I am new to displays on the ESP32. I have made a few simple projects using esp32-c3 and a pn532 RFID reader, and thought I was ready to tackle a display. After getting everything wired up and “Hello World!” displaying on the screen using lambda I was ecstatic, then I tried to get LVGL to work and hit a brick wall. Much searching and trials later I still cannot get it to work. so I am hoping that someone can tell me where I am messing up.
here is my setup:
esphome on a docker updated to the latest image.
ESP: ESP32-S3-N16R8
Display: SH1106 with a EC11 encoder (I2C Bus A)
Load Cell: 5K connected through a hx711
RFID/NFC reader: pn532 (I2C Bus B)
Code that works using lambda
esphome:
friendly_name: DryBox RFID Screen
platformio_options:
board_build.arduino.memory_type: qio_opi
board_build.flash_mode: qio
build_flags:
- "-DCONFIG_SPIRAM_CACHE_WORKAROUND"
- "-mfix-esp32-psram-cache-issue"
esp32:
board: esp32-s3-devkitc-1
variant: esp32s3
flash_size: 16MB
framework:
type: esp-idf
sdkconfig_options:
CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
CONFIG_SPIRAM_FETCH_INSTRUCTIONS: y
CONFIG_SPIRAM_RODATA: y
psram:
mode: octal
speed: 80MHz
globals:
- id: source
type: std::string
- id: url
type: std::string
- id: info
type: std::string
- id: conversion_number
type: float
restore_value: no
initial_value: '0.0'
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: Retracted
ota:
- platform: esphome
password: Retracted
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Drybox-Rfid-Screen"
password: Retracted
captive_portal:
font:
# gfonts://family[@weight]
- file: "gfonts://Roboto"
i2c:
- id: bus_a
sda: GPIO16
scl: GPIO15
scan: true
- id: bus_b
sda: GPIO08
scl: GPIO09
scan: true
switch:
name: "${friendly_name} Buzzer Enabled"
icon: mdi:volume-high
optimistic: true
restore_mode: RESTORE_DEFAULT_ON
entity_category: config
name: "${friendly_name} LED enabled"
icon: mdi:alarm-light-outline
optimistic: true
display:
- platform: ssd1306_i2c
i2c_id: bus_a
model: "SH1106 128x64"
address: 0x3C
lambda: |-
// Print the string "Hello World!" at [0,10]
it.print(0, 10, id(roboto_20), "Hello World!");
pn532_i2c:
i2c_id: bus_b
update_interval: 1s
on_tag:
then:
- if:
condition:
switch.is_on: led_enabled
then:
- light.turn_on:
brightness: 100%
red: 0%
green: 100%
blue: 0%
flash_length: 500ms
- delay: 0.15s #to fix slow component
- lambda: |-
id(source)="";
id(url)="";
id(info)="";
if (tag.has_ndef_message())
auto message = tag.get_ndef_message();
auto records = message->get_records();
for (auto &record : records)
std::string payload = record->get_payload();
std::string type = record->get_type();
size_t box = payload.find("Box");
size_t spool = payload.find("Spool");
if (type == "U" and box != std::string::npos )
ESP_LOGD("tagreader", "Found Box tag NDEF");
id(source)="Box";
id(url)=payload;
else if (type == "U" and spool != std::string::npos )
id(source)="Spool";
id(url)=payload;
else if (type == "T" )
ESP_LOGD("tagreader", "Found music info tag NDEF");
id(info)=payload;
else if ( id(source)=="" )
id(source)="uid";
else
id(source)="uid";
- if:
condition:
lambda: 'return ( id(source)=="uid" );'
then:
- homeassistant.tag_scanned: !lambda |-
ESP_LOGD("tagreader", "No HA NDEF, using UID");
return x;
else:
- if:
condition:
lambda: 'return ( id(source)=="hass" );'
then:
- homeassistant.tag_scanned: !lambda 'return id(info);'
else:
- homeassistant.event:
event: esphome.filament_tag
reader: !lambda |-
return App.get_name().c_str();
source: !lambda |-
return id(source);
url: !lambda |-
return id(url);
info: !lambda |-
return id(info);
- if:
condition:
switch.is_on: buzzer_enabled
then:
# - rtttl.play: "success:d=24,o=5,b=100:c,g,b"
light:
- platform: esp32_rmt_led_strip
rgb_order: GRB
rmt_symbols: 48
pin: GPIO48
num_leds: 1
chipset: ws2812
restore_mode: ALWAYS_OFF
- platform: hx711
dout_pin: GPIO11
clk_pin: GPIO10
gain: 128
update_interval: 1s
- platform: rotary_encoder
pin_a: GPIO05
pin_b: GPIO06
binary_sensor:
- platform: gpio
pin:
number: GPIO4
inverted: false
mode:
input: true
pullup: true
- platform: gpio
pin:
number: GPIO7
inverted: false
mode:
input: true
pullup: true
- platform: gpio
pin:
number: GPIO17
inverted: false
mode:
input: true
pullup: true
here is the log for the above code:
INFO ESPHome 2026.2.4
INFO Reading configuration /config/drybox-rfid-screen.yaml...
INFO Starting log output from drybox-rfid-screen.local using esphome API
INFO Successfully resolved drybox-rfid-screen.local in 0.179s
INFO Successfully connected to drybox-rfid-screen @ 192.168.120.167 in 0.011s
INFO Successful handshake with drybox-rfid-screen @ 192.168.120.167 in 0.059s
[19:05:41.253][I][app:215]: ESPHome version 2026.2.4 compiled on 2026-03-20 18:23:11 -0500
[19:05:41.253][I][app:222]: ESP32 Chip: ESP32-S3 rev0.2, 2 core(s)
[19:05:41.253][C][logger:237]: Logger:
[19:05:41.253][C][logger:237]: Max Level: DEBUG
[19:05:41.253][C][logger:237]: Initial Level: DEBUG
[19:05:41.253][C][logger:244]: Log Baud Rate: 115200
[19:05:41.253][C][logger:244]: Hardware UART: USB_SERIAL_JTAG
[19:05:41.254][C][logger:254]: Task Log Buffer Size: 768 bytes
[19:05:41.254][C][i2c.idf:093]: I2C Bus:
[19:05:41.254][C][i2c.idf:094]: SDA Pin: GPIO16
[19:05:41.254][C][i2c.idf:094]: SCL Pin: GPIO15
[19:05:41.254][C][i2c.idf:094]: Frequency: 50000 Hz
[19:05:41.254][C][i2c.idf:104]: Recovery: bus successfully recovered
[19:05:41.254][C][i2c.idf:114]: Results from bus scan:
[19:05:41.254][C][i2c.idf:120]: Found device at address 0x3C
[19:05:41.255][C][i2c.idf:093]: I2C Bus:
[19:05:41.255][C][i2c.idf:094]: SDA Pin: GPIO8
[19:05:41.255][C][i2c.idf:094]: SCL Pin: GPIO9
[19:05:41.255][C][i2c.idf:094]: Frequency: 50000 Hz
[19:05:41.258][C][i2c.idf:104]: Recovery: bus successfully recovered
[19:05:41.258][C][i2c.idf:114]: Results from bus scan:
[19:05:41.258][C][i2c.idf:120]: Found device at address 0x24
[19:05:41.273][C][esp32_rmt_led_strip:271]: ESP32 RMT LED Strip:
[19:05:41.273][C][esp32_rmt_led_strip:271]: Pin: 48
[19:05:41.274][C][esp32_rmt_led_strip:275]: RMT Symbols: 48
[19:05:41.274][C][esp32_rmt_led_strip:300]: RGB Order: GRB
[19:05:41.274][C][esp32_rmt_led_strip:300]: Max refresh rate: 0
[19:05:41.274][C][esp32_rmt_led_strip:300]: Number of LEDs: 1
[19:05:41.284][C][gpio.binary_sensor:016]: GPIO Binary Sensor 'Back Button'
[19:05:41.285][C][gpio.binary_sensor:152]: Pin: GPIO4
[19:05:41.285][C][gpio.binary_sensor:069]: Mode: interrupt
[19:05:41.294][C][gpio.binary_sensor:071]: Interrupt Type: ANY_EDGE
[19:05:41.295][C][gpio.binary_sensor:016]: GPIO Binary Sensor 'Encoder Push'
[19:05:41.295][C][gpio.binary_sensor:152]: Pin: GPIO7
[19:05:41.295][C][gpio.binary_sensor:069]: Mode: interrupt
[19:05:41.295][C][gpio.binary_sensor:071]: Interrupt Type: ANY_EDGE
[19:05:41.295][C][gpio.binary_sensor:016]: GPIO Binary Sensor 'Confirm Button'
[19:05:41.303][C][gpio.binary_sensor:152]: Pin: GPIO17
[19:05:41.303][C][gpio.binary_sensor:069]: Mode: interrupt
[19:05:41.303][C][gpio.binary_sensor:071]: Interrupt Type: ANY_EDGE
[19:05:41.324][C][light:091]: Light '${friendly_name} LED'
[19:05:41.324][C][light:094]: Default Transition Length: 1.0s
[19:05:41.324][C][light:094]: Gamma Correct: 2.80
[19:05:41.324][C][template.switch:092]: Template Switch '${friendly_name} Buzzer Enabled'
[19:05:41.324][C][template.switch:092]: Restore Mode: restore defaults to ON
[19:05:41.336][C][template.switch:157]: Icon: 'mdi:volume-high'
[19:05:41.337][C][template.switch:055]: Optimistic: YES
[19:05:41.337][C][template.switch:092]: Template Switch '${friendly_name} LED enabled'
[19:05:41.337][C][template.switch:092]: Restore Mode: restore defaults to ON
[19:05:41.349][C][template.switch:157]: Icon: 'mdi:alarm-light-outline'
[19:05:41.349][C][template.switch:055]: Optimistic: YES
[19:05:41.349][C][psram:016]: PSRAM:
[19:05:41.349][C][psram:019]: Available: YES
[19:05:41.349][C][psram:021]: Size: 8192 KB
[19:05:41.349][C][pn532:430]: PN532:
[19:05:41.354][C][pn532:488]: Update Interval: 1.0s
[19:05:41.354][C][pn532_i2c:125]: Address: 0x24
[19:05:41.364][C][hx711:017]: HX711 'HX711 Value'
[19:05:41.364][C][hx711:017]: State Class: 'measurement'
[19:05:41.364][C][hx711:017]: Unit of Measurement: ''
[19:05:41.364][C][hx711:017]: Accuracy Decimals: 0
[19:05:41.371][C][hx711:157]: Icon: 'mdi:scale'
[19:05:41.372][C][hx711:152]: DOUT Pin: GPIO11
[19:05:41.372][C][hx711:152]: SCK Pin: GPIO10
[19:05:41.372][C][hx711:488]: Update Interval: 1.0s
[19:05:41.372][C][rotary_encoder:017]: Rotary Encoder 'Rotary Encoder'
[19:05:41.372][C][rotary_encoder:017]: State Class: ''
[19:05:41.372][C][rotary_encoder:017]: Unit of Measurement: 'steps'
[19:05:41.372][C][rotary_encoder:017]: Accuracy Decimals: 0
[19:05:41.372][C][rotary_encoder:157]: Icon: 'mdi:rotate-right'
[19:05:41.379][C][rotary_encoder:152]: Pin A: GPIO5
[19:05:41.380][C][rotary_encoder:152]: Pin B: GPIO6
[19:05:41.380][C][rotary_encoder:178]: Restore Mode: Restore (Defaults to zero)
[19:05:41.421][C][rotary_encoder:182]: Resolution: 1 Pulse Per Cycle
[19:05:41.421][C][ssd1306_i2c:022]: I2C SSD1306
[19:05:41.421][C][ssd1306_i2c:022]: Rotations: 0 °
[19:05:41.421][C][ssd1306_i2c:022]: Dimensions: 128px x 64px
[19:05:41.422][C][ssd1306_i2c:023]: Model: SH1106 128x64
[19:05:41.422][C][ssd1306_i2c:023]: External VCC: NO
[19:05:41.422][C][ssd1306_i2c:023]: Flip X: YES
[19:05:41.422][C][ssd1306_i2c:023]: Flip Y: YES
[19:05:41.422][C][ssd1306_i2c:023]: Offset X: 0
[19:05:41.422][C][ssd1306_i2c:023]: Offset Y: 0
[19:05:41.422][C][ssd1306_i2c:023]: Inverted Color: NO
[19:05:41.424][C][ssd1306_i2c:033]: Address: 0x3C
[19:05:41.424][C][ssd1306_i2c:488]: Update Interval: 1.0s
[19:05:41.442][C][captive_portal:134]: Captive Portal:
[19:05:41.447][C][wifi:1450]: WiFi:
[19:05:41.447][C][wifi:1450]: Local MAC: E0:72:A1:FC:E3:30
[19:05:41.447][C][wifi:1450]: Connected: YES
[19:05:41.447][C][wifi:1202]: IP Address: 192.168.120.167
[19:05:41.447][C][wifi:1213]: SSID: [redacted]
[19:05:41.447][C][wifi:1213]: BSSID: [redacted]
[19:05:41.447][C][wifi:1213]: Hostname: 'drybox-rfid-screen'
[19:05:41.447][C][wifi:1213]: Signal strength: -48 dB ▂▄▆█
[19:05:41.447][C][wifi:1213]: Channel: 6
[19:05:41.447][C][wifi:1213]: Subnet: 255.255.255.0
[19:05:41.447][C][wifi:1213]: Gateway: 192.168.120.1
[19:05:41.447][C][wifi:1213]: DNS1: 192.168.120.1
[19:05:41.447][C][wifi:1213]: DNS2: 0.0.0.0
[19:05:41.687][C][esphome.ota:075]: Over-The-Air updates:
[19:05:41.687][C][esphome.ota:075]: Address: drybox-rfid-screen.local:3232
[19:05:41.687][C][esphome.ota:075]: Version: 2
[19:05:41.693][C][esphome.ota:082]: Password configured
[19:05:41.695][C][safe_mode:022]: Safe Mode:
[19:05:41.695][C][safe_mode:022]: Successful after: 60s
[19:05:41.695][C][safe_mode:022]: Invoke after: 10 attempts
[19:05:41.695][C][safe_mode:022]: Duration: 300s
[19:05:41.699][C][safe_mode:039]: Bootloader rollback: support unknown
[19:05:41.699][D][hx711:029]: 'HX711 Value': Got value 115774
[19:05:41.699][D][sensor:118]: 'HX711 Value' >> 115774
[19:05:41.705][C][web_server.ota:238]: Web Server OTA
[19:05:41.719][C][api:237]: Server:
[19:05:41.719][C][api:237]: Address: drybox-rfid-screen.local:6053
[19:05:41.719][C][api:237]: Listen backlog: 4
[19:05:41.719][C][api:237]: Max connections: 8
[19:05:41.719][C][api:244]: Noise encryption: YES
[19:05:41.722][C][mdns:177]: mDNS:
[19:05:41.722][C][mdns:177]: Hostname: drybox-rfid-screen
Code that shows Black Screen:
esphome:
platformio_options:
build_flags:
esp32:
variant: esp32s3
flash_size: 16MB
framework:
type: esp-idf
sdkconfig_options:
psram:
mode: octal
speed: 80MHz
globals:
- id: source
type: std::string
- id: url
type: std::string
- id: info
type: std::string
type: float
restore_value: no
# Enable logging
logger:
api:
encryption:
key: Retracted
ota:
- platform: esphome
password: Retracted
wifi:
ap:
password: Retracted
captive_portal:
font:
i2c:
- id: bus_a
sda: GPIO16
scl: GPIO15
scan: true
- id: bus_b
sda: GPIO08
scl: GPIO09
scan: true
switch:
optimistic: true
optimistic: true
lvgl:
log_level: "DEBUG"
# Example configuration entry
displays:
- my_display
pages:
- id: main_page
widgets:
- label:
align: CENTER
text: "Waiting for Updates..."
text_font: montserrat_10
long_mode: WRAP
display:
i2c_id: bus_a
address: 0x3C
auto_clear_enabled: false
update_interval: never
pn532_i2c:
i2c_id: bus_b
update_interval: 1s
on_tag:
then:
- if:
condition:
then:
- light.turn_on:
brightness: 100%
red: 0%
green: 100%
blue: 0%
flash_length: 500ms
- lambda: |-
id(source)="";
id(url)="";
id(info)="";
id(source)="Box";
id(url)=payload;
id(source)="Spool";
id(url)=payload;
id(info)=payload;
id(source)="uid";
else
id(source)="uid";
- if:
condition:
then:
return x;
else:
- if:
condition:
then:
else:
reader: !lambda |-
source: !lambda |-
return id(source);
url: !lambda |-
return id(url);
info: !lambda |-
return id(info);
- if:
condition:
then:
light:
rgb_order: GRB
rmt_symbols: 48
pin: GPIO48
num_leds: 1
chipset: ws2812
- platform: hx711
dout_pin: GPIO11
clk_pin: GPIO10
gain: 128
update_interval: 1s
pin_a: GPIO05
pin_b: GPIO06
binary_sensor:
- platform: gpio
pin:
number: GPIO4
inverted: false
mode:
input: true
pullup: true
- platform: gpio
pin:
number: GPIO7
inverted: false
mode:
input: true
pullup: true
- platform: gpio
pin:
number: GPIO17
inverted: false
mode:
input: true
pullup: true
Log for the code that gives a black screen
INFO Successfully connected to drybox-rfid-screen @ 192.168.120.167 in 5.118s
INFO Successful handshake with drybox-rfid-screen @ 192.168.120.167 in 0.074s
[19:28:21.502][I][app:215]: ESPHome version 2026.2.4 compiled on 2026-03-20 19:07:28 -0500
[19:28:21.502][I][app:222]: ESP32 Chip: ESP32-S3 rev0.2, 2 core(s)
[19:28:21.502][C][logger:237]: Logger:
[19:28:21.502][C][logger:237]: Max Level: DEBUG
[19:28:21.502][C][logger:237]: Initial Level: DEBUG
[19:28:21.513][C][logger:244]: Log Baud Rate: 115200
[19:28:21.513][C][logger:244]: Hardware UART: USB_SERIAL_JTAG
[19:28:21.513][C][logger:254]: Task Log Buffer Size: 768 bytes
[19:28:21.529][C][i2c.idf:093]: I2C Bus:
[19:28:21.536][C][i2c.idf:094]: SDA Pin: GPIO16
[19:28:21.536][C][i2c.idf:094]: SCL Pin: GPIO15
[19:28:21.536][C][i2c.idf:094]: Frequency: 50000 Hz
[19:28:21.537][C][i2c.idf:104]: Recovery: bus successfully recovered
[19:28:21.537][C][i2c.idf:114]: Results from bus scan:
[19:28:21.545][C][i2c.idf:120]: Found device at address 0x3C
[19:28:21.545][C][i2c.idf:093]: I2C Bus:
[19:28:21.545][C][i2c.idf:094]: SDA Pin: GPIO8
[19:28:21.545][C][i2c.idf:094]: SCL Pin: GPIO9
[19:28:21.545][C][i2c.idf:094]: Frequency: 50000 Hz
[19:28:21.545][C][i2c.idf:104]: Recovery: bus successfully recovered
[19:28:21.545][C][i2c.idf:114]: Results from bus scan:
[19:28:21.545][C][i2c.idf:120]: Found device at address 0x24
[19:28:21.552][C][esp32_rmt_led_strip:271]: ESP32 RMT LED Strip:
[19:28:21.552][C][esp32_rmt_led_strip:271]: Pin: 48
[19:28:21.552][C][esp32_rmt_led_strip:275]: RMT Symbols: 48
[19:28:21.552][C][esp32_rmt_led_strip:300]: RGB Order: GRB
[19:28:21.552][C][esp32_rmt_led_strip:300]: Max refresh rate: 0
[19:28:21.552][C][esp32_rmt_led_strip:300]: Number of LEDs: 1
[19:28:21.567][C][gpio.binary_sensor:016]: GPIO Binary Sensor 'Back Button'
[19:28:21.568][C][gpio.binary_sensor:152]: Pin: GPIO4
[19:28:21.568][C][gpio.binary_sensor:069]: Mode: interrupt
[19:28:21.571][C][gpio.binary_sensor:071]: Interrupt Type: ANY_EDGE
[19:28:21.571][C][gpio.binary_sensor:016]: GPIO Binary Sensor 'Encoder Push'
[19:28:21.572][C][gpio.binary_sensor:152]: Pin: GPIO7
[19:28:21.580][C][gpio.binary_sensor:069]: Mode: interrupt
[19:28:21.580][C][gpio.binary_sensor:071]: Interrupt Type: ANY_EDGE
[19:28:21.581][C][gpio.binary_sensor:016]: GPIO Binary Sensor 'Confirm Button'
[19:28:21.584][C][gpio.binary_sensor:152]: Pin: GPIO17
[19:28:21.585][C][gpio.binary_sensor:069]: Mode: interrupt
[19:28:21.585][C][gpio.binary_sensor:071]: Interrupt Type: ANY_EDGE
[19:28:21.608][C][light:091]: Light '${friendly_name} LED'
[19:28:21.608][C][light:094]: Default Transition Length: 1.0s
[19:28:21.608][C][light:094]: Gamma Correct: 2.80
[19:28:21.608][C][template.switch:092]: Template Switch '${friendly_name} Buzzer Enabled'
[19:28:21.608][C][template.switch:092]: Restore Mode: restore defaults to ON
[19:28:21.616][C][template.switch:157]: Icon: 'mdi:volume-high'
[19:28:21.616][C][template.switch:055]: Optimistic: YES
[19:28:21.630][C][template.switch:092]: Template Switch '${friendly_name} LED enabled'
[19:28:21.630][C][template.switch:092]: Restore Mode: restore defaults to ON
[19:28:21.630][C][template.switch:157]: Icon: 'mdi:alarm-light-outline'
[19:28:21.630][C][template.switch:055]: Optimistic: YES
[19:28:21.630][C][psram:016]: PSRAM:
[19:28:21.635][C][psram:019]: Available: YES
[19:28:21.635][C][psram:021]: Size: 8192 KB
[19:28:21.635][C][pn532:430]: PN532:
[19:28:21.638][C][pn532:488]: Update Interval: 1.0s
[19:28:21.638][C][pn532_i2c:125]: Address: 0x24
[19:28:21.642][C][hx711:017]: HX711 'HX711 Value'
[19:28:21.642][C][hx711:017]: State Class: 'measurement'
[19:28:21.642][C][hx711:017]: Unit of Measurement: ''
[19:28:21.642][C][hx711:017]: Accuracy Decimals: 0
[19:28:21.644][C][hx711:157]: Icon: 'mdi:scale'
[19:28:21.645][C][hx711:152]: DOUT Pin: GPIO11
[19:28:21.645][C][hx711:152]: SCK Pin: GPIO10
[19:28:21.667][C][hx711:488]: Update Interval: 1.0s
[19:28:21.667][C][rotary_encoder:017]: Rotary Encoder 'Rotary Encoder'
[19:28:21.667][C][rotary_encoder:017]: State Class: ''
[19:28:21.667][C][rotary_encoder:017]: Unit of Measurement: 'steps'
[19:28:21.667][C][rotary_encoder:017]: Accuracy Decimals: 0
[19:28:21.667][C][rotary_encoder:157]: Icon: 'mdi:rotate-right'
[19:28:21.667][C][rotary_encoder:152]: Pin A: GPIO5
[19:28:21.667][C][rotary_encoder:152]: Pin B: GPIO6
[19:28:21.667][C][rotary_encoder:178]: Restore Mode: Restore (Defaults to zero)
[19:28:21.701][C][rotary_encoder:182]: Resolution: 1 Pulse Per Cycle
[19:28:21.701][C][ssd1306_i2c:022]: I2C SSD1306
[19:28:21.701][C][ssd1306_i2c:022]: Rotations: 0 °
[19:28:21.701][C][ssd1306_i2c:022]: Dimensions: 128px x 64px
[19:28:21.701][C][ssd1306_i2c:023]: Model: SH1106 128x64
[19:28:21.701][C][ssd1306_i2c:023]: External VCC: NO
[19:28:21.701][C][ssd1306_i2c:023]: Flip X: YES
[19:28:21.701][C][ssd1306_i2c:023]: Flip Y: YES
[19:28:21.701][C][ssd1306_i2c:023]: Offset X: 0
[19:28:21.701][C][ssd1306_i2c:023]: Offset Y: 0
[19:28:21.701][C][ssd1306_i2c:023]: Inverted Color: NO
[19:28:21.704][C][ssd1306_i2c:033]: Address: 0x3C
[19:28:21.704][C][ssd1306_i2c:484]: Update Interval: never
[19:28:21.709][C][lvgl:103]: LVGL:
[19:28:21.709][C][lvgl:103]: Display width/height: 128 x 64
[19:28:21.709][C][lvgl:103]: Buffer size: 100%
[19:28:21.709][C][lvgl:103]: Rotation: 0
[19:28:21.709][C][lvgl:103]: Draw rounding: 2
[19:28:21.727][C][captive_portal:134]: Captive Portal:
[19:28:21.738][C][wifi:1450]: WiFi:
[19:28:21.738][C][wifi:1450]: Local MAC: E0:72:A1:FC:E3:30
[19:28:21.738][C][wifi:1450]: Connected: YES
[19:28:21.738][C][wifi:1202]: IP Address: 192.168.120.167
[19:28:21.742][C][wifi:1213]: SSID: [redacted]
[19:28:21.742][C][wifi:1213]: BSSID: [redacted]
[19:28:21.742][C][wifi:1213]: Hostname: 'drybox-rfid-screen'
[19:28:21.742][C][wifi:1213]: Signal strength: -53 dB ▂▄▆█
[19:28:21.742][C][wifi:1213]: Channel: 6
[19:28:21.742][C][wifi:1213]: Subnet: 255.255.255.0
[19:28:21.742][C][wifi:1213]: Gateway: 192.168.120.1
[19:28:21.742][C][wifi:1213]: DNS1: 192.168.120.1
[19:28:21.742][C][wifi:1213]: DNS2: 0.0.0.0
[19:28:21.747][C][esphome.ota:075]: Over-The-Air updates:
[19:28:21.747][C][esphome.ota:075]: Address: drybox-rfid-screen.local:3232
[19:28:21.747][C][esphome.ota:075]: Version: 2
[19:28:21.747][C][esphome.ota:082]: Password configured
[19:28:21.754][C][safe_mode:022]: Safe Mode:
[19:28:21.754][C][safe_mode:022]: Successful after: 60s
[19:28:21.754][C][safe_mode:022]: Invoke after: 10 attempts
[19:28:21.754][C][safe_mode:022]: Duration: 300s
[19:28:21.773][C][safe_mode:039]: Bootloader rollback: supported
[19:28:21.773][C][web_server.ota:238]: Web Server OTA
[19:28:21.779][C][api:237]: Server:
[19:28:21.779][C][api:237]: Address: drybox-rfid-screen.local:6053
[19:28:21.779][C][api:237]: Listen backlog: 4
[19:28:21.779][C][api:237]: Max connections: 8
[19:28:21.779][C][api:244]: Noise encryption: YES
[19:28:21.785][C][mdns:177]: mDNS:
[19:28:21.785][C][mdns:177]: Hostname: drybox-rfid-screen
[19:28:22.470][D][hx711:029]: 'HX711 Value': Got value 115735
[19:28:23.354][D][sensor:118]: 'HX711 Value' >> 115735
[19:28:23.474][D][hx711:029]: 'HX711 Value': Got value 115770
[19:28:24.354][D][sensor:118]: 'HX711 Value' >> 115770
Hopefully someone can see what I am doing wrong.
