Starting a couple days ago I can no longer get my esp32-box3 to connect to the internet and find home assistant. It doesn’t respond to pings as well. I’ve tried to reset the device as well reinstall the config several times. I’ve also placed the device near the router just incase it was a signal issue but it still will not connect. I’ve even set up a new wireless network and tried having it connect to that but same results.
Heres the config
and here is the log
I’ve tried resetting and reinstalling a dozen times, I even created a new network with just 2.4ghz but it is always the same. It will also seemingly reboot on its own, find home assistant just briefly and then go back offline.
This is on HASSOS running in virtmanager on ubuntu
