Esp32-s3 n8r2
Hello everyone, I need help. There is such a module that does not start after loading.
esphome:
  friendly_name: esp32-s3N8R2
  platformio_options:
    board_build.flash_mode: dio
esp32:
  board: esp32-s3-devkitc-1
  variant: esp32s3
  framework:
    type: arduino
logger:
web_server:
  port: 80
api:
ota:
  - platform: esphome
[10:38:38]ESP-ROM:esp32s3-20210327
[10:38:38]Build:Mar 27 2021
[10:38:38]rst:0x1 (POWERON),boot:0x8 (SPI_FAST_FLASH_BOOT)
[10:38:38]SPIWP:0xee
[10:38:38]mode:DIO, clock div:1
[10:38:38]load:0x3fce3808,len:0x39c
[10:38:38]load:0x403c9700,len:0x9bc
[10:38:38]load:0x403cc700,len:0x28dc
[10:38:38]entry 0x403c98c0
i use this on that board
esp32:
  variant: ESP32S3
  framework:
    type: esp-idf
    version: recommended
  flash_size: 8MB
best of luck
only type: esp-idf ?
type: arduino?
only tried with esp-idf, probably work with Arduino too if you just add in flash_size: 8MB
And when you get it working, add this to your code to make available the 2mb psram.
psram:
  mode: quad
