249]: Setup wifi took 2278ms
[09:03:44][W][component:386]: api set Warning flag: unspecified
[09:03:44][I][app:134]: setup() finished successfully!
[09:03:44][W][component:395]: wifi set Warning flag: scanning for networks
[09:03:44][I][app:206]: ESPHome version 2026.1.1 compiled on 2026-01-24 09:01:55 -0600
[09:03:44][I][app:213]: ESP32 Chip: ESP32-P4 r1.3, 2 core(s)
[09:03:44][C][logger:316]: Logger:
[09:03:44][C][logger:316]:  Max Level: DEBUG
[09:03:44][C][logger:316]:  Initial Level: DEBUG
[09:03:44][C][logger:322]:   Log Baud Rate: 115200
[09:03:44][C][logger:322]:  Hardware UART: UART0
[09:03:44][C][logger:332]:   Task Log Buffer Size: 768 bytes
[09:03:44][C][esp_ldo:024]: ESP LDO Channel 3:
[09:03:44][C][esp_ldo:024]:  Voltage: 2.500000V
[09:03:44][C][esp_ldo:024]:  Adjustable: NO
[09:03:44][C][wifi:1304]: WiFi:
[09:03:44][C][wifi:1304]:  Local MAC: 30:ED:A0:EA:6E:0D
[09:03:44][C][wifi:1304]:  Connected: NO
[09:03:44][C][esphome.ota:075]: Over-The-Air updates:
[09:03:44][C][esphome.ota:075]:  Address: p4-esp.local:3232
[09:03:44][C][esphome.ota:075]:  Version: 2
[09:03:44][C][esphome.ota:082]:   Password configured
[09:03:44][C][safe_mode:021]: Safe Mode:
[09:03:44][C][safe_mode:021]:  Successful after: 60s
[09:03:44][C][safe_mode:021]:  Invoke after: 10 attempts
[09:03:44][C][safe_mode:021]:  Duration: 300s
[09:03:44][C][safe_mode:038]:   Bootloader rollback: support unknown
[09:03:44][W][safe_mode:044]: Last reset too quick; invoke in 8 restarts
[09:03:44][C][api:221]: Server:
[09:03:44][C][api:221]:  Address: p4-esp.local:6053
[09:03:44][C][api:221]:  Listen backlog: 4
[09:03:44][C][api:221]:  Max connections: 8
[09:03:44][C][api:233]:   Noise encryption: NO
[09:03:44][C][mdns:177]: mDNS:
[09:03:44][C][mdns:177]:  Hostname: p4-esp
[09:03:51]E (19801) task_wdt: Task watchdog got triggered. The following tasks/users did not reset the watchdog in time:
[09:03:51]E (19801) task_wdt:  - loopTask (CPU 1)
[09:03:51]E (19801) task_wdt: Tasks currently running:
[09:03:51]E (19801) task_wdt: CPU 0: IDLE0
[09:03:51]E (19801) task_wdt: CPU 1: IDLE1
[09:03:51]E (19801) task_wdt: Aborting.
[09:03:51]E (19801) task_wdt: Print CPU 1 registers
[09:03:52]
[09:03:52]
[09:03:52]Core  1 register dump:
[09:03:52]MEPC    : 0x4ff022a8  RA      : 0x4ff02296  SP      : 0x4ff1d720  GP      : 0x4ff0b680
[09:03:52]TP      : 0x4ff1d770  T0      : 0x00000000  T1      : 0x4ff01d50  T2      : 0x00000000
[09:03:52]S0/FP   : 0x00000000  S1      : 0x4ff10000  A0      : 0x00000000  A1      : 0x00000000
[09:03:52]A2      : 0x00000000  A3      : 0x00000000  A4      : 0x00000000  A5      : 0x3ff06000
[09:03:52]A6      : 0x00000000  A7      : 0x00000000  S2      : 0x00000000  S3      : 0x4ff0e000
[09:03:52]S4      : 0x4ff10000  S5      : 0x00000000  S6      : 0x00000000  S7      : 0x00000000
[09:03:52]S8      : 0x00000000  S9      : 0x00000000  S10     : 0x00000000  S11     : 0x00000000
[09:03:52]T3      : 0x00000000  T4      : 0x00000000  T5      : 0x00000000  T6      : 0x00000000
[09:03:52]MSTATUS : 0x00000000  MTVEC   : 0x4ff10000  MCAUSE  : 0x00000000  MTVAL   : 0x40060c8a
[09:03:52]MHARTID : 0x00000000
[09:03:52]
[09:03:52]Stack memory:
[09:03:52]4ff1d720: 0x00000000 0x4ff10000 0x00000000 0x40060c8a 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:52]4ff1d740: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:52]4ff1d760: 0x00000000 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0x00000000 0x4ff1d194 0x4ff1d194 0x00000000
[09:03:52]4ff1d780: 0x00000000 0x00000000 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0x00000160 0x4ff1d6a0 0x00000000
[09:03:52]4ff1d7a0: 0x4ff0e36c 0x4ff1d034 0x4ff1d798 0x4ff0e364 0x00000019 0x00000000 0x00000000 0x4ff1d798
[09:03:52]4ff1d7c0: 0x00000000 0x00000000 0x4ff1d194 0x454c4449 0x00000031 0x00000000 0x00000000 0x00000001
[09:03:52]4ff1d7e0: 0x4ff1d790 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x4ff10698 0x4ff10700
[09:03:52]4ff1d800: 0x4ff10768 0x00000000 0x00000000 0x00000001 0x00000000 0x00000000 0x00000000 0x40048634
[09:03:52]4ff1d820: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:52]4ff1d840: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:52]4ff1d860: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:52]4ff1d880: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:52]4ff1d8a0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:52]4ff1d8c0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:52]4ff1d8e0: 0x00000000 0x00000000 0x00000200 0x6599f643 0x9edb2eaf 0x4ff1d790 0x00000010 0x0008010a
[09:03:52]4ff1d900: 0x00000035 0x00000000 0x4ff3b2c8 0x00000010 0x0001010a 0x00000050 0x00000000 0x4ff1d924
[09:03:52]4ff1d920: 0x00000010 0x0003010a 0x00000036 0x00000000 0x4ff3fb98 0x0000000c 0x00000000 0x4ff10044
[09:03:52]4ff1d940: 0x4ff1d930 0x00000160 0x4ff3f800 0x000039b9 0x4ff0e358 0x4ff176ac 0x4ff1d948 0x4ff0e350
[09:03:52]4ff1d960: 0x00000018 0x4ff23478 0x4ff23478 0x4ff1d948 0x4ff23470 0x00000001 0x4ff3db0c 0x706f6f6c
[09:03:52]4ff1d980: 0x6b736154 0x00000000 0x00000000 0x00000001 0x4ff3fb00 0x00000001 0x00000000 0x4ff217a0
[09:03:52]4ff1d9a0: 0x4004be08 0x00000000 0x4ff10698 0x4ff10700 0x4ff10768 0x00000000 0x00000000 0x00000001
[09:03:52]4ff1d9c0: 0x00000000 0x00000000 0x4ff1dc20 0x40048634 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:52]4ff1d9e0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:52]4ff1da00: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:52]4ff1da20: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:52]4ff1da40: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:52]4ff1da60: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[09:03:52]4ff1da80: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0xaa84bcbf
[09:03:52]4ff1daa0: 0x358c2ef0 0x4ff1d940 0x0000000c 0x00000000 0x4ff10044 0x4ff1daa4 0x00000014 0x0defe4e3
[09:03:52]4ff1dac0: 0x4ff1daac 0x00000004 0x4ff10044 0x4ff1dab4 0x00000024 0x35626333 0x32643762 0x32386162
[09:03:52]4ff1dae0: 0x61643438 0x33323963 0x61636631 0x33666531 0x32356339 0x4ff1da00 0x00000028 0x4009ac4c
[09:03:52]4ff1db00: 0x4007bf68 0x00020032 0x0000ea60 0x000493e0 0x00000002 0x00000064 0x00000a00 0x00000002
[09:03:52]
[09:03:52]
[09:03:52]
[09:03:52]ELF file SHA256: b33544a89
[09:03:52]
[09:03:52]Rebooting...
[09:03:52]ESP-ROM:esp32p4-eco2-20240710
[09:03:52]Build:Jul 10 2024
[09:03:52]rst:0xc (SW_CPU_RESET),boot:0xe (SPI_FAST_FLASH_BOOT)
[09:03:52]Core0 Saved PC:0x40032390
[09:03:52]Core1 Saved PC:0x4ff04ef2
[09:03:52]SPI mode:DIO, clock div:1
[09:03:52]load:0x4ff33ce0,len:0x164c
[09:03:52]load:0x4ff29ed0,len:0xe08
[09:03:52]load:0x4ff2cbd0,len:0x360c
[09:03:52]entry 0x4ff29ed0
[09:03:52]I (33) boot: ESP-IDF 5.5.2 2nd stage bootloader
[09:03:52]I (33) boot: compile time Jan 24 2026 08:57:39
[09:03:52]I (34) boot: Multicore bootloader
[09:03:52]I (35) boot: chip revision: v1.3
[09:03:52]I (36) boot: efuse block revision: v0.3
[09:03:52]I (40) boot.esp32p4: SPI Speed      : 80MHz
[09:03:52]I (43) boot.esp32p4: SPI Mode       : DIO
[09:03:52]I (47) boot.esp32p4: SPI Flash Size : 16MB
[09:03:52]I (51) boot: Enabling RNG early entropy source...
[09:03:52]I (56) boot: Partition Table:
[09:03:52]I (58) boot: ## Label            Usage          Type ST Offset   Length
[09:03:52]I (64) boot:  0 otadata          OTA data         01 00 00009000 00002000
[09:03:52]I (71) boot:  1 phy_init         RF data          01 01 0000b000 00001000
[09:03:52]I (77) boot:  2 app0             OTA app          00 10 00010000 007c0000
[09:03:52]I (84) boot:  3 app1             OTA app          00 11 007d0000 007c0000
[09:03:52]I (90) boot:  4 nvs              WiFi data        01 02 00f90000 0006d000
[09:03:52]I (98) boot: End of partition table
[09:03:52]I (101) esp_image: segment 0: paddr=00010020 vaddr=40070020 size=306e0h (198368) map
[09:03:52]I (136) esp_image: segment 1: paddr=00040708 vaddr=30100000 size=00044h (    68) load
[09:03:52]I (138) esp_image: segment 2: paddr=00040754 vaddr=4ff00000 size=0ae34h ( 44596) load
[09:03:52]I (148) esp_image: segment 3: paddr=0004b590 vaddr=4ff0ae80 size=025fch (  9724) load
[09:03:52]I (151) esp_image: segment 4: paddr=0004db94 vaddr=00000000 size=02484h (  9348)
[09:03:52]I (157) esp_image: segment 5: paddr=00050020 vaddr=40000020 size=62e4ch (405068) map
[09:03:52]I (222) boot: Loaded app from partition at offset 0x10000
[09:03:52]I (222) boot: Disabling RNG early entropy source...
[09:03:52][I][logger:121]: Log initialized
[09:03:52][C][safe_mode:118]: Unsuccessful boot attempts: 3
[09:03:52][D][esp32.preferences:155]: Writing 1 items: 0 cached, 1 written, 0 failed
[09:03:52][I][app:087]: Running through setup()
[09:03:52][D][esp_ldo:020]: Acquired LDO channel 3 with voltage 2.500000V
[09:03:54][C][wifi:475]: Starting
[09:03:54][D][wifi:1098]: Starting scan
[09:03:54][C][component:249]: Setup wifi took 2278ms
[09:03:54][W][component:386]: api set Warning flag: unspecified
[09:03:54][I][app:134]: setup() finished successfully!
[09:03:54][W][component:395]: wifi set Warning flag: scanning for networks
[09:03:54][I][app:206]: ESPHome version 2026.1.1 compiled on 2026-01-24 09:01:55 -0600
[09:03:54][I][app:213]: ESP32 Chip: ESP32-P4 r1.3, 2 core(s)
[09:03:54][C][logger:316]: Logger:
[09:03:54][C][logger:316]:  Max Level: DEBUG
[09:03:54][C][logger:316]:  Initial Level: DEBUG
[09:03:54][C][logger:322]:   Log Baud Rate: 115200
[09:03:54][C][logger:322]:  Hardware UART: UART0
[09:03:54][C][logger:332]:   Task Log Buffer Size: 768 bytes
[09:03:54][C][esp_ldo:024]: ESP LDO Channel 3:
[09:03:54][C][esp_ldo:024]:  Voltage: 2.500000V
[09:03:54][C][esp_ldo:024]:  Adjustable: NO
[09:03:54][C][wifi:1304]: WiFi:
[09:03:54][C][wifi:1304]:  Local MAC: 30:ED:A0:EA:6E:0D
[09:03:54][C][wifi:1304]:  Connected: NO
[09:03:54][C][esphome.ota:075]: Over-The-Air updates:
[09:03:54][C][esphome.ota:075]:  Address: p4-esp.local:3232
[09:03:54][C][esphome.ota:075]:  Version: 2
[09:03:54][C][esphome.ota:082]:   Password configured
[09:03:54][C][safe_mode:021]: Safe Mode:
[09:03:54][C][safe_mode:021]:  Successful after: 60s
[09:03:54][C][safe_mode:021]:  Invoke after: 10 attempts
[09:03:54][C][safe_mode:021]:  Duration: 300s
[09:03:54][C][safe_mode:038]:   Bootloader rollback: support unknown
[09:03:54][W][safe_mode:044]: Last reset too quick; invoke in 7 restarts
[09:03:54][C][api:221]: Server:
[09:03:54][C][api:221]:  Address: p4-esp.local:6053
[09:03:54][C][api:221]:  Listen backlog: 4
[09:03:54][C][api:221]:  Max connections: 8
[09:03:54][C][api:233]:   Noise encryption: NO
[09:03:54][C][mdns:177]: mDNS:
[09:03:54][C][mdns:177]:  Hostname: p4-esp
Automate on!
DaviBoi
Not a P4 expert yet, but:
Is the C6 intentional?
Is your bootloader code that is crashing from a third party?
This is similar
Maybe follow to see if they find solution
Looks like a wifi issue - add fast_connect to your wifi config. Problem goes away.
Issue and fix raise: [wifi] Fix watchdog timeout on P4 WiFi scan by clydebarrow · Pull Request #13520 · esphome/esphome · GitHub
wifi:
  reboot_timeout: 0s
  fast_connect: true
I had tried both but I will confirm when I get back to the device. I completely missed this problem correlating with updating ESPHome.
This looks promising, I will give it a try! Thanks for finding that, I never came across that with my searching.
Yes, the P4 is using the C6 for WiFi since the P4 does not have native WiFi.
In this scenario, which chip does the ESPHome compile parameters address? One, the other, or both? Which chip is the ESPHome log reporting on?
You also need to turn off roaming:
wifi:
  reboot_timeout: 0s
  fast_connect: true
  post_connect_roaming: false
It’s fixed in the latest release anyway
The P4. The C6 has its own firmware that is not ESPHome.
Really appreciate your work on this Clyde!
Hmmm I added both fast_connect: True post_connect_roaming: False
but I still have the same issue. The P4 picks up the network the first scan, then doesn’t the subsequent tries. Any guidance on how I screwed this up?
CONFIG:
esphome:
esp32:
  variant: esp32p4
  flash_size: 16MB
  framework:
    type: esp-idf
    advanced:
psram:
  mode: hex
  speed: 200MHz
preferences:
esp_ldo:
  - voltage: 2.5V
    channel: 3
esp32_hosted:
  variant: ESP32C6
  reset_pin: GPIO54
  cmd_pin: GPIO19
  clk_pin: GPIO18
  d0_pin: GPIO14
  d1_pin: GPIO15
  d2_pin: GPIO16
  d3_pin: GPIO17
  active_high: true
logger:
  # hardware_uart: UART0
api:
ota:
  - platform: esphome
wifi:
  reboot_timeout: 0s
  fast_connect: True
LOGS:
[18:25:52]d:Jul 10 2024
[18:25:52]rst:0x17 (CHIP_USB_UART_RESET),boot:0x31c (SPI_FAST_FLASH_BOOT)
[18:25:52]Core0 Saved PC:0x4ff024c4
[18:25:52]Core1 Saved PC:0x4ff024c4
[18:25:52]SPI mode:DIO, clock div:1
[18:25:52]load:0x4ff33ce0,len:0x16c8
[18:25:52]load:0x4ff29ed0,len:0xdc8
[18:25:52]load:0x4ff2cbd0,len:0x3620
[18:25:52]entry 0x4ff29ed0
[18:25:52]I (14) boot: ESP-IDF 5.5.2 2nd stage bootloader
[18:25:52]I (14) boot: compile time Jan 26 2026 18:21:42
[18:25:52]I (14) boot: Multicore bootloader
[18:25:52]I (16) boot: chip revision: v1.3
[18:25:52]I (16) boot: efuse block revision: v0.3
[18:25:52]I (16) boot.esp32p4: SPI Speed      : 80MHz
[18:25:52]I (16) boot.esp32p4: SPI Mode       : DIO
[18:25:52]I (17) boot.esp32p4: SPI Flash Size : 16MB
[18:25:52]I (17) boot: Enabling RNG early entropy source...
[18:25:52]I (18) boot: Partition Table:
[18:25:52]I (18) boot: ## Label            Usage          Type ST Offset   Length
[18:25:52]I (18) boot:  0 otadata          OTA data         01 00 00009000 00002000
[18:25:52]I (19) boot:  1 phy_init         RF data          01 01 0000b000 00001000
[18:25:52]I (20) boot:  2 app0             OTA app          00 10 00010000 007c0000
[18:25:52]I (20) boot:  3 app1             OTA app          00 11 007d0000 007c0000
[18:25:52]I (21) boot:  4 nvs              WiFi data        01 02 00f90000 0006d000
[18:25:52]I (22) boot: End of partition table
[18:25:52]I (23) esp_image: segment 0: paddr=00010020 vaddr=40070020 size=30f90h (200592) map
[18:25:52]I (53) esp_image: segment 1: paddr=00040fb8 vaddr=30100000 size=00068h (   104) load
[18:25:52]I (54) esp_image: segment 2: paddr=00041028 vaddr=4ff00000 size=0c268h ( 49768) load
[18:25:52]I (64) esp_image: segment 3: paddr=0004d298 vaddr=4ff0c280 size=02b30h ( 11056) load
[18:25:52]I (67) esp_image: segment 4: paddr=0004fdd0 vaddr=00000000 size=00248h (   584)
[18:25:52]I (68) esp_image: segment 5: paddr=00050020 vaddr=40000020 size=67d70h (425328) map
[18:25:52]I (131) boot: Loaded app from partition at offset 0x10000
[18:25:52]I (132) boot: Disabling RNG early entropy source...
[18:25:53][I][logger:121]: Log initialized
[18:25:53][C][safe_mode:118]: Unsuccessful boot attempts: 3
[18:25:53][D][esp32.preferences:155]: Writing 1 items: 0 cached, 1 written, 0 failed
[18:25:53][I][app:087]: Running through setup()
[18:25:53][D][esp_ldo:020]: Acquired LDO channel 3 with voltage 2.500000V
[18:25:56][C][wifi:475]: Starting
[18:25:56][I][wifi:529]: Starting fast_connect (config) 'NETWORK5_IOT'[redacted]
[18:25:56][I][wifi:899]: Connecting to 'NETWORK5_IOT'[redacted] (any)[redacted] (priority 0, attempt 1/1 in phase INITIAL_CONNECT)...
[18:25:56][C][component:249]: Setup wifi took 2343ms
[18:25:56][W][component:386]: api set Warning flag: unspecified
[18:25:56][I][app:134]: setup() finished successfully!
[18:25:56][W][component:395]: wifi set Warning flag: associating to network
[18:25:56][I][app:206]: ESPHome version 2026.1.2 compiled on 2026-01-26 18:20:51 -0600
[18:25:56][I][app:213]: ESP32 Chip: ESP32-P4 r1.3, 2 core(s)
[18:25:56][C][logger:316]: Logger:
[18:25:56][C][logger:316]:  Max Level: DEBUG
[18:25:56][C][logger:316]:  Initial Level: DEBUG
[18:25:56][C][logger:322]:   Log Baud Rate: 115200
[18:25:56][C][logger:322]:  Hardware UART: USB_SERIAL_JTAG
[18:25:56][C][logger:332]:   Task Log Buffer Size: 768 bytes
[18:25:56][C][esp_ldo:024]: ESP LDO Channel 3:
[18:25:56][C][esp_ldo:024]:  Voltage: 2.500000V
[18:25:56][C][esp_ldo:024]:  Adjustable: NO
[18:25:56][C][psram:016]: PSRAM:
[18:25:56][C][psram:019]:   Available: YES
[18:25:56][C][psram:021]:   Size: 32768 KB
[18:25:56][C][wifi:1304]: WiFi:
[18:25:56][C][wifi:1304]:  Local MAC: 30:ED:A0:EA:6E:0D
[18:25:56][C][wifi:1304]:  Connected: NO
[18:25:56][C][sntp:059]: SNTP Time:
[18:25:56][C][sntp:062]:   Server 0: '0.pool.ntp.org'
[18:25:56][C][sntp:062]:   Server 1: '1.pool.ntp.org'
[18:25:56][C][sntp:062]:   Server 2: '2.pool.ntp.org'
[18:25:56][C][time:028]: Timezone: 'CST6CDT,M3.2.0,M11.1.0'
[18:25:56][C][esphome.ota:075]: Over-The-Air updates:
[18:25:56][C][esphome.ota:075]:  Address: p4-esp.local:3232
[18:25:56][C][esphome.ota:075]:  Version: 2
[18:25:56][C][esphome.ota:082]:   Password configured
[18:25:56][C][safe_mode:021]: Safe Mode:
[18:25:56][C][safe_mode:021]:  Successful after: 60s
[18:25:56][C][safe_mode:021]:  Invoke after: 10 attempts
[18:25:56][C][safe_mode:021]:  Duration: 300s
[18:25:56][C][safe_mode:038]:   Bootloader rollback: support unknown
[18:25:56][W][safe_mode:044]: Last reset too quick; invoke in 7 restarts
[18:25:56][C][api:221]: Server:
[18:25:56][C][api:221]:  Address: p4-esp.local:6053
[18:25:56][C][api:221]:  Listen backlog: 4
[18:25:56][C][api:221]:  Max connections: 8
[18:25:56][C][api:233]:   Noise encryption: NO
[18:25:56][C][mdns:177]: mDNS:
[18:25:56][C][mdns:177]:  Hostname: p4-esp
[18:26:02][W][wifi_esp32:771]: Disconnected ssid='NETWORK5_IOT' bssid=22:61:B4:CC:68:FC[redacted] reason='Auth Expired'
[18:26:02][W][wifi:1397]: Connecting to network failed (callback)
[18:26:02][D][wifi:1563]: Retry phase: INITIAL_CONNECT → SCAN_CONNECTING
[18:26:02][D][wifi:1098]: Starting scan
[18:26:05][D][wifi:1227]: Found networks:
[18:26:05][I][wifi:1188]: - 'NETWORK5_IOT' (22:61:B4:CC:68:FC) [redacted]▂▄▆█ Ch: 1 -82dB P:0
[18:26:05][D][wifi:1259]: - 3 non-matching (VERBOSE to show)
[18:26:05][I][wifi:899]: Connecting to 'NETWORK5_IOT'[redacted] (22:61:B4:CC:68:FC)[redacted] (priority 0, attempt 1/2 in phase SCAN_CONNECTING)...
[18:26:05][W][component:543]: wifi took a long time for an operation (75 ms)
[18:26:05][W][component:546]: Components should block for at most 30 ms
[18:26:12][W][wifi_esp32:771]: Disconnected ssid='NETWORK5_IOT' bssid=22:61:B4:CC:68:FC[redacted] reason='Auth Expired'
[18:26:12][W][wifi:1397]: Connecting to network failed (callback)
[18:26:12][D][wifi:1743]: Failed 'NETWORK5_IOT'[redacted] (22:61:B4:CC:68:FC)[redacted], priority 0 → 0
[18:26:12][D][wifi:1814]: Retry attempt 2/2 in phase SCAN_CONNECTING
[18:26:12][I][wifi:899]: Connecting to 'NETWORK5_IOT'[redacted] (22:61:B4:CC:68:FC)[redacted] (priority 0, attempt 2/2 in phase SCAN_CONNECTING)...
[18:26:19][W][wifi_esp32:771]: Disconnected ssid='NETWORK5_IOT' bssid=22:61:B4:CC:68:FC[redacted] reason='Auth Expired'
[18:26:19][W][wifi:1397]: Connecting to network failed (callback)
[18:26:19][D][wifi:1743]: Failed 'NETWORK5_IOT'[redacted] (22:61:B4:CC:68:FC)[redacted], priority 0 → -1
[18:26:19][D][wifi:408]: Skipping hidden retry for visible network 'NETWORK5_IOT'[redacted]
[18:26:19][D][wifi:1563]: Retry phase: SCAN_CONNECTING → RESTARTING
[18:26:19][W][wifi:566]: Restarting adapter
[18:26:19][W][wifi:1413]: Connecting to network failed
[18:26:19][D][wifi:1563]: Retry phase: RESTARTING → SCAN_CONNECTING
[18:26:19][D][wifi:1098]: Starting scan
[18:26:19][W][component:543]: wifi took a long time for an operation (108 ms)
[18:26:19][W][component:546]: Components should block for at most 30 ms
[18:26:19][W][component:543]: wifi took a long time for an operation (127 ms)
[18:26:19][W][wifi:1222]: No networks found
[18:26:19][D][wifi:1563]: Retry phase: SCAN_CONNECTING → RETRY_HIDDEN
[18:26:19][D][wifi:405]: Hidden candidate 'NETWORK5_IOT'[redacted] at index 0
[18:26:19][I][wifi:899]: Connecting to 'NETWORK5_IOT'[redacted] (any)[redacted] (priority 0, attempt 1/1 in phase RETRY_HIDDEN)...
[18:26:20][W][component:543]: wifi took a long time for an operation (160 ms)
[18:26:20][W][component:546]: Components should block for at most 30 ms
Just update to the latest version - 2026.1.2 - then you don’t need those. Though I always use fast_connect anyway, who wants a slow connect?
I did update to 1.2 before flashing this time and completely agree, I usually leave that in for all of mine. I had to double check these logs to make sure it was 1.2 and didn’t flash an older build. Any suggestions i can pursue?
I’ve flashed a P4 and will wait to see if it has any issues.
It seems fine, but it’s not trying to roam.
[14:52:31.030][I][safe_mode:066]: Boot seems successful; resetting boot loop counter
[14:56:41.482][V][wifi:2107]: Roam check skipped, signal good (-31 dBm, attempt 1/3)
[15:01:41.479][V][wifi:2107]: Roam check skipped, signal good (-31 dBm, attempt 2/3)
Sounds good. Thank you for the replies. I’ll investigate further as it seems like it may be a hardware problem for me.
I have the Waveshare 86 panel, which is the same P4+C6 combination as the OP’s board but has a screen. Thought I would brain dump somethings I was looking at tonight.
Product:
Versions:
ESPHome version is: 2026.1.2
Slave C6 firmware was manually compiled with IDF 5.5.2 and updated from the P4 with the host_performs_slave_ota example from ESP-IDF. The master’s firmware was also compiled with the same IDF version.
I (2438) host_performs_slave_ota: Host firmware version: 2.11.5
I (2438) host_performs_slave_ota: Slave firmware version: 2.11.3
I (2440) host_performs_slave_ota: Versions compatible - OTA not required
I am seeing these errors and the wifi would only intermittently connect once in a blue moon. That too only after freshly flashing firmware from ESPHome.
Troubleshooting steps:
  1. Used different USB C-C, A-C cables of various lengths
  2. Used different AC power adapters, computers, power banks, power strips to power the device. All capable of providing >60W on type C.
  3. Tested above combinations with both Type C ports on the device (UART and OTG ports)
  4. Disabled WiFi fast_connect and the device will not connect, even intermittently.
  5. Pinned this device in my WiFi mesh AP settings to one node, disabled roaming and force to connect to 2.4GHz (TP-Link Deco)
Config:
esphome:
  friendly_name: WaveShare P4 Box
  name_add_mac_suffix: false
esp32:
  board: esp32-p4-devboard
  flash_size: 32MB
  framework:
    type: esp-idf
    version: recommended
    advanced:
logger:
  level: debug
  logs:
    lvgl: info
web_server:
  port: 80
  version: 3
psram:
  speed: 200MHz
esp_ldo:
  - channel: 3
    voltage: 2.7V
button:
  - platform: restart
    name: "WaveShare P4 Box"
# Connectivity
esp32_hosted:
  active_high: True
  variant: ESP32C6
  reset_pin: GPIO54
  cmd_pin: GPIO19
  clk_pin: GPIO18
  d0_pin: GPIO14
  d1_pin: GPIO15
  d2_pin: GPIO16
  d3_pin: GPIO17
wifi:
  fast_connect: True
  networks:
    - ssid: "IoT"
      password: "12345678"
Errors:
[09:14:50][C][wifi:475]: Starting
[09:14:50][D][wifi:1960]: Loaded fast_connect settings
[09:14:50][I][wifi:525]: Starting fast_connect (saved) 'IoT'[redacted]
[09:14:50][I][wifi:899]: Connecting to 'IoT'[redacted] (52:22:54:DF:A9:95)[redacted] (priority 0, attempt 1/1 in phase INITIAL_CONNECT)...
[09:14:50][C][component:249]: Setup wifi took 2601ms
[09:14:50][W][component:386]: api set Warning flag: unspecified
[09:14:50][I][app:134]: setup() finished successfully!
[09:14:50][W][wifi_esp32:771]: Disconnected ssid='IoT' bssid=52:22:54:DF:A9:95[redacted] reason='Association Leave'
[09:14:50][W][component:395]: wifi set Warning flag: associating to network
[09:14:50][W][wifi:1397]: Connecting to network failed (callback)
[09:14:50][D][wifi:1563]: Retry phase: INITIAL_CONNECT → SCAN_CONNECTING
[09:14:50][D][wifi:1098]: Starting scan
[09:14:51][W][component:543]: wifi took a long time for an operation (165 ms)
[09:14:51][W][component:546]: Components should block for at most 30 ms
[09:14:51][W][component:543]: lvgl took a long time for an operation (83 ms)
[09:14:51][I][app:206]: ESPHome version 2026.1.2 compiled on 2026-01-27 21:54:49 -0600
[09:14:51][I][app:213]: ESP32 Chip: ESP32-P4 r1.0, 2 core(s)
[09:15:21][E][wifi:1213]: Scan timeout
[09:15:21][D][wifi:1563]: Retry phase: SCAN_CONNECTING → RETRY_HIDDEN
[09:15:21][D][wifi:405]: Hidden candidate 'IoT'[redacted] at index 0
[09:15:21][I][wifi:899]: Connecting to 'IoT'[redacted] (any)[redacted] (priority 0, attempt 1/1 in phase RETRY_HIDDEN)...
[09:15:22][W][wifi_esp32:771]: Disconnected ssid='IoT' bssid=52:22:54:DF:A9:95[redacted] reason='Association Leave'
[09:15:22][W][wifi:1397]: Connecting to network failed (callback)
[09:15:22][D][wifi:1563]: Retry phase: RETRY_HIDDEN → RESTARTING
[09:15:22][W][wifi:566]: Restarting adapter
[09:15:22][W][component:543]: wifi took a long time for an operation (438 ms)
[09:15:22][W][component:546]: Components should block for at most 30 ms
[09:15:22][W][wifi:1413]: Connecting to network failed
[09:15:22][D][wifi:1563]: Retry phase: RESTARTING → SCAN_CONNECTING
[09:15:22][D][wifi:1098]: Starting scan
[09:15:23][W][wifi:1222]: No networks found
[09:15:23][D][wifi:1563]: Retry phase: SCAN_CONNECTING → RETRY_HIDDEN
[09:15:23][D][wifi:405]: Hidden candidate 'IoT'[redacted] at index 0
[09:15:23][I][wifi:899]: Connecting to 'IoT'[redacted] (any)[redacted] (priority 0, attempt 1/1 in phase RETRY_HIDDEN)...
[09:15:23][W][component:543]: wifi took a long time for an operation (645 ms)
[09:15:23][W][component:546]: Components should block for at most 30 ms
[09:15:23][W][wifi_esp32:771]: Disconnected ssid='IoT' bssid=00:00:00:00:00:00[redacted] reason='Unspecified'
[09:15:23][W][wifi:1397]: Connecting to network failed (callback)
[09:15:23][D][wifi:1563]: Retry phase: RETRY_HIDDEN → RESTARTING
[09:15:23][W][wifi:566]: Restarting adapter
[09:15:24][W][wifi:1413]: Connecting to network failed
[09:15:24][D][wifi:1563]: Retry phase: RESTARTING → SCAN_CONNECTING
[09:15:24][D][wifi:1098]: Starting scan
[09:15:24][W][wifi:1222]: No networks found
From the circuit diagram (PDF) of the board (relevant sections below), it seems like ESP_LDO_VO1 is tied directly to the ESP_3V3 net. On the ESP32-C6-MINI Schematic, the C6 (U1) receives its power at Pin 3 (3V3). This pin is also connected to the ESP_3V3 net.
So to me it looks like setting the LDO channel #3 on the P4 should not work to boost voltage for the C6 to the required voltage for the C6 to function as channel #3 is used for the MIPI screen.
From the docs, it seems like we can not control channel1 LDO either.
My preliminary testing seems to be a bit contradictory to the above as setting the voltage to the max 2.7V allowable level seems to have helped the connectivity a bit. I still get scan timeouts when first booting up but the device now at least connects reliably to wifi.
It looks like my original issue was hardware. I soldered a new module to a new board and I am now communicating with no problems.
Something I notice, it didn’t matter if I had the LDO config or not, the C6 connected at the same strength regardless.
So 24 hours have passed and I have done tens of OTA updates with LVGL and so far the device has not failed to connect to wifi yet.
