Just started running into a new issue. Iβm getting SDmmc_common errors now.
CONFIG:
esphome:
friendly_name: P4-ESP
esp32:
variant: esp32p4
flash_size: 16MB
framework:
type: esp-idf
advanced:
enable_idf_experimental_features: true
cpu_frequency: 360MHz
psram:
mode: hex
speed: 200MHz
preferences:
flash_write_interval: 5min
esp_ldo:
- voltage: 2.7V
channel: 3
- voltage: 2.7V
channel: 4
esp32_hosted:
variant: ESP32C6
reset_pin: GPIO54
cmd_pin: GPIO19
clk_pin: GPIO18
d0_pin: GPIO14
d1_pin: GPIO15
d2_pin: GPIO16
d3_pin: GPIO17
active_high: true
logger:
level: DEBUG
logs:
sensor: INFO
switch: INFO
switch.gpio: INFO
gpio.switch: INFO
binary_sensor: INFO
binary_sensor.gpio: INFO
switch.binary_sensor: INFO
binary_sensor.switch: INFO
gpio.binary_sensor: INFO
# hardware_uart: UART0
api:
ota:
- platform: esphome
password: "3cb5b7d2ba8284dac9231fca1ef39c52"
wifi:
ssid: !secret wifi_ssid
power_save_mode: NONE
reboot_timeout: 0s
fast_connect: True
post_connect_roaming: False
LOGS:
[09:27:53.036][I][logger:121]: Log initialized
[09:27:53.037][C][safe_mode:118]: Unsuccessful boot attempts: 0
[09:27:53.042][D][esp32.preferences:155]: Writing 1 items: 0 cached, 1 written, 0 failed
[09:27:53.042][I][app:087]: Running through setup()
[09:27:53.042][D][esp_ldo:020]: Acquired LDO channel 3 with voltage 2.700000V
[09:27:53.046][D][esp_ldo:020]: Acquired LDO channel 4 with voltage 2.700000V
[09:27:54.594][D][esp-idf:000]: E (1650) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
[09:27:54.594][D][esp-idf:000]: E (1650) sdio_wrapper: sdmmc_card_init failed
[09:27:54.723][D][esp-idf:000]: E (1778) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
[09:27:54.723][D][esp-idf:000]: E (1779) sdio_wrapper: sdmmc_card_init failed
[09:27:54.852][D][esp-idf:000]: E (1907) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
[09:27:54.852][D][esp-idf:000]: E (1908) sdio_wrapper: sdmmc_card_init failed
[09:27:54.980][D][esp-idf:000]: E (2036) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
[09:27:54.980][D][esp-idf:000]: E (2037) sdio_wrapper: sdmmc_card_init failed
[09:27:55.111][D][esp-idf:000]: E (2165) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
[09:27:55.111][D][esp-idf:000]: E (2166) sdio_wrapper: sdmmc_card_init failed
[09:27:55.238][D][esp-idf:000]: E (2294) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
[09:27:55.238][D][esp-idf:000]: E (2295) sdio_wrapper: sdmmc_card_init failed
[09:27:55.368][D][esp-idf:000]: E (2423) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
[09:27:55.372][D][esp-idf:000]: E (2424) sdio_wrapper: sdmmc_card_init failed
[09:27:55.496][D][esp-idf:000]: E (2552) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
[09:27:55.496][D][esp-idf:000]: E (2553) sdio_wrapper: sdmmc_card_init failed
[09:27:55.626][D][esp-idf:000]: E (2681) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
[09:27:55.626][D][esp-idf:000]: E (2682) sdio_wrapper: sdmmc_card_init failed
[09:27:55.754][D][esp-idf:000]: E (2810) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
[09:27:55.754][D][esp-idf:000]: E (2811) sdio_wrapper: sdmmc_card_init failed
[09:27:55.884][D][esp-idf:000]: E (2939) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
[09:27:55.884][D][esp-idf:000]: E (2940) sdio_wrapper: sdmmc_card_init failed
[09:27:56.013][D][esp-idf:000]: E (3068) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
[09:27:56.014][D][esp-idf:000]: E (3069) sdio_wrapper: sdmmc_card_init failed
[09:27:56.142][D][esp-idf:000]: E (3197) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
[09:27:56.142][D][esp-idf:000]: E (3198) sdio_wrapper: sdmmc_card_init failed
[09:27:56.270][D][esp-idf:000]: E (3326) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
[09:27:56.271][D][esp-idf:000]: E (3327) sdio_wrapper: sdmmc_card_init failed
[09:27:56.399][D][esp-idf:000]: E (3455) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
[09:27:56.399][D][esp-idf:000]: E (3456) sdio_wrapper: sdmmc_card_init failed
[09:27:56.501][D][esp-idf:000]: E (3557) H_SDIO_DRV: card init failed
[09:27:56.501][D][esp-idf:000]: E (3558) transport: ensure_slave_bus_ready failed
[09:27:56.501]_t 0xffffffff (ESP_FAIL) at 0x400000b2
[09:27:56.501]file: "managed_components/espressif__esp_hosted/host/api/src/esp_hosted_api.c" line 156
[09:27:56.501]func: esp_hosted_reconfigure
[09:27:56.505]expression: transport_drv_reconfigure()
[09:27:56.505][D][esp-idf:000]: E (3561) H_API: ESP-Hosted link not yet up
[09:27:56.505][E][wifi_esp32:184]: esp_wifi_init failed: ESP_FAIL
[09:27:56.505][C][wifi:475]: Starting
[09:27:56.509][D][esp-idf:000]: E (3562) H_API: ESP-Hosted link not yet up
[09:27:56.509][W][wifi_esp32:247]: esp_wifi_set_mode failed: ESP_FAIL
[09:27:56.509][D][esp-idf:000]: E (3563) H_API: ESP-Hosted link not yet up
[09:27:56.509][I][wifi:529]: Starting fast_connect (config) [redacted]
[09:27:56.509][I][wifi:899]: Connecting to [redacted] [redacted] (priority 0, attempt 1/1 in phase INITIAL_CONNECT)...
[09:27:56.509][D][esp-idf:000]: E (3566) H_API: ESP-Hosted link not yet up
[09:27:56.513][W][wifi_esp32:247]: esp_wifi_set_mode failed: ESP_FAIL
[09:27:56.513][E][wifi:976]: wifi_sta_connect_ failed
[09:27:56.513][C][component:249]: Setup wifi took 3466ms
[09:27:56.513][W][component:386]: api set Warning flag: unspecified
[09:27:56.513][I][app:134]: setup() finished successfully!
[09:27:56.513][W][component:395]: wifi set Warning flag: waiting to reconnect
[09:27:56.517][I][app:206]: ESPHome version 2026.1.3 compiled on 2026-02-01 09:26:39 -0600
[09:27:56.517][I][app:213]: ESP32 Chip: ESP32-P4 r1.3, 2 core(s)
[09:27:56.517][C][logger:316]: Logger:
[09:27:56.517][C][logger:316]: Max Level: DEBUG
[09:27:56.517][C][logger:316]: Initial Level: DEBUG
[09:27:56.517][C][logger:322]: Log Baud Rate: 115200
[09:27:56.517][C][logger:322]: Hardware UART: USB_SERIAL_JTAG
[09:27:56.521][C][logger:332]: Task Log Buffer Size: 768 bytes
[09:27:56.521][C][logger:339]: Level for 'binary_sensor': INFO
[09:27:56.521][C][logger:339]: Level for 'binary_sensor.gpio': INFO
[09:27:56.521][C][logger:339]: Level for 'binary_sensor.switch': INFO
[09:27:56.521][C][logger:339]: Level for 'gpio.binary_sensor': INFO
[09:27:56.521][C][logger:339]: Level for 'gpio.switch': INFO
[09:27:56.522][C][logger:339]: Level for 'sensor': INFO
[09:27:56.522][C][logger:339]: Level for 'switch': INFO
[09:27:56.522][C][logger:339]: Level for 'switch.binary_sensor': INFO
[09:27:56.522][C][logger:339]: Level for 'switch.gpio': INFO
[09:27:56.540][C][esp_ldo:024]: ESP LDO Channel 3:
[09:27:56.540][C][esp_ldo:024]: Voltage: 2.700000V
[09:27:56.540][C][esp_ldo:024]: Adjustable: NO
[09:27:56.548][C][esp_ldo:024]: ESP LDO Channel 4:
[09:27:56.548][C][esp_ldo:024]: Voltage: 2.700000V
[09:27:56.548][C][esp_ldo:024]: Adjustable: NO
[09:27:56.558][C][psram:016]: PSRAM:
[09:27:56.558][C][psram:019]: Available: YES
[09:27:56.558][C][psram:021]: Size: 32768 KB
[09:27:56.565][C][wifi:1304]: WiFi:
[09:27:56.565][C][wifi:1304]: Local MAC: 30:ED:A0:EA:6E:05
[09:27:56.566][C][wifi:1304]: Connected: NO
[09:27:56.577][C][esphome.ota:075]: Over-The-Air updates:
[09:27:56.577][C][esphome.ota:075]: Address: p4-esp.local:3232
[09:27:56.577][C][esphome.ota:075]: Version: 2
[09:27:56.577][C][esphome.ota:082]: Password configured
[09:27:56.582][C][safe_mode:021]: Safe Mode:
[09:27:56.582][C][safe_mode:021]: Successful after: 60s
[09:27:56.582][C][safe_mode:021]: Invoke after: 10 attempts
[09:27:56.582][C][safe_mode:021]: Duration: 300s
[09:27:56.582][C][safe_mode:038]: Bootloader rollback: support unknown
[09:27:56.596][C][api:221]: Server:
[09:27:56.596][C][api:221]: Address: p4-esp.local:6053
[09:27:56.596][C][api:221]: Listen backlog: 4
[09:27:56.596][C][api:221]: Max connections: 8
[09:27:56.596][C][api:233]: Noise encryption: NO
[09:27:56.600][C][mdns:177]: mDNS:
[09:27:56.600][C][mdns:177]: Hostname: p4-esp
[09:27:57.022][W][wifi:1418]: Unknown connection status 0
[09:27:57.022][D][wifi:1563]: Retry phase: INITIAL_CONNECT β SCAN_CONNECTING
[09:27:57.022][D][wifi:1098]: Starting scan
[09:27:57.026][D][esp-idf:000]: E (4081) H_API: ESP-Hosted link not yet up
[09:27:57.026][W][wifi_esp32:247]: esp_wifi_set_mode failed: ESP_FAIL
[09:28:28.028][E][wifi:1213]: Scan timeout
[09:28:28.028][D][wifi:1563]: Retry phase: SCAN_CONNECTING β RETRY_HIDDEN
[09:28:28.028][D][wifi:405]: Hidden candidate [redacted] at index 0
[09:28:28.033][I][wifi:899]: Connecting to [redacted] [redacted] (priority 0, attempt 1/1 in phase RETRY_HIDDEN)...
[09:28:28.033][D][esp-idf:000]: E (35085) H_API: ESP-Hosted link not yet up
[09:28:28.033][W][wifi_esp32:247]: esp_wifi_set_mode failed: ESP_FAIL
[09:28:28.033][E][wifi:976]: wifi_sta_connect_ failed
[09:28:28.542][W][wifi:1418]: Unknown connection status 0
[09:28:28.543][D][wifi:1563]: Retry phase: RETRY_HIDDEN β RESTARTING
[09:28:28.543][W][wifi:566]: Restarting adapter
[09:28:29.053][W][wifi:1418]: Unknown connection status 0
[09:28:29.053][D][wifi:1563]: Retry phase: RESTARTING β SCAN_CONNECTING
[09:28:29.053][D][wifi:1098]: Starting scan
[09:28:29.057][D][esp-idf:000]: E (36109) H_API: ESP-Hosted link not yet up
[09:28:29.057][W][wifi_esp32:247]: esp_wifi_set_mode failed: ESP_FAIL
[09:28:53.043][I][safe_mode:066]: Boot seems successful; resetting boot loop counter
[09:29:00.063][E][wifi:1213]: Scan timeout
[09:29:00.063][D][wifi:1563]: Retry phase: SCAN_CONNECTING β RETRY_HIDDEN
[09:29:00.063][D][wifi:405]: Hidden candidate [redacted] at index 0
[09:29:00.063][I][wifi:899]: Connecting to [redacted] [redacted] (priority 0, attempt 1/1 in phase RETRY_HIDDEN)...
[09:29:00.067][D][esp-idf:000]: E (67120) H_API: ESP-Hosted link not yet up
[09:29:00.067][W][wifi_esp32:247]: esp_wifi_set_mode failed: ESP_FAIL
[09:29:00.067][E][wifi:976]: wifi_sta_connect_ failed
[09:29:00.577][W][wifi:1418]: Unknown connection status 0
[09:29:00.577][D][wifi:1563]: Retry phase: RETRY_HIDDEN β RESTARTING
[09:29:00.577][W][wifi:566]: Restarting adapter
[09:29:01.087][W][wifi:1418]: Unknown connection status 0
[09:29:01.087][D][wifi:1563]: Retry phase: RESTARTING β SCAN_CONNECTING
[09:29:01.087][D][wifi:1098]: Starting scan
[09:29:01.087][D][esp-idf:000]: E (68143) H_API: ESP-Hosted link not yet up
[09:29:01.091][W][wifi_esp32:247]: esp_wifi_set_mode failed: ESP_FAIL
[09:29:32.098][E][wifi:1213]: Scan timeout
[09:29:32.102][D][wifi:1563]: Retry phase: SCAN_CONNECTING β RETRY_HIDDEN
[09:29:32.102][D][wifi:405]: Hidden candidate [redacted] at index 0
[09:29:32.102][I][wifi:899]: Connecting to [redacted] [redacted] (priority 0, attempt 1/1 in phase RETRY_HIDDEN)...
[09:29:32.102][D][esp-idf:000]: E (99154) H_API: ESP-Hosted link not yet up
[09:29:32.102][W][wifi_esp32:247]: esp_wifi_set_mode failed: ESP_FAIL
[09:29:32.102][E][wifi:976]: wifi_sta_connect_ failed
[09:29:32.612][W][wifi:1418]: Unknown connection status 0
[09:29:32.612][D][wifi:1563]: Retry phase: RETRY_HIDDEN β RESTARTING
[09:29:32.612][W][wifi:566]: Restarting adapter
[09:29:33.123][W][wifi:1418]: Unknown connection status 0
[09:29:33.123][D][wifi:1563]: Retry phase: RESTARTING β SCAN_CONNECTING
[09:29:33.123][D][wifi:1098]: Starting scan
[09:29:33.127][D][esp-idf:000]: E (100177) H_API: ESP-Hosted link not yet up
[09:29:33.127][W][wifi_esp32:247]: esp_wifi_set_mode failed: ESP_FAIL
Any guidance on where I should be looking? So far, I havenβt been able to find anything relating to this online for not having and SD configuration. Maybe I just need a break for a while here, been too many hours working on this P4.
Thanks for anything,
DaviBoi
