I builded up a board which should capture data from two smart meters over two separate UART interfaces. Data from smart meters is read out with two “Hichi TTL - IR Lesekopf”.
Problem is, that I only get data from one smart meter. It looks like it is only possible to use one UART.
I’ve cross-changed everything, so in general it should not be a hardware problem. I always only get data from smart meter that is connected to “uart_01”. Where is my mistake in following (reduced) configuration?
uart:
- id: uart_01
rx_pin: 17
baud_rate: 9600
data_bits: 8
parity: NONE
stop_bits: 1
- id: uart_02
rx_pin: 25
baud_rate: 9600
data_bits: 8
parity: NONE
stop_bits: 1
sml:
- id: sml_01
uart_id: uart_01
- id: sml_02
uart_id: uart_02
# ----------- SML Z1 -----------
- platform: sml
name: "Z1 Gesamtbezug"
sml_id: sml_01
#server_id: "0123456789abcdef"
obis_code: "1-0:1.8.0"
unit_of_measurement: kWh
accuracy_decimals: 1
state_class: total_increasing
device_class: energy
filters:
- multiply: 0.0001
- platform: sml
name: "Z1 Leistung"
sml_id: sml_01
obis_code: "1-0:16.7.0"
unit_of_measurement: W
accuracy_decimals: 0
state_class: measurement
device_class: power
# ----------- SML Z2 -----------
- platform: sml
name: "Z2 Gesamtbezug"
sml_id: sml_02
filters:
- multiply: 0.0001
- platform: sml
name: "Z2 Leistung"
sml_id: sml_02
device_class: power
With this configuration I only get data from “Z1”, (first meter). If I change rx pins (uart_01 - pin 25, uart_02 - pin 17) I get data from “Z2” (second meter).
Thank you
